Hi Everyone,
Since the release of the 3D printable cell setup is focussed on getting people started with experiments as easily as possible. I thought I would design a gated oscillator that uses as few components as possible. Find the preliminary work attached.
This design uses a single CD4093 IC for both Gate and Main oscillators, plus the necessary inversion. It isn't perfect, but gives most of what is needed, I believe.
I'll update you as this progresses but it should work fine when coupled to a IGBT or Mosfet output, and, could be built quite easily on strip board if necessary.
I will upload scope captures etc when I get it finalised.
Best, even.
Best, even.
