7 tube WFC Stan Meyers Plans Size Dimensions Water Fuel Cell
francoisohsiek
Re: 7 tube WFC Stan Meyers Plans Size Dimensions Water Fuel Cell
« Reply #51, on July 18th, 2022, 01:35 AM »
Hi guys,
Sorry to u here, I can't seem to find an 11 cell 3d print file any where on the forum only images.
Does anyone have these or can post here please?
maybe email it to me? francoiskorff@gmail.com.
Thanks in advance.
on a side note, for a 3.0L engine, what size of the exciter array is recommended? sorry for the noob question.
Earl
« Reply #53, on July 19th, 2022, 04:16 AM »
I have seen the drawings that have all the information needed to machine them Russ had posted them but do not recall 3d print version for 11 cells.  Russ has machining parts. He had
I have done another test on 7 cell holder. I isolated one of the 7 cells holder tubes and printed at 98% scale and that gave a nice tight fit that could still slide both tubes in easily.
Earl
Earl
« Reply #56, on August 23rd, 2022, 01:00 AM »
Shared but another builder
6 cells made and did measurements on all 6.  The cheap meter I am using also give the frequency being used during test if you press a button, so I included that information in reading below.
Test of 6 sets of tubes outer 1/2” x 3 ½” inner 3/8” x 4” using capacitance meter above
      Outer Pos Lead            Out Neg Lead
        Cap in pF          Freq in Hz              Cap in pF          Freq in HZ
1.   31.75 - 31.80   667140         29.76 – 29.80   667680
2.   31.95 - 32.01   666750         29.83 – 29.93   667444
3.   31.32 - 31.47   667160         29.71 – 29.74   667840
4.   31.95 - 32.03   667108         30.20 – 30.33   667550
5.   31.51 – 31.63   667310         30.25 – 30.33   667735
6.   31.96– 32.07   667007         30.43 – 30.57   667512
   This one is with bottom spacer on both ends so inner tube sticks out both ends. I wanted to see if capacitance changed to see if this could be used to tune system.
7.   32.86 – 33.11   667540         31.19 – 31.31   667840
the frequency is 667140 (six hundred sisxty seven ty thousand and one hundred forty)
not 667.14 (six hundred sixty seven point forteen)
