Bypass Diode Vs Blocking Diode Stanley Stephen Meyer
« on June 24th, 2021, 09:02 AM »Last edited on June 24th, 2021, 09:05 AM
 I post this here as several builder have    discussed this and  decided to share it. but remain anonymous
Today we are going to talk about the difference Between
a Bypass Diodes on your voltrolysis tube Cells
and Blocking Diodes on your Vic Driving Circuit Combiner box
for the whole voltrolysis unit and water fuel maker.
Alot of People are Confused what these diodes are used for,
so we are going to go over that now as part of our
ongoing Stanley A Meyer Voltrolysis Teachings
and advanced Methods series.
Every Voltrolysis Unit tube Cell assembly should
have a blocking diode on the DC volts in
and a bypass diode or multiple diodes between the Tube Cell pairs.
You can find these Bypass Diode by opening up your aluminum.
Tube cell base cover or Blocking Diode can be found in the
Multi Vic trigger junction box where your Voltrolysis Tube Cell pairs
Connect to..
(Combining the Staged parallel  Vic transformer Voltages to the
Tube Cell pairs in Series.)
The Bypass Diodes are in the Voltrolysis Unit Base under
the Aluminum RF sleeve cover (which stops coupling effects)
There is 1 Bypass Diode between Every Tube cell pair.
What a Diode Does,
 is it allowing current to flow in one direction?
Even so it should be again noted,
as this Stanley A Meyer Voltrolysis (Not Electrolysis)
As Builders we focus on raising the applied Step Charge
 DC voltage level applied to the tubes cells whilst not raising amps.
The Resistance of those bypass diodes and blocking diodes aid
in restricting amps with the chokes in the circuit to
 further reduce amps being drawn to the Cell pairs
and at the same time ensure Raising Voltage,
as they also have resistance as Components in the circuit.
The Tube Cells in the Voltrolysis Unit
are Wired in Series between each tube cell set.
to ensure they can produce enough DC voltage.
To make enough voltage so the
The Magnetic Water to Gas Separation Effect is maintained.
or what we call Voltrolysis.
So, first point is
the number of Diodes in the cell sets Combiner.
box tells you how many cell pairs you have in the
Voltrolysis Unit Cell Assembly.
Tube cell are always in Pairs never singular tube cells.
As we balance the resistance of inner and outer tubes diameter
by pairing the cell tubes in series.
For the Bypass Diode
Each Bypass Diode is Wired in Parallel between each
Tube Cell pair in the Voltrolysis Unit.
This will insure even if 1 Tube Cell pair is
empty of water or not performing/
The rest of Series Tube Cell pairs that this pairs is Connected to
will keep performing and producing Gas via Voltrolysis.
at the right voltages.
So the Bypass Diodes
bypass a failing Tube Cell set if is empty.
not producing enough gas.
But if you are a beginner, you might be curious what a
Series Tube set is,
so these tube Cells are wired in series so they
can produce a voltage high enough at right rf in a balanced resistance way.
to be used to run voltrolysis unit.
without amps and make Hydrogen on demand
from the Distilled water.
Inside a Typical
6 cell or 10 Cell Voltrolysis unit you will have paired set of tubes.
for a 6 Cell you will have 3 Series Pairs 3 Diodes in Parallel
for a 10 Cell you will have 5 Series Pairs 5 Diodes in Parallel
So it can create 0 to 600 Vdc in the Stanley Meyers Version 1
circuit assembly 8xa/9xb for example
This will ensure even if 1 Set is empty or not performing.
the other sets keep performing at 0 - 600 Vdc from
your Switch gate Control voltage level(variac).
The Tube Cells are Wired in Series and wired in set via series method also.
to ensure they can produce enough.
DC voltage. To make The Magnetic Water to gas Separation Effect,
or what we call Voltrolsis. ( a non-electrolyte process)
with no dead short or amp draw
So, in the Voltrolysis 6 tube Cell unit
we have 3 Series tube cell Sets to create.
this effect.
In the first tube cell set,
if you look at how these tubes cells are wired.
it starts right here than it connects to this one
and this and this one,
and creates a series tube cell set and complete voltrolysis unit,
So, if any of these Tube Cell sets on this Series
fail, that bypass Diode will allow voltage to
flow past that Tube Cell Set on that series.
Because if this tube cell set is failing
to produce gas or in dead short from contaminates,
it will bring down the whole voltrolysis cell series.
performance.
So, the Bypass Diode allows it to be bypassed
And Because these Tube cell sets are in series, even if a
single tube cell set fails, it will wipe out the Gas producing.
 capability of the whole Voltrolysis unit and all its sets.
So, whether 1 Tube Cell Set Fails or Multiple Tube Cell sets Fail,
that Bypass diode will still be activated and bypass.
that Tube Cell Set Failure.
Provided that all the tube Cells are made with precision
this also allow an easy range of PLL to tune to 1 cell set.
Creating a close equivalent to a spider antenna tuning mechanism.
Also, if the whole voltrolysis unit fails,
then all bypass diodes will allow the whole voltrolysis unit
to be bypassed in the case you have multiple whole voltrolysis units.
in series. (whether they be 6 10 or 20 tube units)
So if 1 Tube Cell Pair Fails it will not reduce the
whole gas output of the while Voltrolysis unit or series of units,
If I did not have these bypass diodes. I and I had 3
Voltrolysis units connected in series with this one,
and one voltrolysis unit fails all 3  voltrolysis
units would not produce gas.
But because we have bypass diodes,
if this 1 Voltrolysis unit fails the other
2 voltrolysis unit would still products gas.
So, bypass Diode are very important for failing cells or units.
Blocking Diodes.
Now let’s talk about blocking diodes
as they are completely different.
First Difference of a Blocking Diode vs a Bypass Diode
is a Bypass diode is in parallel configuration?
with the series tube cells pairs.
With a Blocking Diode, it is in series configuration to the
Series tube cell pairs.
So here is a Combiner Box Circuit layout and it shows.
2 individual Voltrolysis Units.
Traditionally in the olden days the blocking diode was used to
ensure batteries did not discharge at night.
You Can think of the Voltrolysis unit as a capacitor,
due to the fact that it charges up and hold voltage.
We want the cell to start charged so it keep producing during
the gate off time.  In Addition, we do not want to ground the cell.
but in fact hold the cell charged. The more the water splits the more.
free electrons become available in the cell and water charging it up further.
The more Positive charged the water the stronger the surface tension of water.
becomes and thus holds more nano bubble in suspension.
So, the Blocking diodes perform that job first for us.
But Blockings Diode have a Second job they can accomplish for us,
they can be especially useful some Voltrolysis cell configurations.
For Example, when we use the Sequential Vic with the triggering system.
the vic are in parallel, it is possible if one vic or cell pair is under performing.
  it will lower the voltage of both bringing down the performance of
the other cell pairs or vics and Voltrolysis unit.
So, if you have 2 Voltrolysis Units in Parallel from vic trigger junction box
you can ensure the lower voltage of one(the capacitance) will not bring down
 the voltage of other and thus they stay Matched. or in tune or in resonance.
Let’s imagine we have 2 Voltrolysis units, one unit is a higher temp or pressure.
than the other voltrolysis unit. So, what will happen because they are connected?
in parallel, the lower producing Voltrolysis unit will discharge some.
of the energy of the higher producing voltrolysis unit.
Also the Voltages will not match so whenever you are triggering or scaling voltages
in parallel to these series pairs you want the voltage to match.
So having a mis match could actually lower the voltage of both arrays if one
 of them is under performing.
So what a blocking diode does, is ensure this does not happen.
it allows current to flow in only 1 direction and from each Voltrolysis unit.
This method can be used on the Electron Extraction circuit also across multiple.
Voltrolysis Units.
And typically, we will have 1 Blocking diode for Each Voltrolysis Units or Cell Pair.
But you can also do 2 pairs per blocking diode provided component max voltage.
specification allows it. That way you will have no fighting and current voltage.
 will flow in an equal fashion to achieve max voltage in Tube Cell Pairs
and Voltrolysis Units.
So over the course of operation, you will produce more voltage in the tubes and thus more gas / water fuel if properly implemented.
Blocking diodes can cause a slight voltage drop but also they help us by
restricting some amps via in line resistance
and balance voltage made between the tube cell pairs to benefit our system.
and tuning efforts.
Keep in mind we can see these diodes in our Multiple vic trigger system
as we are sending scalable parallel voltage to
series Tube cell pairs and voltrolysis units.
So the Blocking Diodes doing 2 jobs for us
 1 Balancing DC High Voltages applied
 2 Holding and stopping voltages from draining out
of our water capacitor. (Voltrolysis Units) whilst protecting our circuits from damage
But if you have only a single Series Voltrolysis unit on a 8xa/9xb
 connecting to only 1 vic , we only use 1 feature of the Blocking diode.
 2 Holding and stopping voltages from draining out.
of our water capacitor. (Voltrolysis Units) whilst protecting our circuits from damage.
That is pretty much it.
a Bypass diode will bypass a Pair of Tube Cells or
a string of voltrolysis units. To ensure the maximum output from your
Water Fuel Unit.
A Blocking diode traditionally used to avoid discharging of Water Capacitor.
but now days it is also used for when multi vic are connected in parallel to drive.
 tube cell pairs or voltrolysis units.
Attached is what this looks like on paper ,
it draw some comparison to Stephen Meyers use of the Diodes.
if one inputted from multiple vic it is a close match.
and helps us see more than just a Balun circuit.
