The attached pdf it the results of my testing of the Feedback coil and Stan's Pulse indicator circuit. The two screen shots below shot 2 examples of what the output of K14 signal H input in K21. The also show that the K14's output level does not change with frequency.
The test report also show the 2 feedback coil outputs and how they change going through K14. This is a simple circuit and it is a standard circuit for an Op Amp with a gain of 10, which is set by the resistors. The diodes ensure the proper voltage +/1 is place on the Op Amp input pins. The rest of items on the output are there to drive the led.
The 5v offset is removed by the Op Amp and is there so the Op Amp does not require a negative power supply, instead ground is used.
The gain of 10 is need to raise voltage level to that needed by K21. Note: Level is not critical as long as it is high enough. The important part of the signal is the phase information.
My testing also show that winding the coil with halve the wire, adding 5V to center, then winding other half is not a problem, this is what I did. I believe you could also add 5v to center then wind both halves at same time.
As you can see in the pictures below the feedback coils track the digital pulses.
I do want to note: I did not use all the VIC coils for this test I just used the Primary and Feedback coils. The secondary was on the core but not hooked up. My main purpose was to see what the feedback coil output looked like and to see what K14 did to the signals. I think the testing accomplished those goals.
One side benefit for me was that have feedback coil and K14 in the system made the output of K21 much more stable. Some of this due the present of the feedback loop on the Op Amp in the circuit which helps to eliminate noise, again a standard function of this type of circuit.
