All Great things start with a first step
People have asked for a Vic start up and Vic tune step guide
here is a start , i hope people will add to is
Re tuning vic start up
Several Thread here is some of it
1 look at the scope make sure initial signal is tuned balanced dry first
2 start low volt 1 to 2 volt and low amps you should see gas let it charge up
3 you should have gas
4 use a compass to tune LMD 90 direction as if wrong now polarization no effect will occur
( joe said with out correct resistance you dont get 90 " so you done get gas
5 LMD it is tune the dipole to reflect back on cell
6 when diode there the reflect should raise voltage and turn back to dc
