HOW TO BUILD WITH ATOMS THROUGH THE POWER OF THINKING
I remarked earlier that the French Revolution arose out of the secret societies (Note 4) of the occultists, and if these currents were investigated further, they would lead back to the school of the adepts.
Now the French Revolution certainly proceeded from such things as this. There is a well-known story contained in the writings of the Countess d'Adhémar. It related that, before the outbreak of the French Revolution, the Countess d’Adhémar, one of the ladies-in-waiting to Marie-Antoinette, received a visit from the Count of St. Germain.
In the school founded by the Landgrave of Hessen, also, there were two main concerns: the Philosopher's Stone and the Knowledge of the Pentagram. The Freemasonry founded by the Landgrave of Hessen at that time continued to exist in a rather diluted form. In fact, the whole of Freemasonry, as I have described it, is called the Egyptian rite, the rite of Memphis and Misraim. The latter traces its origin back to King Misraim who came from Assyria — from the Orient — and, after the conquest of Egypt, was initiated into the Egyptian mysteries. These are indeed the mysteries which originate from ancient Atlantis. An unbroken tradition exists from that time. Modern Freemasonry is only a continuation of what was established then in Egypt.
When people sit together and have a discussion they talk about their own views, sometimes also about the most elevated things. But all of this exists on the level of illusion, and is just as irrelevant as what a person says who is ignorant of the true sum of the angles of a triangle and only gives his own opinion about it. Just as one is unable to discuss whether the sum of the angles of a triangle have this or that many degrees, so one is also unable to have a discussion about higher truths. That is why the democratic principle is not applicable to matters of knowledge, for there is no basis of argument on which to discuss them. What distinguishes masonry of the higher degrees from craft masonry is that one learns to know the truth step by step. Whoever has recognised a thing can no longer hold more than one opinion about it. One has either recognised it, or one has not done so. The ninety-six degrees have, therefore, a certain justification
It is only very recently that science has been able to form a conception of what the atom is. It stands [in the same relationship to electricity] as ice does to water out of which it has been frozen. The physical atom is condensed electricity. I regard Balfour's speech as something of extreme importance.
The secret which will be discovered is that electricity — when one learns to view it from a particular level — is exactly the same as what human thought is. Human thought is the same thing as electricity, viewed one time from the inside, another time from the outside.
Whoever is now aware of what electricity is, knows that there is something living within him which, in a frozen state, forms the atom. Here is the bridge from human thought to the atom. One will learn to know the building stones of the physical world; they are tiny condensed monads, condensed electricity. In that moment when human beings realise this elementary occult truth about thought, electricity and the atom, in that same moment they will have understood something which is of the utmost importance for the future and for the whole of the sixth post-Atlantean epoch. They will have learned how to build with atoms through the power of thinking.
The Temple Legend
THE ESSENCE AND TASK OF FREEMASONRY FROM THE POINT OF VIEW OF SPIRITUAL SCIENCE
https://wn.rsarchive.org/Lectures/GA093/English
Freemasonry and Related Occult Movements
https://wn.rsarchive.org/Lectures/GA093/English/
Ian Colmer Pyramid Harmonic Geometry
Draw a horizontal line on a piece of paper. Make two circles, each one with it's centre point on the line, and each circle touching. Now draw 2 lines vertically until they intersect with the circles circumference. Connect the 4 points, making a cross.
Use this new centrepoint as the centre of a new circle, that intersects those 4 points. If you now draw a line from the base (horizontal line) to the top of that new circle, you will have the exact length of the side of the pyramid.
Use this length as a radius distance, and make two new circles from the original circle centres. They will intersect the vertical line, and give you the exact height of the pyramid. The most important part of all of this is that the angle created is a harmonic CONSTANT. This was verified by Bruce L. Cathie.
https://web.archive.org/web/20090226015700/http:/www.ianja
Quatrefoil
3 5 7
A PROOF OF EUCLID’S 47th PROPOSITION
https://www.facebook.com/permalink.php?story_fbid=838996163
It is correct to say that humanity will be astonished by some of the discoveries which will be made in the near future. But they will be rather premature discoveries and will thereby cause some havoc. The task of the Theosophical Society consists mainly in preparing people for such things. For instance, what I described at the beginning as the knowledge of the Philosopher's Stone was formerly much more universally known than it is today and, indeed, it was known already during a certain period of the Atlantean Epoch. At that time the possibility of conquering death was really something which was commonly known. I only wish to remark that I was not very happy about allowing this truth to appear in print recently. Therefore where this should have come in the discussion about Atlantean times in the Luzifer article, a row of dots was printed in place of those things which may not yet be communicated. (Note 14) It cannot even yet be communicated in its entirety. There is a very similar piece of information recorded by a very advanced medium, which appeared in the Theosophical Review (Note 15) dealing with exactly the same thing in a rather different form. The overcoming of death in Atlantean times is naturally preserved in the memories of the individuals concerned without their being aware of it. There are many people reincarnated today who passed through that period in their former lives and who are led to such revelations through their own memories. That will first of all lead to a kind of overrating of certain medical discoveries. People will imagine that medical science was the discoverer of such things. In reality people will have been led to them through their own memories of Atlantean times.
‘I will now tell you a little more about the wonderful power of Atlantis, so as to make you realise what man has been, and will be in the future ages; for to tell the truth Atlantis was material perfection, to this man can never return, but to perfection he will come in future time.
‘The ways of life of the highest classes were most simple, for nourishment was obtained almost from the air alone. Like orchids, the rulers, and more especially the priests, drew all their sustenance from the substance contained in the atmosphere. Consult any botanist you like and you will see that I am right. You cannot do this, for you are not self-materialised; you are creatures born, and not made by your own will ...
‘It was only the discovery of the great secret, that of the “tree of life”, which simplified matters, and that you will never regain until you cease to care for the power for its own sake. I mean the secret of death and birth. There is no need for men to die. There is no reason for men to be born. I know the secret in part, but not fully, for I am not good enough to be permitted to recall the wonderful power. If I could do this I should at once be tempted to reveal it to you, for it would be, God willing, an eternity of happiness.
‘I will, however, try and define somewhat and give you an example. A man is entirely renewed each seven years; after a while, however, he deteriorates and slowly decomposes. This is owing to ignorance, for if he knew how to regulate the inflow of new particles, he would never choose worse but rather better particles, and the atoms would remain permanently polarised by his will. Man is really held in a single cell; this cell is immortal and descends from generation to generation, creating ever new forms in which a human spirit can manifest. If this cell is retained in the body, and there is no procreation or waste of conservative power, then there is no reason why man should not exist for ever, during the cycle. By his children, however, man reproduces himself, and so destroys his material self. To an adept, to marry is to become a lower creature subject to death. This is truth. Every man or woman who creates can only do so by handing on his immortality. Man is a spirit, and the spirit is the central point of the materialised form. The whole of mankind accepts death as a necessity, and therefore hypnotise themselves into a belief that they must, die, but there is no reason for it if the cell is still intact in them.
‘Think it over and understand that this is one of the chief Christian teachings that has been corrupted. Christ rose from the dead to be the first fruits of life.
‘I want to refer to the new discovery which will be made, and of which I have previously spoken. It was well known once, and will return to the fated man's memory, and he will be hailed as a benefactor of humanity. In the old days of Atlantis when the secrets of the body were entirely unveiled to the caste of rulers and priests, they learnt it in a far more terrible way even than that of vivisection, namely by the stultification of the soul, thus destroying or distorting the power of evolution in a creature. You do not know this, thank God! or the earth would be once more a land of devils ...’
St Germain
The seasons will gradually change — first the spring, then the summer. It is the gradual cessation of time itself, as the announcement of the end of the cycle. I see it all; astrologers and meteorologists know nothing, believe me; ONE NEEDS TO HAVE STUDIED IN THE PYRAMIDS AS I HAVE STUDIED. Towards the end of this century I shall disappear out of Europe, and betake myself to the region of the Himalayas. I will rest; I must rest. In exactly 85 years people will again set eyes on me.
https://wn.rsarchive.org/Lectures/GA093/English/RSP1985/Tm
Let us take our start from the fact that the Freemasons were THE BUILDERS OF THE PYRAMIDS, of the mystery temples, and of the churches. You will easily gain the conviction — especially by reading Vitruvius (Note 7) — that the manner in which architecture was formerly studied is quite different from our present method. One did not study it at that time by making calculations, but instead, definite intuitions were imparted by means of symbols.
If you read in Luzifer (Note8) how the Lemurians developed their building capacity you will get an inkling of the way in which this art was then practised. It is not possible today to build in that manner. With amazement and wonder we behold the buildings of the ancient Chinese and of the Babylonians and Assyrians, and know that they were constructed without a knowledge of our present-day mathematics. We behold the wonderful engineering feat of Lake Moeris in Egypt; a lake which was constructed to collect water which could be diverted into irrigation channels in times of need. It was not built with our modern engineering technique. The wonderful acoustic effects produced in old buildings were achieved in a way which modern architects are not yet able to imitate. At that time men were able to build by means of intuitive faculties, not through rational understanding.
The whole of this kind of architecture stood in relationship to a knowledge of the universe. If you take THE EGYPTIAN PYRAMIDS, for instance, their measurements correspond to certain measurements in heavenly space, to the distances of the stars in space. The whole configuration of stellar space was depicted in these buildings. There was a connection between the individual building and the dome of heaven. The mysterious rhythm presented to our gaze when we behold the starry heavens — not just with our outer sense, but with an intuitive gaze which penetrates to higher relationships, to rhythmical relationships — that was what the original architects included in their building, because they were building out of the universe.
Now you will have an idea of what Freemasonry used to be and you will realise that it had to outgrow its real task. It was bound to lose its significance as the world became rationalistic. It had its meaning when the fourth cultural epoch was still being developed. The fifth epoch brought about the loss of its importance. Today, Freemasons are no longer masons. Anybody can become a member. For occultists, symbols have a real meaning. A symbol that is merely a symbol, merely a copy or image, has no meaning; there is only significance in what can become a reality, in what can become a living force. If a symbol acts upon the spirit of humanity in such a way that intuitive forces are set free, then we are dealing with a true symbol. Today, Freemasons say they have symbols which mean this or that. An occult symbol, however, is one which takes hold of the will and leads over into the astral body. Inasmuch as our culture has become an intellectual culture, Freemasonry has lost its meaning.
The history of Freemasonry is related to them in the following way: The first true mason was Adam, (Note 12) the first man, who had an extraordinary knowledge of geometry at the time of his expulsion from Paradise. He was recognised as the first mason because, being the first man, he was a direct descendant of the Light. The true, deeper origin of Freemasonry, however, pre-dates humanity entirely. It resides in Light itself which existed before mankind.
This original insight and its reflection in Freemasonry was lost; there was no longer any conscious appreciation of the transformation wrought by a proper use of acoustics in a building where the speaker's words are thrown back and are thereby changed in their effect. Those who built the great cathedrals of medieval times were the great Freemasons. They were aware of the importance of the fact that what was spoken by the priest should be reflected back from the individual walls and the whole congregation immersed in a sea of sound, breathing and fluctuating in significant vibration which would exercise still greater effect on the astral body than on the physical ear. That has all been lost and it was inevitable that this should be so in the new age. That is what I meant when I told you that what is left of Freemasonry is only the husk of what it was in former times.
‘That is and has been the great longing of mankind ever since human beings who could reason existed. Mankind needs to have this assurance of a life after death in order to be truly happy in this present life. Therefore all the mysteries contained in the religions and centres of hidden wisdom have occupied themselves with this question as their highest and principal task. The Church has naturally also occupied itself with this question of the “Lost Word”; the “Lost Immortality”, but it directs the candidate along the path of grace and portrays it as a gift from above and not as something to be achieved by personal effort. Our Order, however, places it within the power of each individual seeker, by practical means, to unite himself consciously and voluntarily with the World Consciousness, with the ultimate forces of Creation.’
The second lesson was the knowledge of THE PENTAGRAM. That is the ability to distinguish the five bodies of man one from another. When someone says: physical body, etheric body, astral body, Kama-Manas body, causal body, [higher Manas or spirit self] these are mere words, or at best, abstract ideas. Nothing, however, is achieved by that. A person living today as a rule hardly knows the physical body; only one who knows THE PENTAGRAM learns to know the five bodies. One does not know a body by living in it, but by having it as an object. That is what distinguishes an average person from one who has gone through such a schooling that the five bodies have become objects.
You all have a soul and you all have a spirit. This soul and spirit are called upon to reach one day the highest stages of perfection. But you were already there before your first physical incarnation. You were first physically incarnated in the preceding races after the time of the Hyperborean and Polarian epochs. (Note 5) Before that you were purely beings of soul. But as beings of soul you were a part of the world soul, and as spirit you were part of the general world spirit. The world soul and the world spirit were spread around you as Nature is spread around you today. Just as the mineral world, the plant world and the animal world are around you today, so were the worlds of soul and spirit spread around you then. And what was once outside you is now your soul; you have made inward what to begin with was outside. What today is your inward part was once spread about outside. This has now become your soul. The spirit, too, was once spread around you. And what is now spread around you will become your inner life. You will take into yourself what is now the mineral kingdom, and it will become your inner part. The plant kingdom will become your inner part. What surrounds you in Nature will become your inner being.
You will understand now how this is connected with the first example given: you build a church for others, not for yourself. You can take into [yourself] a world full of majesty, beauty and splendour if you make the world majestic, beautiful and splendid. To do something for the higher self is not selfish because it is not done only for the self. This higher self will be united with all other higher selves, so that it is [done] for all at the same time.
It is this that the Freemasons knew. The Freemason knew, when he helped [by] building with the spiritualisation of the mineral world, that this would one day become the content of his soul — and to build means nothing else than to spiritualise the mineral world. That is the significant thing: God once gave us the Nature that surrounds us, as mineral, plant and animal nature. We take these in [to ourselves]. It is not due to us that it is there; all we can do is to appropriate it for ourselves. But what we ourselves create in the world — that is what will, through ourselves, constitute our future being.
The secret of secrets is this, therefore: the human being must learn how to keep silence about the paths along which his ego unfolds, and to regard his deeds, not his ego, as the criterion. The real heart of the secret lies in his deeds and the overcoming of the ego through action. The ego must remain concealed within the deed. Elimination of the interests of the ego from the onstreaming flow of karma — this belongs to the first degree. Whatever karma the ego incurs is thereby wiped out from karma. Nation, race, sex, position, religion — all these work upon human egoism. Only when mankind has overcome all these things will it be freed from egoism.
The individual will acquire more and more power over certain masses of people. For the drift of this development is not that we will become democratic, but that we will become brutally oligarchic, in that the individual will gain more and more power. If the ennobling of morals is not achieved, then the most brutal forces will lead. This will happen, just as catastrophe by water happened to the Atlanteans.
But that is, after all, quite natural; as materialism developed itself, then the priestly wisdom did indeed have to fade away. What can happen now? The old wisdom has gone away. We have to live in the external. What follows from that? This — that something better can come along again, only when a wisdom arrives which is again asexual, which is connected neither with the male nor with the female wisdom, neither with the female Bible, nor with the male Temple Legend. We find this wisdom in theosophy. In this wisdom both sexes understand each other. In it, the man that is in woman is at work on woman, and what is once more asexual is working on man. Male and female meet each other there in the knowledge of higher planes. It is therefore quite natural that the proper occult basis has come about in Freemasonry, and that a new start has been made. Something such as this is called a ‘VORTEX’
2day
1 8 2020
1 8 4
13
circles
https://www.facebook.com/permalink.php?story_fbid=876790522
