Nature is very simple in her causes
« on June 9th, 2020, 03:50 AM »Last edited on June 9th, 2020, 03:52 AM
Nature is very simple in her causes.
She is complex only in her repeative effects.
My friendly critics will of course admit that there are two foci to any elliptical orbit. If one of these foci is important, why is not the other equally so? What is the cause of elliptical orbits if not that some doubly acting force, concentrated at two foci, is exerting its opposite influences on both masses, not on one. For this reason also it is inaccurate, because untrue, to say that the sun is at one of its foci. That informs that the sun’s centre is one of its foci, which is not true. The true focus, which only happens to be within the sun, because of the sun’s huge bulk, is the mutual gravitative centre of both sun and planet, or earth and moon.
If Newton had watched that apple compose itself from low potential gases and liquids to high potential solids, saw it fall, and still remained on his job watching it decompose back again into low potential gases and vapors as it arose, we might have had a complete law of gravitation which would have been a great aid in putting a much-needed foundation under the feet of science during these intervening centuries.
Newton, for example, would have solved the other half of the gravitational problem if he had found out how that apple and the tree upon which it grew got up in the air before the apple fell. I challenge the world of science to correctly and completely answer that question.
https://www.philosophy.org/new-york-times-articles.html
Re: Nature is very simple in her causes
« Reply #1, on June 9th, 2020, 03:56 AM »Last edited on June 9th, 2020, 04:05 AM
Illusions are not limited to perspective but to every electrical, chemical and astronomical relation.
Nature is the supreme deceiver, the champion “poker bluffer,” who, with a simple hand, makes you think she has much. Nature is simple. She has but one force (which she divides into two), one form (which she divides into many), and seven patterns (which she complexes by repeating them in such marvelous systems of wave periodicities that it needs imagination, rather than eyesight, to coordinate them).
The electron is a doubly charged mass. The action of integrating any mass is a generative or condensive one which is called the attraction of gravitation. This causes mass to appear around a common centre of high compression pressure and gives rise to the commonly believed error that matter attracts matter, which is not true to nature. The reaction to this action of compression is the expansion of the field which has been rendered vacuous by thus being drawn upon by the gravitative, in-drawing, endothermic action of condensation. The expansion of the residual volume, or field surrounding the mass, is a vacuity which is as equally minus the original equilibrium of the total volumes as the centre of the mass is plus that equilibrium.
first octave 7eVen lines blue sQuar, second octave purple sQuar
https://www.facebook.com/permalink.php?story_fbid=838989023174490&id=1000119019962
Rainbow 42
https://www.facebook.com/permalink.php?story_fbid=606816749725053&id=100011901996265
« Reply #2, on June 9th, 2020, 04:02 AM »Last edited on June 9th, 2020, 04:05 AM
All charging masses are simultaneously dis-charging and all discharging masses are simultaneously recharging other masses in this two-way universe of motion.... This constant interchange is the cause of the motion of force which moves only for one purpose, and that is to find an equilibrium position for which it is ever in search of and never finds, for that position is itself always in motion.
Our “positive” and “negative” are admittedly meaningless words. Russell’s dual principle gives them a rational and reasonable meaning which may be mechanically comprehensible. He says that “positive” is plus an equilibrium of a quantum of energy, and that “negative” is minus that equilibrium. In other words, a vacuous condition is created in a given quantum of energy by pumping some of it out of one part (the surrounding field) and into the other part (the central mass). How simple it is to understand an electrical short circuit, or a chemical reaction, when thus explained, or to understand the motion of energy as force seeking an equilibrium. I remember when we used to think that the current in a battery flowed only in one direction. We now admit its flow in both directions. If nature expresses itself universally by a flow in both directions, instead of in isolated instances, it is well to know it even though we old-timers have to adjust our practice to it.
Einstein’s theory of relativity did away with the motion of the physical existence of the ether, established originally by the properties which theory required to be given to space, only to replace it in larger measure with other properties... The ether-wave theory of light held sway for over a hundred years. From the time of Clerk Maxwell onward it so satisfactorily accounted for phenomena and had so unexpectedly deduced so many unsuspected relationships in physics that it was regarded as an established fact, a true picture of the universe. Yet today very few of the leading physicists believe in an ether at all.
https://www.youtube.com/watch?v=3woJM2Tsp9Q
« Reply #3, on June 9th, 2020, 05:13 AM »Last edited on June 9th, 2020, 06:14 AM
PUMP
The force represented by that vacuity is an expansion pressure which is the equal and opposite of the gravitative compression pressure and gives rise to that commonly believed error of light repulsion which is not true of nature. The “hole” that Dirac describes is the vacuous force of the expansion stroke of the universal pump. This force is correctly described as negative electricity, negative discharge, radiation, radio-activity or by any other name which results in the dis-appearance of mass into its surrounding tenuous field. On the contrary, the high pressure point of dense mass is the condensive force which is the compression stroke of the universal pump. This force is correctly described as positive electricity, positive charge, gravitation, condensation or by any other name which results in the appearance of mass into solidity. These two opposing actions and reactions constitute the electro-magnetic oscillations, or compression-expansion sequences, which are present in every mass and which constitute the mechanistic or life principle of the universe.
Every mass in the universe is a complete pump oscillating between two equilibrium dead centres of opposed force. Every two masses are reciprocating, collaborating and co-ordinating their respective energies, each in accordance with its respective and comparative potential. Each mass in the universe is revolving around every other mass in elliptical orbits determined by their mutual ever-moving compression and expansion foci.
First of all, the compression-expansion sequence constitutes a cycle of motion which is mechanistic; it conforms with the known oscillating character of all electrical force. It makes matter comprehensible when each mass is known to be a compression-expansion “pump,” or storage battery of polarized force doing the work of the universe. Russell says that every effect of motion gives birth to its opposite effect, that our degenerative, radiant energy which is wasting away our universe becomes generative energy simply through its gravitational change of direction toward mass instead of away from it. The same radiation which degenerates our sun regenerates this planet as light. Let us give him a chance to prove that and see what the outcome is. Our “positive” and “negative” are admittedly meaningless words. Russell’s dual principle gives them a rational and reasonable meaning which may be mechanically comprehensible. He says that “positive” is plus an equilibrium of a quantum of energy, and that “negative” is minus that equilibrium. In other words, a vacuous condition is created in a given quantum of energy by pumping some of it out of one part (the surrounding field) and into the other part (the central mass). How simple it is to understand an electrical short circuit, or a chemical reaction, when thus explained, or to understand the motion of energy as force seeking an equilibrium.
PUMP = HEART
The heart is not a pump. Instead, the heart is a streaming device, and in the left ventricle, the spin of fluid is captured and twirled back on itself. In this way, the heart acts as a brake. The prime reason for this braking is balance. The heart is a balancing organ.
the Magical Heart
http://www.motherworld.net/chestahedron/remarkable.html
https://www.youtube.com/watch?v=6-x1CJnEMks
« Reply #13, on January 27th, 2021, 07:14 AM »
 142424840_1008541779552546_291716607498250376_o.jpg - 100.23 kB, 1080x1080, viewed 127 times.
« Reply #15, on March 11th, 2021, 05:34 AM »Last edited on March 11th, 2021, 05:40 AM
 159224577_1034061633667227_3467805288322373492_o.jpg - 266.06 kB, 892x990, viewed 101 times.
« Reply #16, on March 23rd, 2021, 09:52 AM »Last edited on March 23rd, 2021, 10:06 AM
Photo of the cosmos? Yes, but not the astronomical universe — but in fact the cellular universe!
The most detailed, spectacular and accurate model of a human cell ever made!
This image has been obtained using x-rays, nuclear magnetic resonance, and cryo-electronics microscopy data to perform representation.
The image reveals a cellular landscape cross-section through a eukaryotic cell, by Evan Ingersoll & Gael McGill - Digizyme’s Molecular Maya custom software, Autodesk Maya, and Foundry Modo used to import, model, rig, populate, and render all structural datasets.
In it, you can see even the ATP-synthases of mitochondria.
This is inside just one cell. There exists a literally a Living Universe inside of us!
https://www.facebook.com/lightisconsciousness/posts/2786323938349441
Light is Consciousness
"Symmetry In Chaos"
https://www.facebook.com/groups/SacredGeometry369/permalink/2976491936009995/
@Heather Mac
https://www.facebook.com/permalink.php?story_fbid=1038970459843011&id=100011901996265
https://www.facebook.com/groups/sacredgeo/permalink/10158179711464353/
 161756864_1038970429843014_1033178682145400333_o.jpg - 570.96 kB, 1624x999, viewed 136 times.
 163034869_3731435496978085_6204705109405475658_o.jpg - 234.08 kB, 1024x1024, viewed 96 times.
« Reply #20, on October 6th, 2021, 01:37 AM »
Every atom has its antimatter counterpart not only in form of its nuclei anti-particles but as a whole structure. Some basic universal law is missing specially, the fact that by creation of matter state there is at the same time a creation in antimatter state and the atom is not complete without antimatter state. Because the universal law that rules the law of opposites states, that any opposite pair need a third part or force in order to keep the opposites in balance. That is for negative charge and positive charge as well for black and white and any other opposite pairs. The third neutral part is active and supports balance if imbalance in a system occurs.
https://www.facebook.com/groups/766370360377385/posts/1521995988148148
The first ring is equal to the diameter of the pebble. The second ring is equal to the diameter of the first ring, times the cube root of PI, or 1.3313. The third ring is equal to the second ring, also times 1.3313. Each ring is a NATURAL HARMONIC of the previous ring.
Les Brown and the basic Law Of Nature. Walter Russell Motion.
https://www.youtube.com/watch?v=m4svhQHFnrY
Physics Of Crystals Full Documentary - Les Brown
https://www.youtube.com/watch?v=wM21geOzyj8
 244414724_1164008730672516_271846038583059878_n.jpg - 125.43 kB, 889x1160, viewed 81 times.
« Reply #24, on March 27th, 2023, 06:31 AM »Last edited on March 27th, 2023, 06:34 AM
Abell 1689 is made up of so much matter that it warps light...
https://twitter.com/NASAHubble/status/1617990635130179601/photo/1
NASA's Hubble Space Telescope
If the universe were toroidal, it would have a specific type of topology that could be revealed through certain patterns in the cosmic microwave background radiation (CMB) and large scale structure of the universe.
One way to detect a toroidal universe would be to look for patterns in the CMB known as "circles-in-the-sky." These patterns would be created by the "topological lensing" effect, where the toroidal shape of the universe would bend and distort the CMB in a specific way, creating circular patterns that repeat.
https://www.facebook.com/photo/?fbid=658702376052905&set=a.557823799474097
ORION circle
https://nl.pinterest.com/pin/319826011012051398/
Let There Be Light
https://www.facebook.com/photo/?fbid=1520800391660013&set=pob.100011901996265
How does an atom look like
https://www.facebook.com/photo/?fbid=1489163881490331&set=a.134555690284497
https://www.facebook.com/permalink.php?story_fbid=pfbid02xqe4XAkEHRF96kKa7H49VfpqptgLUN5T2eGfxx3vuJN7epurBfoPzq6P6WY7P3jCl&id=100011901996265
 337854738_1267838523854706_1916218341085427867_n.jpg - 387.53 kB, 1249x1287, viewed 56 times.
 337891066_213219864627706_4646980106942757172_n.jpg - 363.36 kB, 1249x1287, viewed 48 times.
 337520457_156136927371786_8597262266275247052_n.jpg - 442.12 kB, 2023x1089, viewed 63 times.
