Hello all.
I've replicated Patrick Kelly's South African inventor's 'Tiny Generator', from his post last month.
I've put it all together, 3d printed parts and the rotor etc, but I'm struggling to get it to operate as advertised.
Likely my electronics and connections are at fault as I'm a newcomer to the practical side.
Contrary to the instructions, the magnets need to be placed in the rotor SOUTH facing out for the hall sensor to work, but I had a voyage of discovery of all the other mistakes I'd made along the way trying to get it to work, but got there in the end.
Problem is I attached the oscilloscope and I can't get the system to pulse the back emf as expected. In the beginning I left it running for a couple of hours, but found that the battery voltage dropped very slowly rather than increased, which suggested it wasn't charging. I had three 12v 7Ah attached, two running in parallel with the charging battery.
I attached a second coil out of curiosity and burned up the mosfet and the +i've line on the board.
Fixed that, then used a different single coil (close to spec but taken from a speaker and professionally wound) and the negative line fried, and mosfet again.
Now, I wound a new coil carefully to original spec, no flaws or overlapping, and I've replaced the mosfet but find it runs very hot within ~30 secs operating, so I switch it off.
I'm still researching and reading up to find the error of my ways.
If anyone has any suggestions I'd appreciate it.
I've attached a video of it's operation so it may help troubleshoot. Starting V ~12.6, I~0.212A.
Cheers,
Ian.
Cheers,
Ian.
