I have an idea for the Z axis. Have a separate piece of aluminum that the stepper motor mounts to, with rods mount this to the side of the top aluminum block of the Z axis, [bore holes to fit rods in both pieces], make the stepper motor aluminum block slide on the rods to adjust belt tension. What do you think?:D
Question to all of you out there.
Thanks Jeff. I like that idea. I'll see if that will fit. I may need to get a longer belt for that though cause the pulleys are 3.5" apart with a 13" belt.Quote from Jeff Nading on December 16th, 2012, 12:20 PM I have an idea for the Z axis. Have a separate piece of aluminum that the stepper motor mounts to, with rods mount this to the side of the top aluminum block of the Z axis, [bore holes to fit rods in both pieces], make the stepper motor aluminum block slide on the rods to adjust belt tension. What do you think?:D
I would like to know how many of you have built the reprap 3d printer. If you have or if you are in some stage of the build, or if you are thinking of building one, please post and share your builds and thoughts, thanks, Jeff.
Ravenous Emu
RE: Question to all of you out there.
« Reply #28, on June 11th, 2013, 11:57 AM »Last edited on June 11th, 2013, 12:09 PM by Ravenous Emu
Hey Jeff,
Just ran across this... Might want to download and print out the parts.
:D :cool: :P
http://grabcad.com/library/cnc-3-axis
This one looked good to. :D :cool: :P.
http://grabcad.com/library/diy-cnc--1/files
:D :cool: :P
« Reply #29, on October 13th, 2013, 06:54 AM »Last edited on October 13th, 2013, 07:03 AM by Jeff Nading
It sits upon my dining table broken heartedly due to repeated power supply attempt failures.. HOWEVER! I just obtained a decommissioned Dell pe2850 with dual 1000W PSUs.. tonight the mad science..shall be delayed 2 days.. darn parental duties... :sQuote from Jeff Nading on February 7th, 2012, 05:44 PM I would like to know how many of you have built the reprap 3d printer. If you have or if you are in some stage of the build, or if you are thinking of building one, please post and share your builds and thoughts, thanks, Jeff.
Hey Jeff,
:D :cool: :P
