Built holder for boards from 2 shelf boards as laying them out on table was taking to much room. Wiring was mostly to route power to each board. I left enough slack in wires so I could pull each board out to check it with a scope. I was glad I did as I start to do system tests to see if everything was still working, I found I had moved pot settings and needed to reset them to match setting from my initial testing. The scope shots in my test reports were very helpful in doing this.
Hopefully with this setup I can just connect the coils to connection strip on the end and continue testing. One thing I do not like is the 2n3055 mounted on the leg make that whole leg to be at +12 DC. I need to do something about that. I am still working though checking things, but I did find another issue I though I would report. I started on the analog side and was working my way though resetting the pots and I am getting the results I expected after making the necessary adjustments until I got to the finally output to the primary coil. Instead of the analog wave train I expect I kept getting a flatline voltage. This is from the 2N3005 (Q4 in K9 the Voltage Amplitude Control circuit).
I retraced the signal through the circuit, and everything matched until I got the final output instead of analog wave train, I got a flatline voltage. In my initial testing I did not have the output from the emitter of the 2n3005 connected to the switch and the last 1uF capacitor. The capacitor is the cause of the flatline. Remove it and system works. With it in you can still move the voltage level up and down but AM wave is gone. It does not make sense to have gone to all the work of creating the AM signal then remove it before sending it to primary coil.
It is possible this capacitor was intended to smooth out the noise on the AM wave as it has a lot of noise, however if this is the intended purpose 1uF is the wrong value. However, if you want to smooth out noise on a 12-volt source then it would do that.
I am continuing to check the other boards that feed the 5KHZ side and have started to gather some of the material I need to make coils. Looks like a should find the ferrite core first so I know what size and shape to make coils and bobbins. I know the dimensions for the areas for the wire but need to know size of hole inside bobbins.
Pictures below. Front and back of finished boards mounted power comes in on left through a 12-volt connecter and there 2 LM317s one for 10v and on for 5v that feed bus bars on back. Common ground through out system. Boards powered from the bus bars. Bus bar on the right will connect to primary and feedback coils.
The scope shots show the output of the 2n3005 with the one with capacitor in circuit and one with it removed. This is the signal going to one side of primary coil. The yellow trace is the 50Hz signal input used to create AM wave. I have it on screen to provide a good sync for the scope.
