8XA 9XB 9XA DUAL VARIAC BOX DESIGNS
« on October 14th, 2019, 11:39 AM »Last edited on November 24th, 2020, 09:43 PM
Documenting the methods can be applied to main circuits
open to discussion
Thank you Mr Valentin Petkov /valyonpz
warj1990
Re: 8XA 9XB 9XA DUAL VARIAC DESIGNS
« Reply #1, on October 21st, 2019, 07:21 AM »Last edited on October 21st, 2019, 08:04 AM
I like the use of the 566 and TL081 for frequency and duty cycle.  Simple design and functions.
I personally think the right portion needs corrected.
The "Gas Rate Control" will be shorted to ground during pulsing with the IRFP460.
While I'm not sure who has seen the inside of the box, I will post this as my understanding of the system.
Resonant Action control is "Va" and is always held constant "on" with variable amplitude from the “Resonant Amplitude” control knob (variac).
Gas Rate control would be “Vb, Vc, ….Vn” (variac).
I’m including a high resolution photo and adding my opinion on the controls:
CP = Constant Pulse
GP = Gated Pulse
SP = Single Pulse
PF1 = Pulse Frequency 1
PF2 = Pulse Frequency 2
Whatever the frequency was – it wasn’t controlled in this unit,  only the x,2x,3x,4x (Low and High).  No base frequency adjustments seen.
HGG = Hydrogen Gas Gun
W.
warj1990
« Reply #2, on October 21st, 2019, 08:06 AM »
Possible "Seq." from CS3....
Variable Duty for resonant action photo.
Patent CA1234773A
warj1990
« Reply #3, on October 21st, 2019, 08:10 AM »
Second control from left:
Cavity Array: Light.
I think it was built for testing this cell pictured.  Notice the LED Array with the cell.
« Reply #4, on October 21st, 2019, 12:17 PM »Last edited on October 21st, 2019, 12:55 PM
Quote from warj1990 on October 21st, 2019, 07:21 AM
CP = Constant Pulse
GP = Gated Pulse
SP = Single Pulse
W.
cool thanks for input  very nice to read,
it lookw like there is  7 x 9xa / 9xb cards int here
warj1990
« Reply #6, on October 21st, 2019, 01:05 PM »
Good work.
I'm glad you posted this.
I was thinking "L" and "H" was a switch with two positions. (which is wrong)
I now realize it is a variable resistor for frequency generator.
W.
« Reply #7, on October 21st, 2019, 07:43 PM »Last edited on October 21st, 2019, 07:45 PM
i added this one   i found the old back pic again
If you could have a go as diagram based on multiple 8xa  it would be cool to see
I put the Petkov one at start of thread showing the  variacs  we can add more 8XA's and Volts x1 yo 4 cards
 to that drawing if you have ability to do so
GOD SPEED
« Reply #8, on October 21st, 2019, 07:47 PM »
the cell can be used as power storage or capcitors in the circuit even where
the flat plate is show we can have round cells as caps having voltage at the ready
Re: 8XA 9XB 9XA DUAL VARIAC BOX DESIGNS
« Reply #11, on November 24th, 2020, 09:44 PM »Last edited on November 24th, 2020, 09:58 PM
#8XA #9XB #9XA #DUAL #VARIAC #BOX #DESIGNS #Stanley #Meyer
