Stanley Meyer Guessing Games
« on August 23rd, 2019, 10:30 PM »
Hello
I invite every one to help guess phrases from Stanley Meyers hand writings  the missing word correctly
attached
warj1990
Re: Stanley Meyer Guessing Games
« Reply #4, on August 26th, 2019, 12:52 PM »Last edited on August 26th, 2019, 01:40 PM
Final:
" Note:
This drawing is the sole property of
Stanley A. Meyer  All concepts and design
Here within shall not be ???? from this
Drawing without the written consent of
Stanley A Meyer.
All technical data furnished by
Stanley A Meyer must be returned upon
Request and shall not be reproduced
W.
Belfior
« Reply #6, on August 30th, 2019, 10:04 AM »
Hmm in the image, isn't he grounding all the positive output from the full bridge rectifiers?
warj1990
« Reply #11, on September 4th, 2019, 02:31 PM »Last edited on September 4th, 2019, 02:34 PM
While the drawing does appear to show an Isolation transformer for each one...they are usually 1:1 ratio.
We also know a variac is not an isolation transformer...
Looking at the waveform to the right of T1 it shows a positive pulse wave...
I think the diodes are just drawn backwards...
While it could work with one transformer, I don't think it would work with two the way it is shown... IC9 would also have to be a negative voltage regulator, which I don't believe it is.
If you look at D7... all the circuit becomes useless when SW1 is in the UP position.
Between D7 and DB nothing would work.
So I'm fully convinced in this drawing the diodes are simply shown incorrectly.
Good catch Belfior.
W.
Belfior
« Reply #13, on September 5th, 2019, 10:10 AM »
Quote from warj1990 on September 4th, 2019, 02:31 PM
Good catch Belfior.
W.
Well I think this happens very easily if one uses off the shelf PSUs and they draw them out in their own circuits or just an easy mistake to make
