https://m.youtube.com/watch?v=W-9PdVLU6zw
Just explaining my research on one aspect of the VIC.
One problem we've all had is getting voltage to our cells. If you build a VIC to match Stan's you have to gap the core, just like Stan did.
The problem is once you gap the core you introduce a high leakage inductance to the VIC which causes it to have very poor voltage regulation.
So, when you connect the VIC to your cells and pulse the primary coil with 7.8V like I did your voltage across the cell should be 52V (because of the step up transformer) but instead you get 2V across it. This is because of the poor voltage regulation of the VIC.
So what does it mean?
As my measurements show it takes a load impedance greater than 1M ohm to get the full 52V across it when pulsed at 10kHz.
The chokes are not large enough to produce even 100k Ohms impedance at 10kHz.
The high impedance is required to begin to see any appreciable voltage across the cell so where does that impedance come from?
Ronnie stated several years ago you have to get current flowing through the cells first. Once you do you'll begin to produce basic electrolysis.
The gas bubbles produced by electrolysis, many of which stick to the electrodes from tension and electric field forces actually reduce the surface area of the electrodes.
In a previous video I showed that if you reduce electrode surface area by 1/2 while maintaining the same gap the resistance between the electrodes will double.
So, as the gas bubbles form on the electrodes the surface area is reduced which increases the resistance between the electrodes.
As this begins to occur the voltage of the cells starts to increase. Then and only then can you tune into resonance and get the voltages in the kV range.
More to come...
More to come...
