Does electricity really exist ?
Keep in mind I’m JUST asking the question does electricity really exist or is it all JUST magnetism?
1. My first reason is if electricity is real then why can we not take (plus + voltage) from (battery A) and the (minus – voltage) of (battery B) to run something or register on a voltmeter ?
2. The quarks in a proton has (+2/3) and (–1/3) charge and this causes (+1/3) and (–1/3) to cancel each other leaving a net charge of (+1/3). The quarks in a neutron has (-2/3) and (+1/3) charge and this causes (+1/3) and (–1/3) to cancel each other leaving net charge of (-1/3). So in the nucleus protons and neutrons can sit side by side because of attraction.
3. The (- charge) of the electron is attracted to the nucleus because of the (+) proton but is stopped from crashing into the nucleus because of the (- charge) of the neutron.
4. Now replace the (+) and (-) charge with (north) and (south) poles of magnetism this seems a better fit then using electric charge.
5. Consider a voltmeter it is not really measuring electricity it is measuring magnetism. https://en.wikipedia.org/wiki/Voltmeter
6. Place a compass on an AA battery and the N and S line up with plus and minus of the battery. Proving a battery contains magnetism.
7. Place a compass on long single wire and touch ends to a battery, compass is deflected. So is electricity flowing in the wire or is magnetism ?
8. Take a large coil of wire and pass a magnet in the center. It is magnetism that is transferred to the coil not electricity. Should we believe the copper wire contains an endless supply of (+ & -) electricity ?
9. The best I can think of electricity it is the movement of magnetism.
10. We can take the north of a magnet and south of a (different) magnet to create electricity but as stated in (# 1 above) we can not take (+) and (-) from two (different) batteries to do anything.
That should be enough to get the conversation started on electricity and magnetism! Please feel free to add any thoughts. And yes I know it is called Electromagnetism :)
