The attached document is the result of analyzing the circuit for this card. It is another step in my understand of how the electronic works and what it actually does. Like the one I did for main frequency generator card it lists all the inputs and outputs and shows what the card does to them. I am doing this as Ronnie mentioned he did not understand how system worked until we looked at all the modules in detail.
The card has one main function it sets the pulse width for all the frequencies signals coming from the Main Frequency Generator and those on the Accel input (the gate function) and allows the width to be manually controlled from pot on front panel. The circuit sets a minimum width that cannot changed. Stan has stated changing pulse width effect rate of gas production.
It does provide switch to turned off cell and provides input to allow other modules to do this.
As far as I can tell it does provide the GATE (no signal space) seen it the VIC signal. I thought given the name of the card it was added here but it is not. I think gate here was meant to set size of opening (pulse width) like a gate in fence.
NOTE: If you plan on building these cards you need the front panel controls.
