Hi Buddy, - Thankyou, this circuit is working really well for me now, i have made up 3of them on a single board for use with a few projects that require really fast switching.... - - the rise and fall time is really fast on this circuit diagram simple due too the fact that - the photoisolaters are designed too be pinned too the power rails with 2-3k resistance, (in the datasheet). which delivers a 8v signal, - however in the datasheet, that also recommend a 100ohm biasing resistor, which my circuit is based on. - ... similar too the new signal generator i received from ali express today, the rise and full times look like the learning tower of piza, - ,,,
but mine is super fast, - basically because it is burning lots of waste energy too tighten up the signal. . .. i really like doing this - it was not part of my teachings when i studied electronics, and i never see it done in practice, - but im convinced its an important ascect of free energy, - because the efficiency of the spikes is directly related too the fall time, -
also please add "10volt zener" too the diode . - as this is used too bring down a large positive bias , that the opto isolater is not able too,
thanks for this draw up by the way, - its critical infrastructure, even though my will likely require a little ground balancing untill the 12v regulator is accurate.
