I though I'd start a new thread for this one. I did a little searching and found a lot of research on "Spin Polarizing Particles" like Argon, Helium, and Neon using laser optical pumping. A lot of the language is way too scientific for me, but I think I can read between the lines a little.
I found this thesis pdf from 1984 testing lasers for polarizing gases:
http://scholarship.rice.edu/handle/1911/15899
I haven't read the whole thing, most of it gives me a head ache.:P
What I find interesting is a lot of similarities with Stan's ideas. Other research I've seen they use laser optical pumping combined with a magnetic field. Except they use a real laser saying that circular polarized light is necessary. The magnetic field is aligned in the same linear direction as the pumping laser. They also talk about polarized gasses that lasts for hours, as a long time. We know Stan said permanent, specifically many times. What is missing from the Optical Pumping is Stans electron extraction circuit. I'm starting to wonder, based on the new Zealand video where he shows the argon and iron lattice, that maybe it is the argon gas that is magnetically polarized, and the iron is neutral. Using the electron extraction to take off enough electrons to allow argon to bond with iron, the iron would align with it on its own. Since it is a molecular bond, it is now permanently magnetized. With iron in the lattice, you wouldn't have to worry about repulsion of two like poles as much either. Kind of like how two north poles of neo magnets won't stick together, but if you put a piece of non magnetized steel between them, they will.
So my bets on the key to magnetized gas are the electron extraction circuit. But I've been wrong before. lol:) Maybe someone else can understand the thesis better than I can.
