I got some relays but I think I might ask you guys before I start to bring out the blue smoke.
Now if I want to have a self looped device, I would like to start it with a 9V battery like all self respecting kapanadze replicators do.
So lets say I have a power supply for the circuit, 9-16V cap feeding that power supply, a relay and the self looped circuit on the far right.
some circuit - PSU - 9-16V cap - self latching relay system - the "some circuit" looping back with the energy to feed my PSU.
Now the PSU is there just to supply even voltage, but takes 0-16V DC in. The circuit looping back might have voltages even over 50V DC. Now how do I build the "latching relay" that it takes 9V battery until output comes back from the self looped system?
If my "free energy system" is using one or more grounds I might not be able to even use ground in this latching setup, so how do I prepare for the possible 50V "over voltage" that might be heading back from the self looping? Is a Zener diode setup enough? If I can't use ground for the over voltage, do I just redirect the excess to an antenna?
