cell core
stl print
Resonant Cavity Machining Template STLs_5-22-2024
Saved from Stans Legacy Thank you Stan Meyer and All who help replicate and Copy Stans Work
Please be aware that new templates will be added when DIY machining techniques are tested. Check regularly until this banner is removed - indicating the below listed have been finalized and tested.
We understand that the machining of fluted inner electrodes for the Water Resonant Cavity, Gas Resonant Cavity and inner electrode for Gas Processor, etc. are cost prohibitive to many people. Current prices here in the USA for 1 - 4 inch fluted water resonant cavity was $50/each. Inspired to give fellow Stan Meyer researchers more economic options/methods, the below templates can be 3D printed and used for DIY machining. Main tools needed will be:
1.) Creality 3D printer, which you'll need to do other things related to Stan Meyer
2.) A Dremel rotary tool - with metal cutting wheel
3.) A bench vise
4.) A 1/2" chuck cordless drill
4inch Water Fuel Cell Resonant Cavity Inner Electrode Machining Template:
Water 4in Resonant Cavity Inner Electrode Template.stl
