Differential Solenoids Meter MIXING
« on January 13th, 2019, 08:38 PM »
Stanley Meyer had Differential Solenoids that had 3 wires going to each solenoid.
Stepper Motor
Do you think they were forward and reverse motors like showcased in this video?
Picture of the 3 Differential Solenoids and I only see 2 wires to each.
What do you see? There should be 3 wires.
Maybe he just used a forward and reverse switch ...
 this show two wires yellow and blue to motor which can be polarity reversed.
I used a similar setup to control a throttle on Potato Harvester Diesel Engine.
And here I see 3 terminals for each differential solenoid
Chattering Solenoids for what purpose. Air Gate? EGR? Ionized Air? Mixing Valve
 Controller? They don't look like forward and reverse stepper motor controls?
A4988 Stepper Motor Driver Carrier
https://www.google.com/search?safe=active&tbm=isch&sa=1&ei=GFM5XLzMF86c_Qaw8ouwDQ&q=A4988+microstepping+IC+for+h+bridge&oq=A4988+microstepping+IC+for+h+bridge&gs_l=img.3...52361.61157..64085...0.0..0.110.1535.17j1......1....1..gws-wiz-img.r_9wC4Qvo2M#imgrc=_
http://floraoflangkawi.org/servo-motor-wiring-diagram/servo-motor-wiring-diagram-anonymerfo-of-servo-wiring-diagram-at-servo-motor-wiring-diagram/
Pumps
https://l.facebook.com/l.php?u=https%3A%2F%2Fwww.google.com%2Fsearch%3Fq%3DPeristaltic%2520pump%2520with%2520arduino%2520controller%26safe%3Dactive%26source%3Dlnms%26tbm%3Disch%26sa%3DX%26ved%3D0ahUKEwjmieiRiujfAhUKTt8KHegDCRsQ_AUIDigB%26biw%3D1067%26bih%3D473%26fbclid%3DIwAR27mZzopgb7e5hE_gLJXjYKCsSFW4ZDjOL5gUegQPQbkWeNqbXj1lWsRdg&h=AT0tye-HPT_lWNDeB8x25xe8CoGlGjtrXAVfUBKKDfGr7K2ZBBZWNVc0-x1tOWUVSdH49jJWtppMTnEYe0Cpyds3XhMDoM8YbNQGRDVwNmoeI2T8TCx0pnZoqnnx1ScfOw
https://l.facebook.com/l.php?u=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Ftime_continue%3D231%26v%3DZIQKf98cAMk%26fbclid%3DIwAR0_qRJdx-BUYmiqALDcBCKuJ8-SqWrcr1tx3dQ6gliKILrTfsoph1p-Zhk&h=AT0fblLecKmdzAn_sLS6HLs6966aCyuupDPv95JvspaTAcY0vjOWijpWhr6ZJnRdHSv6xPdGaoL1nvvzLWKEXGJLmTMBakgX7oQJRUTiNhXD2wt4NWyA7rH36iOOXq00SQ
https://centralvalleyhho.com/
So mixing chamber is combination of several pumps with electric valves.....
DIY peristaltic pump http://blogs.rsc.org/chi.../2015/06/26/diy-peristaltic-pump/
parsitic pumps and stepper  motor  valves
Looks like if we learn arduino we can make a good mixing valve?
that is only way to precise mix fluids
https://l.facebook.com/l.php?u=https%3A%2F%2Fwww.google.com%2Fsearch%3Fq%3Darduino%2520controlled%2520servo%2520motor%2520with%2520a%2520pintle%2520valve%26safe%3Dactive%26tbm%3Disch%26source%3Diu%26ictx%3D1%26fir%3Dl_ZhkJ6nIdlIGM%25253A%25252CFa3RQ_A10JTlTM%25252C_%26usg%3DAI4_-kTrBM8BnJdQiTBDr5CSUghZsEAhXg%26sa%3DX%26ved%3D2ahUKEwjYwP2TjujfAhUmm-AKHcihD40Q9QEwEnoECAMQBA%26fbclid%3DIwAR1NfSkq2rq65VjjsPomrCvKHOn4Xf0Py5FPnQuQG2QzKb5ur6eQpWdcS9A%23imgrc%3Dl_ZhkJ6nIdlIGM&h=AT3Vaq85HrAIDG6RDIfiBUzOxIw_fcjYvK535ftUXHd5D60yoVBs4CWwd-VBv_ylN03QidFTjLMBwIEIydOsuD4J_1BpM7OIAPSrQ-7kjDjwP0W951kaL2UjbKxfneYH5g
These venturi bubble thing is not for precise mixing what we need....
 In the patent Stan sey obitenig simuntesly those three fluids is imbortant to acive rection..
125 psi
yes you are correct for that pressure but they can be variable speed to feed to another 125psi pump?
125 psi cut out sensor
https://l.facebook.com/l.php?u=https%3A%2F%2Fwww.google.com%2Fsearch%3Fq%3D125psi%2520cut%2520out%2520sensor%26safe%3Dactive%26tbm%3Disch%26tbo%3Du%26source%3Duniv%26sa%3DX%26ved%3D2ahUKEwi_yqfekejfAhVCTt8KHdRVBVwQsAR6BAgAEAE%26biw%3D1067%26bih%3D473%26fbclid%3DIwAR0lBLLnGUytTQw-fkqIy4kUfRtD6j4sM7eT7I9lrGhdWPtnwrZio7GmRvg&h=AT2UX8pN0aivr-yGAb8Rdc-iFdoXyu3Xq6vqSA6MRndaLY3hpzERLV80LtYmcyWw7ZkE0JujicRkwNKvV7LULfJGCPltWVHr0fXZhW-tHcfEXk2gRGOGuZPuHaZNbFhPfA
Mixer? https://www.youtube.com/watch?v=8f3Vj6U9aKw
Re: Differential Solenoids Meter MIXING
« Reply #2, on January 13th, 2019, 09:35 PM »
any one up for the challenge
to draw a circuit that with will turn on power to water injection system waiting trigger at rpm or pedal tps position (on/off)
and when key turned off / or vacuum trigger switch off on engine will reverse pump
water and empty lines back to water tank and than stop.
patrick1
« Reply #3, on January 14th, 2019, 11:09 PM »
Wow amazing,   im using garden valves from my sprinkler system.  and a 12v fuel pump for the petrol...
Oh and in relation too the circuit.  i use op amps, and decade counters for everything, - and a 555 if i can squeeze it in,  - = but should be possible judging by the description. ;-)
« Reply #4, on January 15th, 2019, 07:22 AM »
Note:
Distilled water, you can boost it by making h & o nano bubble saturated water
make it hit dry fog in intake keep all surface positive to remove electrons
Enjoy the benefits
( cold positive charged )water holds more gas)
« Reply #5, on January 15th, 2019, 07:33 AM »Last edited on January 15th, 2019, 08:04 AM
Quote from patrick1 on January 14th, 2019, 11:09 PM
Hi Patrick sounds good Dan
