The alchemists of old tried to use chemistry to cause nuclear transmutation, mixing various substances together in the hopes of creating something more valuable. It was the beginnings of modern chemistry... obviously, either none were successful (or we'd have heard about it), or they were successful and were secretive about their knowledge.
Nowadays we know that nuclear transmutation goes on all around us every day.
For example, in our sun, the proton-proton reaction causes 2 1H atoms to transmute into deuterium (2H), which combines with another 1H to create 3He. Then 2 3He atoms combine to create 2He and 2 1H atoms. So net, 6 1H atoms create one 2He atom and 2 1H atoms and give off 4.14 x 10-12 Joules of energy, at a rate of ~9.29 x1037 reactions per second.
For another example, when a cosmic ray in the form of a neutron enters our atmosphere, it hits the 14N in the atmosphere, transmuting it into 1 14C and 1 1H. Then each 14C atom combines with 2 8O atoms to create 14CO2.
Many of the transmutation processes are complicated, so knowledge of nuclear physics is necessary to figure out what elements will interact and at what energy levels... at least, it used to be that way. Dr. Alexander Parkhomov created a spreadsheet. The download page is now showing 404, but I was able to grab the spreadsheet before then. It's attached below.
Dr. Alexander Parkhomov's fusion / fission nucleon exchange table (in OpenOffice .xlsx format, zipped with 7-Zip) - 71715 KB unzipped, 33716.26 KB zipped
Now there's a database created by Phillip Powers. You can query any element as to whether it can transmute into any other element.
The main energetically favourable nucleon exchange table from Dr. Alexander Parkhomov's Fusion Fission spreadsheet table in database form
Want to find two products that are easily separated after transmutation?
Query the database like this: E3 = 'Xe' and E4 = 'Pt' order by MeV DESC
Want to transmute lead (82Pb) into platinum (78Pt)?
Query the database like this: E2 = 'Pb' and E4 = 'Pt' order by MeV DESC
And you'll get the following:
Code: [Select]
So there are a great number of elements which will successfully interact with lead to transmute into platinum.
Some interesting ones (picked based upon the easy availability of the elements, and the ease with which they can be separated after processing):
Code: [Select]
Now the only thing left to do is to figure out the procedure by which to most efficiently transmute any given element into any other given element... usually it's done via electrical discharge, but other methods might increase yield (by combining any of pressure, temperature or bombardment with protons, neutrons or electrons)
To produce electrons is easy enough... it's just electrical current.
To produce protons, use a device similar to the Cockroft / Walton device:
To produce neutrons takes a bit more work because you have to overcome the strong fundamental force... first you have to strip the electrons from 2He, leaving only the nucleus (two protons, two neutrons). This is done by hitting the 2He atom with sufficiently strong light to ionize it. Then hit the nucleus with strong x-ray energy to break apart the protons and neutrons, then attract away the protons with a DC-biased plate, leaving only the neutrons.
Or, you can create deuterium by electrolyzing water to remove the light water, leaving only the heavy water (deuterium), then adding more water and electrolyzing again, etc., etc... eventually you'll build up a large quantity of deuterium (this is the way the Nazis did it at the Vemork plant in Norway, before the Allies destroyed it).
Or keep the water at an exact temperature to evaporate the light water away (D2O boils at 101.4 C, whereas H2O boils at 99.97 C at atmospheric pressure... you can increase the evaporation rate by drawing a vacuum and running a lower temperature to save energy).
Or do both... first electrolyze, then evaporate. In normal water, there is only one deuterium atom for every 6400 hydrogen atoms, but deuterium is more prevalent in the residue of water used as an electrolyte. An analysis of the residues from the Vemork hydroelectric plant, a large-scale hydrogen production plant using electrolysis of water for ammonia production, showed a hydrogen/deuterium ratio of 48. So electrolyzing the water increases the hydrogen/deuterium ratio by 33.33 times, leaving less water to be evaporated later to further concentrate the heavy water.
Deuterium contains one proton and one neutron, so you can then use the above techniques to strip the protons away, leaving only the neutrons. Free neutrons have a half-life of ~14 minutes 42 seconds, so you need to continually produce them, Their decay involves the emission of a W− boson from one of the down quarks within the neutron, converting the down quark into an up quark and the neutron into a proton; the W− then decays into an electron and an electron antineutrino.
id E1 Z1 A1 E2 Z2 A2 E3 Z3 A3 E4 Z4 A4 MeV
146806 Ca 20 40 Pb 82 208 Cr 24 54 Pt 78 194 34.9720
146313 Ca 20 40 Pb 82 204 Cr 24 54 Pt 78 190 34.3060
146582 Ca 20 40 Pb 82 206 Cr 24 54 Pt 78 192 34.2101
113755 Ar 18 36 Pb 82 208 Ti 22 50 Pt 78 194 34.0852
113455 Ar 18 36 Pb 82 204 Ti 22 50 Pt 78 190 33.4192
113626 Ar 18 36 Pb 82 206 Ti 22 50 Pt 78 192 33.3233
146724 Ca 20 40 Pb 82 207 Cr 24 53 Pt 78 194 32.6265
92384 S 16 32 Pb 82 208 Ca 20 48 Pt 78 192 32.5324
92284 S 16 32 Pb 82 206 Ca 20 48 Pt 78 190 31.8636
146805 Ca 20 40 Pb 82 208 Cr 24 53 Pt 78 195 31.4491
146804 Ca 20 40 Pb 82 208 Cr 24 52 Pt 78 196 31.4267
146312 Ca 20 40 Pb 82 204 Cr 24 52 Pt 78 192 31.4044
146581 Ca 20 40 Pb 82 206 Cr 24 52 Pt 78 194 31.4016
92358 S 16 33 Pb 82 207 Ca 20 48 Pt 78 192 31.2665
146723 Ca 20 40 Pb 82 207 Cr 24 52 Pt 78 195 30.8818
113715 Ar 18 36 Pb 82 207 Ti 22 49 Pt 78 194 30.5241
92383 S 16 32 Pb 82 208 Ca 20 46 Pt 78 194 30.0118
191166 Cr 24 50 Pb 82 208 Ni 28 64 Pt 78 194 29.7389
113754 Ar 18 36 Pb 82 208 Ti 22 49 Pt 78 195 29.3467
92140 S 16 32 Pb 82 204 Ca 20 46 Pt 78 190 29.3458
146843 Ca 20 42 Pb 82 208 Cr 24 54 Pt 78 196 29.2601
92282 S 16 32 Pb 82 206 Ca 20 46 Pt 78 192 29.2498
123976 K 19 39 Pb 82 208 V 23 51 Pt 78 196 29.2480
146385 Ca 20 42 Pb 82 204 Cr 24 54 Pt 78 192 29.2377
146644 Ca 20 42 Pb 82 206 Cr 24 54 Pt 78 194 29.2349
123780 K 19 39 Pb 82 204 V 23 51 Pt 78 192 29.2256
123910 K 19 39 Pb 82 206 V 23 51 Pt 78 194 29.2228
113753 Ar 18 36 Pb 82 208 Ti 22 48 Pt 78 196 29.1213
113454 Ar 18 36 Pb 82 204 Ti 22 48 Pt 78 192 29.0989
113625 Ar 18 36 Pb 82 206 Ti 22 48 Pt 78 194 29.0961
190701 Cr 24 50 Pb 82 204 Ni 28 64 Pt 78 190 29.0729
190950 Cr 24 50 Pb 82 206 Ni 28 64 Pt 78 192 28.9769
169752 Ti 22 46 Pb 82 208 Fe 26 58 Pt 78 196 28.8987
169302 Ti 22 46 Pb 82 204 Fe 26 58 Pt 78 192 28.8763
169542 Ti 22 46 Pb 82 206 Fe 26 58 Pt 78 194 28.8735
123962 K 19 40 Pb 82 207 V 23 51 Pt 78 196 28.8269
92357 S 16 33 Pb 82 207 Ca 20 46 Pt 78 194 28.7459
146757 Ca 20 42 Pb 82 207 Cr 24 54 Pt 78 195 28.7152
146774 Ca 20 43 Pb 82 207 Cr 24 54 Pt 78 196 28.7068
123954 K 19 39 Pb 82 207 V 23 51 Pt 78 195 28.7031
113714 Ar 18 36 Pb 82 207 Ti 22 48 Pt 78 195 28.5764
235622 Ni 28 58 Pb 82 208 Ge 32 76 Pt 78 190 28.5745
303652 Se 34 74 Pb 82 208 Sr 38 88 Pt 78 194 28.5727
169667 Ti 22 46 Pb 82 207 Fe 26 58 Pt 78 195 28.3537
303010 Se 34 74 Pb 82 204 Sr 38 88 Pt 78 190 27.9066
303325 Se 34 74 Pb 82 206 Sr 38 88 Pt 78 192 27.8107
123936 K 19 40 Pb 82 206 V 23 51 Pt 78 195 27.6244
327111 Kr 36 78 Pb 82 208 Zr 40 92 Pt 78 194 27.5834
113783 Ar 18 38 Pb 82 208 Ti 22 50 Pt 78 196 27.5704
92399 S 16 33 Pb 82 208 Ca 20 46 Pt 78 195 27.5685
113524 Ar 18 38 Pb 82 204 Ti 22 50 Pt 78 192 27.5480
113673 Ar 18 38 Pb 82 206 Ti 22 50 Pt 78 194 27.5452
146677 Ca 20 43 Pb 82 206 Cr 24 54 Pt 78 195 27.5042
211527 Fe 26 54 Pb 82 208 Zn 30 70 Pt 78 192 27.4670
327113 Kr 36 78 Pb 82 208 Zr 40 94 Pt 78 192 27.4250
235619 Ni 28 58 Pb 82 208 Ge 32 74 Pt 78 192 27.3915
169695 Ti 22 47 Pb 82 207 Fe 26 58 Pt 78 196 27.3887
191165 Cr 24 50 Pb 82 208 Ni 28 62 Pt 78 196 27.3571
190699 Cr 24 50 Pb 82 204 Ni 28 62 Pt 78 192 27.3347
190948 Cr 24 50 Pb 82 206 Ni 28 62 Pt 78 194 27.3319
92406 S 16 34 Pb 82 208 Ca 20 48 Pt 78 194 27.3263
113736 Ar 18 38 Pb 82 207 Ti 22 50 Pt 78 195 27.0254
283486 Ge 32 70 Pb 82 208 Kr 36 86 Pt 78 192 26.9891
45798 Ne 10 20 Pb 82 204 Si 14 30 Pt 78 194 26.9574
326388 Kr 36 78 Pb 82 204 Zr 40 92 Pt 78 190 26.9174
146756 Ca 20 42 Pb 82 207 Cr 24 53 Pt 78 196 26.9146
327115 Kr 36 78 Pb 82 208 Zr 40 96 Pt 78 190 26.8848
326745 Kr 36 78 Pb 82 206 Zr 40 92 Pt 78 192 26.8214
191087 Cr 24 50 Pb 82 207 Ni 28 62 Pt 78 195 26.8121
211240 Fe 26 54 Pb 82 206 Zn 30 70 Pt 78 190 26.7982
326748 Kr 36 78 Pb 82 206 Zr 40 94 Pt 78 190 26.7562
235251 Ni 28 58 Pb 82 206 Ge 32 74 Pt 78 190 26.7227
92226 S 16 34 Pb 82 204 Ca 20 48 Pt 78 190 26.6603
211525 Fe 26 54 Pb 82 208 Zn 30 68 Pt 78 194 26.6314
92327 S 16 34 Pb 82 206 Ca 20 48 Pt 78 192 26.5643
45879 Ne 10 21 Pb 82 207 Si 14 30 Pt 78 198 26.5066
146442 Ca 20 43 Pb 82 204 Cr 24 53 Pt 78 194 26.4433
146384 Ca 20 42 Pb 82 204 Cr 24 52 Pt 78 194 26.4293
45824 Ne 10 21 Pb 82 204 Si 14 30 Pt 78 195 26.3957
283236 Ge 32 70 Pb 82 206 Kr 36 86 Pt 78 190 26.3203
92382 S 16 32 Pb 82 208 Ca 20 44 Pt 78 196 26.3119
92138 S 16 32 Pb 82 204 Ca 20 44 Pt 78 192 26.2896
92280 S 16 32 Pb 82 206 Ca 20 44 Pt 78 194 26.2868
326973 Kr 36 78 Pb 82 207 Zr 40 91 Pt 78 194 26.2737
169666 Ti 22 46 Pb 82 207 Fe 26 57 Pt 78 196 26.2271
45852 Ne 10 20 Pb 82 206 Si 14 30 Pt 78 196 26.2178
150429 Sc 21 45 Pb 82 204 Mn 25 55 Pt 78 194 26.1973
123828 K 19 41 Pb 82 204 V 23 51 Pt 78 194 26.1899
169588 Ti 22 47 Pb 82 206 Fe 26 58 Pt 78 195 26.1862
169301 Ti 22 46 Pb 82 204 Fe 26 56 Pt 78 194 26.0446
210951 Fe 26 54 Pb 82 204 Zn 30 68 Pt 78 190 25.9654
113569 Ar 18 40 Pb 82 204 Ti 22 50 Pt 78 194 25.9449
261154 Zn 30 64 Pb 82 208 Se 34 80 Pt 78 192 25.9393
45886 Ne 10 20 Pb 82 208 Si 14 30 Pt 78 198 25.8909
211238 Fe 26 54 Pb 82 206 Zn 30 68 Pt 78 192 25.8695
327109 Kr 36 78 Pb 82 208 Zr 40 90 Pt 78 196 25.8126
326387 Kr 36 78 Pb 82 204 Zr 40 90 Pt 78 192 25.7903
326744 Kr 36 78 Pb 82 206 Zr 40 90 Pt 78 194 25.7875
92343 S 16 32 Pb 82 207 Ca 20 44 Pt 78 195 25.7670
146643 Ca 20 42 Pb 82 206 Cr 24 53 Pt 78 195 25.7120
146676 Ca 20 43 Pb 82 206 Cr 24 53 Pt 78 196 25.7036
146642 Ca 20 42 Pb 82 206 Cr 24 52 Pt 78 196 25.6897
123953 K 19 39 Pb 82 207 V 23 50 Pt 78 196 25.5844
59631 Mg 12 24 Pb 82 204 S 16 34 Pt 78 194 25.5593
150485 Sc 21 45 Pb 82 206 Mn 25 55 Pt 78 196 25.4577
123943 K 19 41 Pb 82 206 V 23 51 Pt 78 196 25.4503
146862 Ca 20 43 Pb 82 208 Cr 24 53 Pt 78 198 25.3767
146842 Ca 20 42 Pb 82 208 Cr 24 52 Pt 78 198 25.3627
169540 Ti 22 46 Pb 82 206 Fe 26 56 Pt 78 196 25.3050
260837 Zn 30 64 Pb 82 206 Se 34 80 Pt 78 190 25.2705
326972 Kr 36 78 Pb 82 207 Zr 40 90 Pt 78 195 25.2677
123814 K 19 40 Pb 82 204 V 23 50 Pt 78 194 25.2454
235618 Ni 28 58 Pb 82 208 Ge 32 72 Pt 78 194 25.2379
113700 Ar 18 40 Pb 82 206 Ti 22 50 Pt 78 196 25.2053
150509 Sc 21 45 Pb 82 208 Mn 25 55 Pt 78 198 25.1308
123988 K 19 41 Pb 82 208 V 23 51 Pt 78 198 25.1233
327110 Kr 36 78 Pb 82 208 Zr 40 91 Pt 78 195 25.0963
92356 S 16 33 Pb 82 207 Ca 20 44 Pt 78 196 25.0460
146479 Ca 20 44 Pb 82 204 Cr 24 54 Pt 78 194 25.0292
169541 Ti 22 46 Pb 82 206 Fe 26 57 Pt 78 195 25.0246
169751 Ti 22 46 Pb 82 208 Fe 26 56 Pt 78 198 24.9780
146311 Ca 20 40 Pb 82 204 Cr 24 50 Pt 78 194 24.9612
113795 Ar 18 40 Pb 82 208 Ti 22 50 Pt 78 198 24.8783
113713 Ar 18 36 Pb 82 207 Ti 22 47 Pt 78 196 24.8774
283484 Ge 32 70 Pb 82 208 Kr 36 84 Pt 78 194 24.8774
303522 Se 34 74 Pb 82 207 Sr 38 87 Pt 78 194 24.8225
59705 Mg 12 24 Pb 82 206 S 16 34 Pt 78 196 24.8197
146773 Ca 20 43 Pb 82 207 Cr 24 52 Pt 78 198 24.8094
169370 Ti 22 47 Pb 82 204 Fe 26 57 Pt 78 194 24.7992
146441 Ca 20 43 Pb 82 204 Cr 24 52 Pt 78 195 24.6986
235471 Ni 28 58 Pb 82 207 Ge 32 73 Pt 78 192 24.6380
234898 Ni 28 58 Pb 82 204 Ge 32 72 Pt 78 190 24.5719
59742 Mg 12 25 Pb 82 207 S 16 34 Pt 78 198 24.5383
123935 K 19 40 Pb 82 206 V 23 50 Pt 78 196 24.5057
59752 Mg 12 24 Pb 82 208 S 16 34 Pt 78 198 24.4927
235250 Ni 28 58 Pb 82 206 Ge 32 72 Pt 78 192 24.4759
59666 Mg 12 25 Pb 82 204 S 16 34 Pt 78 195 24.4275
75042 Si 14 28 Pb 82 208 Ar 18 40 Pt 78 196 24.4107
74864 Si 14 28 Pb 82 204 Ar 18 40 Pt 78 192 24.3884
74973 Si 14 28 Pb 82 206 Ar 18 40 Pt 78 194 24.3856
123909 K 19 39 Pb 82 206 V 23 50 Pt 78 195 24.3819
146692 Ca 20 44 Pb 82 206 Cr 24 54 Pt 78 196 24.2896
146580 Ca 20 40 Pb 82 206 Cr 24 50 Pt 78 196 24.2216
282956 Ge 32 70 Pb 82 204 Kr 36 84 Pt 78 190 24.2114
123984 K 19 40 Pb 82 208 V 23 50 Pt 78 198 24.1788
191086 Cr 24 50 Pb 82 207 Ni 28 61 Pt 78 196 24.1434
62978 Al 13 27 Pb 82 204 Cl 17 37 Pt 78 194 24.1238
283233 Ge 32 70 Pb 82 206 Kr 36 84 Pt 78 192 24.1155
92405 S 16 34 Pb 82 208 Ca 20 46 Pt 78 196 24.0689
283445 Ge 32 73 Pb 82 207 Kr 36 86 Pt 78 194 24.0614
169587 Ti 22 47 Pb 82 206 Fe 26 57 Pt 78 196 24.0596
92224 S 16 34 Pb 82 204 Ca 20 46 Pt 78 192 24.0465
92326 S 16 34 Pb 82 206 Ca 20 46 Pt 78 194 24.0437
113735 Ar 18 38 Pb 82 207 Ti 22 49 Pt 78 196 24.0093
146867 Ca 20 44 Pb 82 208 Cr 24 54 Pt 78 198 23.9627
45834 Ne 10 22 Pb 82 204 Si 14 30 Pt 78 196 23.9506
146802 Ca 20 40 Pb 82 208 Cr 24 50 Pt 78 198 23.8947
261152 Zn 30 64 Pb 82 208 Se 34 78 Pt 78 194 23.8751
75016 Si 14 28 Pb 82 207 Ar 18 40 Pt 78 195 23.8658
92314 S 16 33 Pb 82 206 Ca 20 44 Pt 78 195 23.8435
211415 Fe 26 54 Pb 82 207 Zn 30 67 Pt 78 194 23.8090
190698 Cr 24 50 Pb 82 204 Ni 28 60 Pt 78 194 23.7782
169779 Ti 22 47 Pb 82 208 Fe 26 57 Pt 78 198 23.7326
45823 Ne 10 21 Pb 82 204 Si 14 29 Pt 78 196 23.7028
113624 Ar 18 36 Pb 82 206 Ti 22 47 Pt 78 195 23.6749
303651 Se 34 74 Pb 82 208 Sr 38 87 Pt 78 195 23.6450
283526 Ge 32 72 Pb 82 208 Kr 36 86 Pt 78 194 23.5659
303703 Se 34 76 Pb 82 208 Sr 38 88 Pt 78 196 23.5500
303074 Se 34 76 Pb 82 204 Sr 38 88 Pt 78 192 23.5277
303395 Se 34 76 Pb 82 206 Sr 38 88 Pt 78 194 23.5249
92372 S 16 34 Pb 82 207 Ca 20 46 Pt 78 195 23.5240
303594 Se 34 77 Pb 82 207 Sr 38 88 Pt 78 196 23.5118
211523 Fe 26 54 Pb 82 208 Zn 30 66 Pt 78 196 23.5072
210950 Fe 26 54 Pb 82 204 Zn 30 66 Pt 78 192 23.4848
211237 Fe 26 54 Pb 82 206 Zn 30 66 Pt 78 194 23.4820
169694 Ti 22 47 Pb 82 207 Fe 26 56 Pt 78 198 23.4681
113453 Ar 18 36 Pb 82 204 Ti 22 46 Pt 78 194 23.4494
63002 Al 13 27 Pb 82 206 Cl 17 37 Pt 78 196 23.3842
169369 Ti 22 47 Pb 82 204 Fe 26 56 Pt 78 195 23.3572
113523 Ar 18 38 Pb 82 204 Ti 22 48 Pt 78 194 23.3209
75026 Si 14 29 Pb 82 207 Ar 18 40 Pt 78 196 23.3097
35917 F 9 19 Pb 82 204 Al 13 27 Pt 78 196 23.2482
169411 Ti 22 48 Pb 82 204 Fe 26 58 Pt 78 194 23.2268
260519 Zn 30 64 Pb 82 204 Se 34 78 Pt 78 190 23.2091
33087 O 8 17 Pb 82 207 Mg 12 26 Pt 78 198 23.2044
303650 Se 34 74 Pb 82 208 Sr 38 86 Pt 78 196 23.1504
303009 Se 34 74 Pb 82 204 Sr 38 86 Pt 78 192 23.1281
303324 Se 34 74 Pb 82 206 Sr 38 86 Pt 78 194 23.1253
260834 Zn 30 64 Pb 82 206 Se 34 78 Pt 78 192 23.1132
33043 O 8 17 Pb 82 204 Mg 12 26 Pt 78 195 23.0936
63010 Al 13 27 Pb 82 208 Cl 17 37 Pt 78 198 23.0573
190946 Cr 24 50 Pb 82 206 Ni 28 60 Pt 78 196 23.0386
303559 Se 34 76 Pb 82 207 Sr 38 88 Pt 78 195 23.0051
33052 O 8 18 Pb 82 204 Mg 12 26 Pt 78 196 22.9679
211414 Fe 26 54 Pb 82 207 Zn 30 66 Pt 78 195 22.9623
235687 Ni 28 60 Pb 82 208 Ge 32 76 Pt 78 192 22.9492
190947 Cr 24 50 Pb 82 206 Ni 28 61 Pt 78 195 22.9408
283029 Ge 32 72 Pb 82 204 Kr 36 86 Pt 78 190 22.8999
283550 Ge 32 73 Pb 82 208 Kr 36 86 Pt 78 195 22.8840
45867 Ne 10 22 Pb 82 206 Si 14 30 Pt 78 198 22.8589
113672 Ar 18 38 Pb 82 206 Ti 22 49 Pt 78 195 22.8067
283293 Ge 32 72 Pb 82 206 Kr 36 86 Pt 78 192 22.8039
74862 Si 14 28 Pb 82 204 Ar 18 38 Pt 78 194 22.7853
6038 He 2 3 Pb 82 207 C 6 12 Pt 78 198 22.7266
191164 Cr 24 50 Pb 82 208 Ni 28 60 Pt 78 198 22.7117
113623 Ar 18 36 Pb 82 206 Ti 22 46 Pt 78 196 22.7098
45872 Ne 10 20 Pb 82 207 Si 14 29 Pt 78 198 22.6530
211524 Fe 26 54 Pb 82 208 Zn 30 67 Pt 78 195 22.6316
6009 He 2 3 Pb 82 204 C 6 12 Pt 78 195 22.6157
45862 Ne 10 21 Pb 82 206 Si 14 29 Pt 78 198 22.6111
303521 Se 34 74 Pb 82 207 Sr 38 86 Pt 78 195 22.6055
113671 Ar 18 38 Pb 82 206 Ti 22 48 Pt 78 196 22.5813
191203 Cr 24 52 Pb 82 208 Ni 28 64 Pt 78 196 22.5589
92342 S 16 32 Pb 82 207 Ca 20 43 Pt 78 196 22.5524
45797 Ne 10 20 Pb 82 204 Si 14 29 Pt 78 195 22.5422
190776 Cr 24 52 Pb 82 204 Ni 28 64 Pt 78 192 22.5366
191012 Cr 24 52 Pb 82 206 Ni 28 64 Pt 78 194 22.5338
235555 Ni 28 61 Pb 82 207 Ge 32 76 Pt 78 192 22.5021
169615 Ti 22 48 Pb 82 206 Fe 26 58 Pt 78 196 22.4872
48830 Na 11 23 Pb 82 204 P 15 31 Pt 78 196 22.4471
327172 Kr 36 80 Pb 82 208 Zr 40 94 Pt 78 194 22.4276
286214 As 33 75 Pb 82 208 Rb 37 87 Pt 78 196 22.4145
286132 As 33 75 Pb 82 204 Rb 37 87 Pt 78 192 22.3922
286188 As 33 75 Pb 82 206 Rb 37 87 Pt 78 194 22.3894
113751 Ar 18 36 Pb 82 208 Ti 22 46 Pt 78 198 22.3829
9784 Li 3 7 Pb 82 204 N 7 15 Pt 78 196 22.3419
303438 Se 34 77 Pb 82 206 Sr 38 88 Pt 78 195 22.3093
235318 Ni 28 60 Pb 82 206 Ge 32 76 Pt 78 190 22.2804
113782 Ar 18 38 Pb 82 208 Ti 22 48 Pt 78 198 22.2543
169789 Ti 22 48 Pb 82 208 Fe 26 58 Pt 78 198 22.1602
35931 F 9 19 Pb 82 206 Al 13 27 Pt 78 198 22.1565
74997 Si 14 29 Pb 82 206 Ar 18 40 Pt 78 195 22.1071
261099 Zn 30 67 Pb 82 207 Se 34 80 Pt 78 194 22.0997
92137 S 16 32 Pb 82 204 Ca 20 42 Pt 78 194 22.0811
74972 Si 14 28 Pb 82 206 Ar 18 38 Pt 78 196 22.0457
191116 Cr 24 52 Pb 82 207 Ni 28 64 Pt 78 195 22.0140
191136 Cr 24 53 Pb 82 207 Ni 28 64 Pt 78 196 21.9916
45796 Ne 10 20 Pb 82 204 Si 14 28 Pt 78 196 21.9861
33077 O 8 18 Pb 82 206 Mg 12 26 Pt 78 198 21.8761
286206 As 33 75 Pb 82 207 Rb 37 87 Pt 78 195 21.8696
235685 Ni 28 60 Pb 82 208 Ge 32 74 Pt 78 194 21.8594
327171 Kr 36 80 Pb 82 208 Zr 40 92 Pt 78 196 21.8491
326438 Kr 36 80 Pb 82 204 Zr 40 92 Pt 78 192 21.8268
326811 Kr 36 80 Pb 82 206 Zr 40 92 Pt 78 194 21.8240
211579 Fe 26 56 Pb 82 208 Zn 30 70 Pt 78 194 21.8137
327173 Kr 36 80 Pb 82 208 Zr 40 96 Pt 78 192 21.7942
9801 Li 3 6 Pb 82 207 N 7 15 Pt 78 198 21.7839
261206 Zn 30 66 Pb 82 208 Se 34 80 Pt 78 194 21.7690
326441 Kr 36 80 Pb 82 204 Zr 40 94 Pt 78 190 21.7616
283387 Ge 32 70 Pb 82 207 Kr 36 83 Pt 78 194 21.7355
75041 Si 14 28 Pb 82 208 Ar 18 38 Pt 78 198 21.7187
9780 Li 3 6 Pb 82 204 N 7 15 Pt 78 195 21.6731
326813 Kr 36 80 Pb 82 206 Zr 40 94 Pt 78 192 21.6656
146792 Ca 20 44 Pb 82 207 Cr 24 53 Pt 78 198 21.6172
99216 Cl 17 35 Pb 82 204 Sc 21 45 Pt 78 194 21.6060
308249 Br 35 79 Pb 82 204 Y 39 89 Pt 78 194 21.5892
211477 Fe 26 57 Pb 82 207 Zn 30 70 Pt 78 194 21.5492
146478 Ca 20 44 Pb 82 204 Cr 24 53 Pt 78 195 21.5063
146477 Ca 20 44 Pb 82 204 Cr 24 52 Pt 78 196 21.4840
123969 K 19 41 Pb 82 207 V 23 50 Pt 78 198 21.4598
235553 Ni 28 61 Pb 82 207 Ge 32 74 Pt 78 194 21.4123
169730 Ti 22 49 Pb 82 207 Fe 26 58 Pt 78 198 21.3899
92191 S 16 33 Pb 82 204 Ca 20 43 Pt 78 194 21.3685
6010 He 2 3 Pb 82 204 C 6 13 Pt 78 194 21.3638
48845 Na 11 23 Pb 82 206 P 15 31 Pt 78 198 21.3554
92279 S 16 32 Pb 82 206 Ca 20 43 Pt 78 195 21.3498
123827 K 19 41 Pb 82 204 V 23 50 Pt 78 195 21.3489
92278 S 16 32 Pb 82 206 Ca 20 42 Pt 78 196 21.3415
15950 B 5 10 Pb 82 207 F 9 19 Pt 78 198 21.3331
146512 Ca 20 46 Pb 82 204 Cr 24 54 Pt 78 196 21.3294
113741 Ar 18 40 Pb 82 207 Ti 22 49 Pt 78 198 21.3172
327012 Kr 36 80 Pb 82 207 Zr 40 92 Pt 78 195 21.3042
169456 Ti 22 49 Pb 82 204 Fe 26 58 Pt 78 195 21.2791
59678 Mg 12 26 Pb 82 204 S 16 34 Pt 78 196 21.2511
9797 Li 3 7 Pb 82 206 N 7 15 Pt 78 198 21.2502
15927 B 5 10 Pb 82 204 F 9 19 Pt 78 195 21.2222
283444 Ge 32 73 Pb 82 207 Kr 36 84 Pt 78 196 21.2129
113568 Ar 18 40 Pb 82 204 Ti 22 49 Pt 78 195 21.2064
234959 Ni 28 60 Pb 82 204 Ge 32 74 Pt 78 190 21.1934
211018 Fe 26 56 Pb 82 204 Zn 30 70 Pt 78 190 21.1477
326815 Kr 36 80 Pb 82 206 Zr 40 96 Pt 78 190 21.1254
260586 Zn 30 66 Pb 82 204 Se 34 80 Pt 78 190 21.1030
235315 Ni 28 60 Pb 82 206 Ge 32 74 Pt 78 192 21.0974
92222 S 16 34 Pb 82 204 Ca 20 44 Pt 78 194 21.0834
235617 Ni 28 58 Pb 82 208 Ge 32 70 Pt 78 196 21.0778
234897 Ni 28 58 Pb 82 204 Ge 32 70 Pt 78 192 21.0555
235249 Ni 28 58 Pb 82 206 Ge 32 70 Pt 78 194 21.0527
211312 Fe 26 56 Pb 82 206 Zn 30 70 Pt 78 192 21.0518
33025 O 8 16 Pb 82 204 Mg 12 26 Pt 78 194 21.0359
92381 S 16 32 Pb 82 208 Ca 20 42 Pt 78 198 21.0145
283482 Ge 32 70 Pb 82 208 Kr 36 82 Pt 78 196 21.0117
260900 Zn 30 66 Pb 82 206 Se 34 80 Pt 78 192 21.0071
282955 Ge 32 70 Pb 82 204 Kr 36 82 Pt 78 192 20.9894
283232 Ge 32 70 Pb 82 206 Kr 36 82 Pt 78 194 20.9866
113567 Ar 18 40 Pb 82 204 Ti 22 48 Pt 78 196 20.9810
59665 Mg 12 25 Pb 82 204 S 16 33 Pt 78 196 20.9279
261238 Zn 30 67 Pb 82 208 Se 34 80 Pt 78 195 20.9223
45851 Ne 10 20 Pb 82 206 Si 14 28 Pt 78 198 20.8943
190774 Cr 24 52 Pb 82 204 Ni 28 62 Pt 78 194 20.8915
99295 Cl 17 35 Pb 82 206 Sc 21 45 Pt 78 196 20.8664
308360 Br 35 79 Pb 82 206 Y 39 89 Pt 78 196 20.8496
174617 V 23 50 Pb 82 207 Co 27 59 Pt 78 198 20.8124
326437 Kr 36 80 Pb 82 204 Zr 40 90 Pt 78 194 20.7928
191046 Cr 24 53 Pb 82 206 Ni 28 64 Pt 78 195 20.7891
261027 Zn 30 64 Pb 82 207 Se 34 77 Pt 78 194 20.7714
283525 Ge 32 72 Pb 82 208 Kr 36 84 Pt 78 196 20.7174
174534 V 23 50 Pb 82 204 Co 27 59 Pt 78 195 20.7015
283026 Ge 32 72 Pb 82 204 Kr 36 84 Pt 78 192 20.6950
283291 Ge 32 72 Pb 82 206 Kr 36 84 Pt 78 194 20.6922
283558 Ge 32 74 Pb 82 208 Kr 36 86 Pt 78 196 20.6754
78622 P 15 31 Pb 82 204 K 19 41 Pt 78 194 20.6671
283117 Ge 32 74 Pb 82 204 Kr 36 86 Pt 78 192 20.6531
283350 Ge 32 74 Pb 82 206 Kr 36 86 Pt 78 194 20.6503
92313 S 16 33 Pb 82 206 Ca 20 43 Pt 78 196 20.6289
6030 He 2 3 Pb 82 206 C 6 13 Pt 78 196 20.6242
75025 Si 14 29 Pb 82 207 Ar 18 38 Pt 78 198 20.6177
283483 Ge 32 70 Pb 82 208 Kr 36 83 Pt 78 195 20.5581
99324 Cl 17 35 Pb 82 208 Sc 21 45 Pt 78 198 20.5394
327011 Kr 36 80 Pb 82 207 Zr 40 91 Pt 78 196 20.5394
235470 Ni 28 58 Pb 82 207 Ge 32 70 Pt 78 195 20.5329
308413 Br 35 79 Pb 82 208 Y 39 89 Pt 78 198 20.5227
74908 Si 14 29 Pb 82 204 Ar 18 38 Pt 78 195 20.5068
303178 Se 34 78 Pb 82 204 Sr 38 88 Pt 78 194 20.4901
283386 Ge 32 70 Pb 82 207 Kr 36 82 Pt 78 195 20.4668
59735 Mg 12 24 Pb 82 207 S 16 33 Pt 78 198 20.4482
146691 Ca 20 44 Pb 82 206 Cr 24 52 Pt 78 198 20.3923
211608 Fe 26 57 Pb 82 208 Zn 30 70 Pt 78 195 20.3718
92325 S 16 34 Pb 82 206 Ca 20 44 Pt 78 196 20.3438
24724 N 7 14 Pb 82 207 Na 11 23 Pt 78 198 20.3410
59630 Mg 12 24 Pb 82 204 S 16 33 Pt 78 195 20.3373
92398 S 16 33 Pb 82 208 Ca 20 43 Pt 78 198 20.3019
6044 He 2 3 Pb 82 208 C 6 13 Pt 78 198 20.2973
33064 O 8 16 Pb 82 206 Mg 12 26 Pt 78 196 20.2963
211578 Fe 26 56 Pb 82 208 Zn 30 68 Pt 78 196 20.2414
146710 Ca 20 46 Pb 82 206 Cr 24 54 Pt 78 198 20.2376
235724 Ni 28 61 Pb 82 208 Ge 32 74 Pt 78 195 20.2348
24699 N 7 14 Pb 82 204 Na 11 23 Pt 78 195 20.2302
211016 Fe 26 56 Pb 82 204 Zn 30 68 Pt 78 192 20.2190
211310 Fe 26 56 Pb 82 206 Zn 30 68 Pt 78 194 20.2162
343796 Sr 38 84 Pb 82 208 Mo 42 98 Pt 78 194 20.2134
283421 Ge 32 72 Pb 82 207 Kr 36 84 Pt 78 195 20.1724
59727 Mg 12 26 Pb 82 206 S 16 34 Pt 78 198 20.1594
74932 Si 14 30 Pb 82 204 Ar 18 40 Pt 78 194 20.1538
191011 Cr 24 52 Pb 82 206 Ni 28 62 Pt 78 196 20.1519
283468 Ge 32 74 Pb 82 207 Kr 36 86 Pt 78 195 20.1305
261150 Zn 30 64 Pb 82 208 Se 34 76 Pt 78 196 20.1007
260518 Zn 30 64 Pb 82 204 Se 34 76 Pt 78 192 20.0784
260833 Zn 30 64 Pb 82 206 Se 34 76 Pt 78 194 20.0756
326809 Kr 36 80 Pb 82 206 Zr 40 90 Pt 78 196 20.0532
92404 S 16 34 Pb 82 208 Ca 20 44 Pt 78 198 20.0169
283329 Ge 32 73 Pb 82 206 Kr 36 84 Pt 78 195 20.0104
211476 Fe 26 57 Pb 82 207 Zn 30 68 Pt 78 196 19.9768
33092 O 8 16 Pb 82 208 Mg 12 26 Pt 78 198 19.9694
11714 Be 4 9 Pb 82 207 O 8 18 Pt 78 198 19.9284
78659 P 15 31 Pb 82 206 K 19 41 Pt 78 196 19.9275
33042 O 8 17 Pb 82 204 Mg 12 25 Pt 78 196 19.9172
113699 Ar 18 40 Pb 82 206 Ti 22 48 Pt 78 198 19.8893
303137 Se 34 77 Pb 82 204 Sr 38 87 Pt 78 194 19.8436
59722 Mg 12 25 Pb 82 206 S 16 33 Pt 78 198 19.8362
191202 Cr 24 52 Pb 82 208 Ni 28 62 Pt 78 198 19.8250
11707 Be 4 9 Pb 82 204 O 8 18 Pt 78 195 19.8175
303558 Se 34 76 Pb 82 207 Sr 38 87 Pt 78 196 19.7998
303471 Se 34 78 Pb 82 206 Sr 38 88 Pt 78 196 19.7505
92355 S 16 33 Pb 82 207 Ca 20 42 Pt 78 198 19.7486
190865 Cr 24 54 Pb 82 204 Ni 28 64 Pt 78 194 19.7281
327170 Kr 36 80 Pb 82 208 Zr 40 90 Pt 78 198 19.7263
211451 Fe 26 56 Pb 82 207 Zn 30 68 Pt 78 195 19.6964
11706 Be 4 9 Pb 82 204 O 8 17 Pt 78 196 19.6918
169409 Ti 22 48 Pb 82 204 Fe 26 56 Pt 78 196 19.6583
169300 Ti 22 46 Pb 82 204 Fe 26 54 Pt 78 196 19.6545
92190 S 16 33 Pb 82 204 Ca 20 42 Pt 78 195 19.6378
59629 Mg 12 24 Pb 82 204 S 16 32 Pt 78 196 19.6163
78672 P 15 31 Pb 82 208 K 19 41 Pt 78 198 19.6005
261151 Zn 30 64 Pb 82 208 Se 34 77 Pt 78 195 19.5940
343797 Sr 38 84 Pb 82 208 Mo 42 100 Pt 78 192 19.5800
283154 Ge 32 76 Pb 82 204 Kr 36 86 Pt 78 194 19.5632
266751 Ga 31 69 Pb 82 208 Br 35 81 Pt 78 196 19.5623
261026 Zn 30 64 Pb 82 207 Se 34 76 Pt 78 195 19.5558
343218 Sr 38 84 Pb 82 204 Mo 42 98 Pt 78 190 19.5474
266581 Ga 31 69 Pb 82 204 Br 35 81 Pt 78 192 19.5400
266696 Ga 31 69 Pb 82 206 Br 35 81 Pt 78 194 19.5372
169721 Ti 22 48 Pb 82 207 Fe 26 57 Pt 78 198 19.4887
343490 Sr 38 84 Pb 82 206 Mo 42 98 Pt 78 192 19.4515
303749 Se 34 78 Pb 82 208 Sr 38 88 Pt 78 198 19.4235
75005 Si 14 30 Pb 82 206 Ar 18 40 Pt 78 196 19.4142
235742 Ni 28 62 Pb 82 208 Ge 32 76 Pt 78 194 19.3928
169410 Ti 22 48 Pb 82 204 Fe 26 57 Pt 78 195 19.3779
62977 Al 13 27 Pb 82 204 Cl 17 35 Pt 78 196 19.3453
326810 Kr 36 80 Pb 82 206 Zr 40 91 Pt 78 195 19.3369
210949 Fe 26 54 Pb 82 204 Zn 30 64 Pt 78 194 19.3145
399505 Ru 44 96 Pb 82 208 Cd 48 114 Pt 78 190 19.3043
261098 Zn 30 67 Pb 82 207 Se 34 78 Pt 78 196 19.2987
343669 Sr 38 84 Pb 82 207 Mo 42 97 Pt 78 194 19.2950
191135 Cr 24 53 Pb 82 207 Ni 28 62 Pt 78 198 19.2577
146383 Ca 20 42 Pb 82 204 Cr 24 50 Pt 78 196 19.2493
169455 Ti 22 49 Pb 82 204 Fe 26 57 Pt 78 196 19.1525
190834 Cr 24 53 Pb 82 204 Ni 28 62 Pt 78 195 19.1469
194146 Mn 25 55 Pb 82 204 Cu 29 65 Pt 78 194 19.1208
235514 Ni 28 60 Pb 82 207 Ge 32 73 Pt 78 194 19.1059
303437 Se 34 77 Pb 82 206 Sr 38 87 Pt 78 196 19.1040
75054 Si 14 30 Pb 82 208 Ar 18 40 Pt 78 198 19.0872
343794 Sr 38 84 Pb 82 208 Mo 42 96 Pt 78 196 19.0854
343216 Sr 38 84 Pb 82 204 Mo 42 96 Pt 78 192 19.0630
343489 Sr 38 84 Pb 82 206 Mo 42 96 Pt 78 194 19.0602
266737 Ga 31 69 Pb 82 207 Br 35 81 Pt 78 195 19.0174
191065 Cr 24 54 Pb 82 206 Ni 28 64 Pt 78 196 18.9885
235683 Ni 28 60 Pb 82 208 Ge 32 72 Pt 78 196 18.9689
261205 Zn 30 66 Pb 82 208 Se 34 78 Pt 78 196 18.9680
234958 Ni 28 60 Pb 82 204 Ge 32 72 Pt 78 192 18.9466
260583 Zn 30 66 Pb 82 204 Se 34 78 Pt 78 192 18.9457
20720 C 6 13 Pb 82 207 Ne 10 22 Pt 78 198 18.9438
235314 Ni 28 60 Pb 82 206 Ge 32 72 Pt 78 194 18.9438
260898 Zn 30 66 Pb 82 206 Se 34 78 Pt 78 194 18.9429
343492 Sr 38 84 Pb 82 206 Mo 42 100 Pt 78 190 18.9112
303073 Se 34 76 Pb 82 204 Sr 38 86 Pt 78 194 18.8423
20695 C 6 13 Pb 82 204 Ne 10 22 Pt 78 195 18.8329
33072 O 8 17 Pb 82 206 Mg 12 25 Pt 78 198 18.8255
283373 Ge 32 76 Pb 82 206 Kr 36 86 Pt 78 196 18.8236
303733 Se 34 77 Pb 82 208 Sr 38 87 Pt 78 198 18.7771
211360 Fe 26 57 Pb 82 206 Zn 30 68 Pt 78 195 18.7743
286130 As 33 75 Pb 82 204 Rb 37 85 Pt 78 194 18.7500
235066 Ni 28 62 Pb 82 204 Ge 32 76 Pt 78 190 18.7268
191226 Cr 24 54 Pb 82 208 Ni 28 64 Pt 78 198 18.6616
261252 Zn 30 68 Pb 82 208 Se 34 80 Pt 78 196 18.6448
214922 Co 27 59 Pb 82 208 Ga 31 71 Pt 78 196 18.6420
235410 Ni 28 62 Pb 82 206 Ge 32 76 Pt 78 192 18.6308
45833 Ne 10 22 Pb 82 204 Si 14 28 Pt 78 198 18.6271
260685 Zn 30 68 Pb 82 204 Se 34 80 Pt 78 192 18.6224
214823 Co 27 59 Pb 82 204 Ga 31 71 Pt 78 192 18.6196
260975 Zn 30 68 Pb 82 206 Se 34 80 Pt 78 194 18.6196
214889 Co 27 59 Pb 82 206 Ga 31 71 Pt 78 194 18.6168
399502 Ru 44 96 Pb 82 208 Cd 48 112 Pt 78 192 18.6057
9779 Li 3 6 Pb 82 204 N 7 14 Pt 78 196 18.6038
11711 Be 4 9 Pb 82 206 O 8 17 Pt 78 198 18.6001
303394 Se 34 76 Pb 82 206 Sr 38 87 Pt 78 195 18.5973
211236 Fe 26 54 Pb 82 206 Zn 30 64 Pt 78 196 18.5749
169614 Ti 22 48 Pb 82 206 Fe 26 56 Pt 78 198 18.5665
169538 Ti 22 46 Pb 82 206 Fe 26 54 Pt 78 198 18.5628
283115 Ge 32 74 Pb 82 204 Kr 36 84 Pt 78 194 18.5414
343668 Sr 38 84 Pb 82 207 Mo 42 96 Pt 78 195 18.5405
59704 Mg 12 24 Pb 82 206 S 16 32 Pt 78 198 18.5246
235551 Ni 28 61 Pb 82 207 Ge 32 72 Pt 78 196 18.5218
435027 Cd 48 106 Pb 82 208 Te 52 124 Pt 78 190 18.5218
283568 Ge 32 76 Pb 82 208 Kr 36 86 Pt 78 198 18.4967
235513 Ni 28 60 Pb 82 207 Ge 32 72 Pt 78 195 18.4240
261066 Zn 30 66 Pb 82 207 Se 34 78 Pt 78 195 18.4231
194195 Mn 25 55 Pb 82 206 Cu 29 65 Pt 78 196 18.3812
241947 Cu 29 63 Pb 82 208 As 33 75 Pt 78 196 18.3299
33051 O 8 18 Pb 82 204 Mg 12 24 Pt 78 198 18.3076
241742 Cu 29 63 Pb 82 204 As 33 75 Pt 78 192 18.3076
241878 Cu 29 63 Pb 82 206 As 33 75 Pt 78 194 18.3048
169481 Ti 22 50 Pb 82 204 Fe 26 58 Pt 78 196 18.2629
63001 Al 13 27 Pb 82 206 Cl 17 35 Pt 78 198 18.2536
211521 Fe 26 54 Pb 82 208 Zn 30 64 Pt 78 198 18.2480
211619 Fe 26 58 Pb 82 208 Zn 30 70 Pt 78 196 18.2452
211123 Fe 26 58 Pb 82 204 Zn 30 70 Pt 78 192 18.2228
211385 Fe 26 58 Pb 82 206 Zn 30 70 Pt 78 194 18.2200
415637 Pd 46 102 Pb 82 208 Sn 50 120 Pt 78 190 18.1679
146640 Ca 20 42 Pb 82 206 Cr 24 50 Pt 78 198 18.1576
283077 Ge 32 73 Pb 82 204 Kr 36 83 Pt 78 194 18.1530
343795 Sr 38 84 Pb 82 208 Mo 42 97 Pt 78 195 18.1176
303393 Se 34 76 Pb 82 206 Sr 38 86 Pt 78 196 18.1027
261130 Zn 30 68 Pb 82 207 Se 34 80 Pt 78 195 18.0999
214911 Co 27 59 Pb 82 207 Ga 31 71 Pt 78 195 18.0971
260945 Zn 30 67 Pb 82 206 Se 34 78 Pt 78 195 18.0961
169640 Ti 22 49 Pb 82 206 Fe 26 57 Pt 78 198 18.0607
194218 Mn 25 55 Pb 82 208 Cu 29 65 Pt 78 198 18.0542
235723 Ni 28 61 Pb 82 208 Ge 32 73 Pt 78 196 18.0263
113734 Ar 18 38 Pb 82 207 Ti 22 47 Pt 78 198 18.0104
286187 As 33 75 Pb 82 206 Rb 37 85 Pt 78 196 18.0104
303008 Se 34 74 Pb 82 204 Sr 38 84 Pt 78 194 18.0086
235017 Ni 28 61 Pb 82 204 Ge 32 73 Pt 78 192 18.0039
235371 Ni 28 61 Pb 82 206 Ge 32 73 Pt 78 194 18.0011
398967 Ru 44 96 Pb 82 206 Cd 48 112 Pt 78 190 17.9369
235684 Ni 28 60 Pb 82 208 Ge 32 73 Pt 78 195 17.9285
113522 Ar 18 38 Pb 82 204 Ti 22 47 Pt 78 195 17.8996
326503 Kr 36 82 Pb 82 204 Zr 40 92 Pt 78 194 17.8400
211015 Fe 26 56 Pb 82 204 Zn 30 66 Pt 78 194 17.8316
74931 Si 14 30 Pb 82 204 Ar 18 38 Pt 78 196 17.8139
327216 Kr 36 82 Pb 82 208 Zr 40 96 Pt 78 194 17.8074
283349 Ge 32 74 Pb 82 206 Kr 36 84 Pt 78 196 17.8018
260734 Zn 30 70 Pb 82 204 Se 34 80 Pt 78 194 17.7869
241928 Cu 29 63 Pb 82 207 As 33 75 Pt 78 195 17.7850
303701 Se 34 76 Pb 82 208 Sr 38 86 Pt 78 198 17.7757
303592 Se 34 77 Pb 82 207 Sr 38 86 Pt 78 198 17.7375
146529 Ca 20 48 Pb 82 204 Cr 24 54 Pt 78 198 17.7198
327069 Kr 36 83 Pb 82 207 Zr 40 96 Pt 78 194 17.7161
327215 Kr 36 82 Pb 82 208 Zr 40 94 Pt 78 196 17.7040
211505 Fe 26 58 Pb 82 207 Zn 30 70 Pt 78 195 17.7003
308278 Br 35 81 Pb 82 204 Y 39 89 Pt 78 196 17.7003
303224 Se 34 80 Pb 82 204 Sr 38 88 Pt 78 196 17.6891
15933 B 5 11 Pb 82 204 F 9 19 Pt 78 196 17.6872
286212 As 33 75 Pb 82 208 Rb 37 85 Pt 78 198 17.6835
326505 Kr 36 82 Pb 82 204 Zr 40 94 Pt 78 192 17.6816
326871 Kr 36 82 Pb 82 206 Zr 40 94 Pt 78 194 17.6788
399246 Ru 44 96 Pb 82 207 Cd 48 113 Pt 78 190 17.6406
303136 Se 34 77 Pb 82 204 Sr 38 86 Pt 78 195 17.6267
327068 Kr 36 83 Pb 82 207 Zr 40 94 Pt 78 196 17.6127
343215 Sr 38 84 Pb 82 204 Mo 42 94 Pt 78 194 17.6006
174550 V 23 51 Pb 82 204 Co 27 59 Pt 78 196 17.5829
20680 C 6 12 Pb 82 204 Ne 10 22 Pt 78 194 17.5810
283420 Ge 32 72 Pb 82 207 Kr 36 83 Pt 78 196 17.5754
235741 Ni 28 62 Pb 82 208 Ge 32 74 Pt 78 196 17.5661
283025 Ge 32 72 Pb 82 204 Kr 36 82 Pt 78 194 17.5661
235063 Ni 28 62 Pb 82 204 Ge 32 74 Pt 78 192 17.5438
235408 Ni 28 62 Pb 82 206 Ge 32 74 Pt 78 194 17.5410
9794 Li 3 6 Pb 82 206 N 7 14 Pt 78 198 17.5121
190697 Cr 24 50 Pb 82 204 Ni 28 58 Pt 78 196 17.5093
235552 Ni 28 61 Pb 82 207 Ge 32 73 Pt 78 195 17.4813
283557 Ge 32 74 Pb 82 208 Kr 36 84 Pt 78 198 17.4748
266612 Ga 31 71 Pb 82 204 Br 35 81 Pt 78 194 17.4702
146511 Ca 20 46 Pb 82 204 Cr 24 52 Pt 78 198 17.4320
211450 Fe 26 56 Pb 82 207 Zn 30 67 Pt 78 196 17.4189
283328 Ge 32 73 Pb 82 206 Kr 36 83 Pt 78 196 17.4134
211121 Fe 26 58 Pb 82 204 Zn 30 68 Pt 78 194 17.3873
190864 Cr 24 54 Pb 82 204 Ni 28 62 Pt 78 196 17.3463
235370 Ni 28 61 Pb 82 206 Ge 32 72 Pt 78 195 17.3193
343667 Sr 38 84 Pb 82 207 Mo 42 95 Pt 78 196 17.3006
303323 Se 34 74 Pb 82 206 Sr 38 84 Pt 78 196 17.2690
211081 Fe 26 57 Pb 82 204 Zn 30 67 Pt 78 194 17.2364
453737 Sn 50 114 Pb 82 208 Xe 54 132 Pt 78 190 17.2252
381436 Mo 42 92 Pb 82 208 Pd 46 110 Pt 78 190 17.2177
399501 Ru 44 96 Pb 82 208 Cd 48 110 Pt 78 194 17.1991
169648 Ti 22 50 Pb 82 206 Fe 26 58 Pt 78 198 17.1712
24704 N 7 15 Pb 82 204 Na 11 23 Pt 78 196 17.1609
327044 Kr 36 82 Pb 82 207 Zr 40 94 Pt 78 195 17.1591
326507 Kr 36 82 Pb 82 204 Zr 40 96 Pt 78 190 17.1414
415636 Pd 46 102 Pb 82 208 Sn 50 118 Pt 78 192 17.1060
326870 Kr 36 82 Pb 82 206 Zr 40 92 Pt 78 196 17.1004
211308 Fe 26 56 Pb 82 206 Zn 30 66 Pt 78 196 17.0920
283549 Ge 32 73 Pb 82 208 Kr 36 83 Pt 78 198 17.0864
261007 Zn 30 70 Pb 82 206 Se 34 80 Pt 78 196 17.0473
326872 Kr 36 82 Pb 82 206 Zr 40 96 Pt 78 192 17.0454
235591 Ni 28 62 Pb 82 207 Ge 32 74 Pt 78 195 17.0212
235763 Ni 28 64 Pb 82 208 Ge 32 76 Pt 78 196 17.0109
282954 Ge 32 70 Pb 82 204 Kr 36 80 Pt 78 194 17.0026
283443 Ge 32 73 Pb 82 207 Kr 36 82 Pt 78 198 16.9951
235126 Ni 28 64 Pb 82 204 Ge 32 76 Pt 78 192 16.9886
235448 Ni 28 64 Pb 82 206 Ge 32 76 Pt 78 194 16.9858
303647 Se 34 74 Pb 82 208 Sr 38 84 Pt 78 198 16.9420
113521 Ar 18 38 Pb 82 204 Ti 22 46 Pt 78 196 16.9346
435026 Cd 48 106 Pb 82 208 Te 52 122 Pt 78 192 16.9197
78620 P 15 31 Pb 82 204 K 19 39 Pt 78 196 16.8945
283076 Ge 32 73 Pb 82 204 Kr 36 82 Pt 78 195 16.8843
453699 Sn 50 112 Pb 82 208 Xe 54 130 Pt 78 190 16.8824
78668 P 15 31 Pb 82 207 K 19 40 Pt 78 198 16.8815
343487 Sr 38 84 Pb 82 206 Mo 42 94 Pt 78 196 16.8610
20705 C 6 12 Pb 82 206 Ne 10 22 Pt 78 196 16.8414
99251 Cl 17 37 Pb 82 204 Sc 21 45 Pt 78 196 16.8274
283289 Ge 32 72 Pb 82 206 Kr 36 82 Pt 78 196 16.8265
327214 Kr 36 82 Pb 82 208 Zr 40 92 Pt 78 198 16.7734
78621 P 15 31 Pb 82 204 K 19 40 Pt 78 195 16.7706
211577 Fe 26 56 Pb 82 208 Zn 30 66 Pt 78 198 16.7650
266723 Ga 31 71 Pb 82 206 Br 35 81 Pt 78 196 16.7306
33023 O 8 16 Pb 82 204 Mg 12 24 Pt 78 196 16.7278
75004 Si 14 30 Pb 82 206 Ar 18 38 Pt 78 198 16.7222
261269 Zn 30 70 Pb 82 208 Se 34 80 Pt 78 198 16.7203
283153 Ge 32 76 Pb 82 204 Kr 36 84 Pt 78 196 16.7147
327067 Kr 36 83 Pb 82 207 Zr 40 92 Pt 78 198 16.6821
211384 Fe 26 58 Pb 82 206 Zn 30 68 Pt 78 196 16.6477
191115 Cr 24 52 Pb 82 207 Ni 28 61 Pt 78 198 16.6113
308385 Br 35 81 Pb 82 206 Y 39 89 Pt 78 198 16.6085
190772 Cr 24 52 Pb 82 204 Ni 28 60 Pt 78 196 16.5983
303501 Se 34 80 Pb 82 206 Sr 38 88 Pt 78 198 16.5974
15946 B 5 11 Pb 82 206 F 9 19 Pt 78 198 16.5955
326559 Kr 36 83 Pb 82 204 Zr 40 92 Pt 78 195 16.5713
260683 Zn 30 68 Pb 82 204 Se 34 78 Pt 78 194 16.5582
214821 Co 27 59 Pb 82 204 Ga 31 69 Pt 78 194 16.5499
327240 Kr 36 83 Pb 82 208 Zr 40 96 Pt 78 195 16.5387
343792 Sr 38 84 Pb 82 208 Mo 42 94 Pt 78 198 16.5340
398574 Ru 44 96 Pb 82 204 Cd 48 110 Pt 78 190 16.5331
20724 C 6 12 Pb 82 208 Ne 10 22 Pt 78 198 16.5145
434788 Cd 48 106 Pb 82 207 Te 52 123 Pt 78 190 16.5042
190773 Cr 24 52 Pb 82 204 Ni 28 61 Pt 78 195 16.5005
211475 Fe 26 57 Pb 82 207 Zn 30 66 Pt 78 198 16.5005
283524 Ge 32 72 Pb 82 208 Kr 36 82 Pt 78 198 16.4996
211359 Fe 26 57 Pb 82 206 Zn 30 67 Pt 78 196 16.4968
174601 V 23 51 Pb 82 206 Co 27 59 Pt 78 198 16.4912
190833 Cr 24 53 Pb 82 204 Ni 28 61 Pt 78 196 16.4781
235605 Ni 28 64 Pb 82 207 Ge 32 76 Pt 78 195 16.4660
453735 Sn 50 114 Pb 82 208 Xe 54 130 Pt 78 192 16.4539
398966 Ru 44 96 Pb 82 206 Cd 48 110 Pt 78 192 16.4371
415205 Pd 46 102 Pb 82 206 Sn 50 118 Pt 78 190 16.4371
190944 Cr 24 50 Pb 82 206 Ni 28 58 Pt 78 198 16.4176
326909 Kr 36 83 Pb 82 206 Zr 40 94 Pt 78 195 16.4101
266766 Ga 31 71 Pb 82 208 Br 35 81 Pt 78 198 16.4036
211080 Fe 26 57 Pb 82 204 Zn 30 66 Pt 78 195 16.3896
20694 C 6 13 Pb 82 204 Ne 10 21 Pt 78 196 16.3878
266579 Ga 31 69 Pb 82 204 Br 35 79 Pt 78 194 16.3878
381433 Mo 42 92 Pb 82 208 Pd 46 108 Pt 78 192 16.3794
283290 Ge 32 72 Pb 82 206 Kr 36 83 Pt 78 195 16.3729
92136 S 16 32 Pb 82 204 Ca 20 40 Pt 78 196 16.3691
399245 Ru 44 96 Pb 82 207 Cd 48 111 Pt 78 192 16.3552
211618 Fe 26 58 Pb 82 208 Zn 30 68 Pt 78 198 16.3207
415441 Pd 46 102 Pb 82 207 Sn 50 119 Pt 78 190 16.2993
260640 Zn 30 67 Pb 82 204 Se 34 77 Pt 78 194 16.2769
74861 Si 14 28 Pb 82 204 Ar 18 36 Pt 78 196 16.2704
283231 Ge 32 70 Pb 82 206 Kr 36 80 Pt 78 196 16.2630
92371 S 16 34 Pb 82 207 Ca 20 43 Pt 78 198 16.2574
435064 Cd 48 108 Pb 82 208 Te 52 126 Pt 78 190 16.2564
191064 Cr 24 54 Pb 82 206 Ni 28 62 Pt 78 198 16.2546
434521 Cd 48 106 Pb 82 206 Te 52 122 Pt 78 190 16.2508
33081 O 8 16 Pb 82 207 Mg 12 25 Pt 78 198 16.2481
211309 Fe 26 56 Pb 82 206 Zn 30 67 Pt 78 195 16.2164
211607 Fe 26 57 Pb 82 208 Zn 30 67 Pt 78 198 16.1698
92221 S 16 34 Pb 82 204 Ca 20 43 Pt 78 195 16.1465
92220 S 16 34 Pb 82 204 Ca 20 42 Pt 78 196 16.1381
33024 O 8 16 Pb 82 204 Mg 12 25 Pt 78 195 16.1372
343488 Sr 38 84 Pb 82 206 Mo 42 95 Pt 78 195 16.0981
24719 N 7 15 Pb 82 206 Na 11 23 Pt 78 198 16.0692
326501 Kr 36 82 Pb 82 204 Zr 40 90 Pt 78 196 16.0692
399557 Ru 44 98 Pb 82 208 Cd 48 116 Pt 78 190 16.0068
415512 Pd 46 105 Pb 82 207 Sn 50 122 Pt 78 190 16.0012
399554 Ru 44 98 Pb 82 208 Cd 48 114 Pt 78 192 15.9695
283480 Ge 32 70 Pb 82 208 Kr 36 80 Pt 78 198 15.9360
260582 Zn 30 66 Pb 82 204 Se 34 76 Pt 78 194 15.9081
235124 Ni 28 64 Pb 82 204 Ge 32 74 Pt 78 194 15.8987
261065 Zn 30 66 Pb 82 207 Se 34 77 Pt 78 196 15.8643
399316 Ru 44 99 Pb 82 207 Cd 48 116 Pt 78 190 15.8522
113669 Ar 18 38 Pb 82 206 Ti 22 46 Pt 78 198 15.8429
260974 Zn 30 68 Pb 82 206 Se 34 78 Pt 78 196 15.8186
399313 Ru 44 99 Pb 82 207 Cd 48 114 Pt 78 192 15.8149
415509 Pd 46 105 Pb 82 207 Sn 50 120 Pt 78 192 15.8149
214888 Co 27 59 Pb 82 206 Ga 31 69 Pt 78 196 15.8102
326558 Kr 36 83 Pb 82 204 Zr 40 91 Pt 78 196 15.8065
78657 P 15 31 Pb 82 206 K 19 39 Pt 78 198 15.8028
260517 Zn 30 64 Pb 82 204 Se 34 74 Pt 78 194 15.7926
453187 Sn 50 114 Pb 82 206 Xe 54 130 Pt 78 190 15.7851
381431 Mo 42 92 Pb 82 208 Pd 46 106 Pt 78 194 15.7646
99310 Cl 17 37 Pb 82 206 Sc 21 45 Pt 78 198 15.7357
380916 Mo 42 92 Pb 82 206 Pd 46 108 Pt 78 190 15.7106
415689 Pd 46 104 Pb 82 208 Sn 50 122 Pt 78 190 15.6901
303623 Se 34 78 Pb 82 207 Sr 38 87 Pt 78 198 15.6733
453468 Sn 50 114 Pb 82 207 Xe 54 131 Pt 78 190 15.6687
266695 Ga 31 69 Pb 82 206 Br 35 79 Pt 78 196 15.6482
33063 O 8 16 Pb 82 206 Mg 12 24 Pt 78 198 15.6361
283372 Ge 32 76 Pb 82 206 Kr 36 84 Pt 78 198 15.6230
303177 Se 34 78 Pb 82 204 Sr 38 87 Pt 78 195 15.5625
260944 Zn 30 67 Pb 82 206 Se 34 77 Pt 78 196 15.5373
234957 Ni 28 60 Pb 82 204 Ge 32 70 Pt 78 194 15.5233
415635 Pd 46 102 Pb 82 208 Sn 50 116 Pt 78 194 15.5224
191010 Cr 24 52 Pb 82 206 Ni 28 60 Pt 78 198 15.5066
415686 Pd 46 104 Pb 82 208 Sn 50 120 Pt 78 192 15.5038
261251 Zn 30 68 Pb 82 208 Se 34 78 Pt 78 198 15.4917
214920 Co 27 59 Pb 82 208 Ga 31 69 Pt 78 198 15.4833
453698 Sn 50 112 Pb 82 208 Xe 54 128 Pt 78 192 15.4777
327043 Kr 36 82 Pb 82 207 Zr 40 91 Pt 78 198 15.4637
194145 Mn 25 55 Pb 82 204 Cu 29 63 Pt 78 196 15.4134
235062 Ni 28 62 Pb 82 204 Ge 32 72 Pt 78 194 15.3901
191045 Cr 24 53 Pb 82 206 Ni 28 61 Pt 78 198 15.3864
399552 Ru 44 98 Pb 82 208 Cd 48 112 Pt 78 194 15.3641
326502 Kr 36 82 Pb 82 204 Zr 40 91 Pt 78 195 15.3529
241777 Cu 29 65 Pb 82 204 As 33 75 Pt 78 194 15.3371
435062 Cd 48 108 Pb 82 208 Te 52 124 Pt 78 192 15.3268
266749 Ga 31 69 Pb 82 208 Br 35 79 Pt 78 198 15.3212
399004 Ru 44 98 Pb 82 206 Cd 48 114 Pt 78 190 15.3007
20712 C 6 13 Pb 82 206 Ne 10 21 Pt 78 198 15.2961
92276 S 16 32 Pb 82 206 Ca 20 40 Pt 78 198 15.2774
415440 Pd 46 102 Pb 82 207 Sn 50 117 Pt 78 192 15.2281
261237 Zn 30 67 Pb 82 208 Se 34 77 Pt 78 198 15.2104
399311 Ru 44 99 Pb 82 207 Cd 48 112 Pt 78 194 15.2094
74970 Si 14 28 Pb 82 206 Ar 18 36 Pt 78 198 15.1787
261097 Zn 30 67 Pb 82 207 Se 34 76 Pt 78 198 15.1722
260896 Zn 30 66 Pb 82 206 Se 34 76 Pt 78 196 15.1684
235447 Ni 28 64 Pb 82 206 Ge 32 74 Pt 78 196 15.1591
453734 Sn 50 114 Pb 82 208 Xe 54 128 Pt 78 194 15.1424
380512 Mo 42 92 Pb 82 204 Pd 46 106 Pt 78 190 15.0986
467364 Te 52 120 Pb 82 208 Ba 56 138 Pt 78 190 15.0846
303176 Se 34 78 Pb 82 204 Sr 38 86 Pt 78 196 15.0678
260639 Zn 30 67 Pb 82 204 Se 34 76 Pt 78 195 15.0613
260832 Zn 30 64 Pb 82 206 Se 34 74 Pt 78 196 15.0529
92324 S 16 34 Pb 82 206 Ca 20 42 Pt 78 198 15.0464
380913 Mo 42 92 Pb 82 206 Pd 46 106 Pt 78 192 15.0026
453444 Sn 50 112 Pb 82 207 Xe 54 129 Pt 78 190 15.0008
260733 Zn 30 70 Pb 82 204 Se 34 78 Pt 78 196 14.9859
326869 Kr 36 82 Pb 82 206 Zr 40 90 Pt 78 198 14.9775
59677 Mg 12 26 Pb 82 204 S 16 32 Pt 78 198 14.9561
419377 Ag 47 107 Pb 82 208 Sb 51 123 Pt 78 192 14.9356
414863 Pd 46 102 Pb 82 204 Sn 50 116 Pt 78 190 14.8564
415508 Pd 46 105 Pb 82 207 Sn 50 118 Pt 78 194 14.8462
261204 Zn 30 66 Pb 82 208 Se 34 76 Pt 78 198 14.8415
415240 Pd 46 104 Pb 82 206 Sn 50 120 Pt 78 190 14.8350
235762 Ni 28 64 Pb 82 208 Ge 32 74 Pt 78 198 14.8322
235590 Ni 28 62 Pb 82 207 Ge 32 73 Pt 78 196 14.8126
453164 Sn 50 112 Pb 82 206 Xe 54 128 Pt 78 190 14.8089
235313 Ni 28 60 Pb 82 206 Ge 32 70 Pt 78 196 14.7837
415204 Pd 46 102 Pb 82 206 Sn 50 116 Pt 78 192 14.7605
261147 Zn 30 64 Pb 82 208 Se 34 74 Pt 78 198 14.7260
326908 Kr 36 83 Pb 82 206 Zr 40 91 Pt 78 198 14.7148
398594 Ru 44 98 Pb 82 204 Cd 48 112 Pt 78 190 14.6980
283113 Ge 32 74 Pb 82 204 Kr 36 82 Pt 78 196 14.6757
434879 Cd 48 111 Pb 82 207 Te 52 128 Pt 78 190 14.6692
260897 Zn 30 66 Pb 82 206 Se 34 77 Pt 78 195 14.6617
434544 Cd 48 108 Pb 82 206 Te 52 124 Pt 78 190 14.6580
434876 Cd 48 111 Pb 82 207 Te 52 126 Pt 78 192 14.6580
235406 Ni 28 62 Pb 82 206 Ge 32 72 Pt 78 196 14.6505
381271 Mo 42 95 Pb 82 207 Pd 46 110 Pt 78 192 14.6133
399001 Ru 44 98 Pb 82 206 Cd 48 112 Pt 78 192 14.6021
241909 Cu 29 65 Pb 82 206 As 33 75 Pt 78 196 14.5974
20678 C 6 12 Pb 82 204 Ne 10 20 Pt 78 196 14.5742
453467 Sn 50 114 Pb 82 207 Xe 54 129 Pt 78 192 14.5723
326593 Kr 36 84 Pb 82 204 Zr 40 94 Pt 78 194 14.5527
415685 Pd 46 104 Pb 82 208 Sn 50 118 Pt 78 194 14.5350
452773 Sn 50 114 Pb 82 204 Xe 54 128 Pt 78 190 14.4763
434809 Cd 48 108 Pb 82 207 Te 52 125 Pt 78 190 14.4642
343851 Sr 38 86 Pb 82 208 Mo 42 100 Pt 78 194 14.4605
235681 Ni 28 60 Pb 82 208 Ge 32 70 Pt 78 198 14.4568
478055 Xe 54 124 Pb 82 208 Ce 58 140 Pt 78 192 14.4512
381489 Mo 42 94 Pb 82 208 Pd 46 110 Pt 78 192 14.3953
453186 Sn 50 114 Pb 82 206 Xe 54 128 Pt 78 192 14.3804
343850 Sr 38 86 Pb 82 208 Mo 42 98 Pt 78 196 14.3571
169480 Ti 22 50 Pb 82 204 Fe 26 56 Pt 78 198 14.3422
343272 Sr 38 86 Pb 82 204 Mo 42 98 Pt 78 192 14.3348
283467 Ge 32 74 Pb 82 207 Kr 36 83 Pt 78 198 14.3329
343553 Sr 38 86 Pb 82 206 Mo 42 98 Pt 78 194 14.3320
235740 Ni 28 62 Pb 82 208 Ge 32 72 Pt 78 198 14.3236
194193 Mn 25 55 Pb 82 206 Cu 29 63 Pt 78 198 14.3217
467362 Te 52 120 Pb 82 208 Ba 56 136 Pt 78 192 14.3115
399273 Ru 44 98 Pb 82 207 Cd 48 113 Pt 78 192 14.3059
241966 Cu 29 65 Pb 82 208 As 33 75 Pt 78 198 14.2705
419297 Ag 47 107 Pb 82 206 Sb 51 123 Pt 78 190 14.2668
453500 Sn 50 115 Pb 82 207 Xe 54 132 Pt 78 190 14.2668
211119 Fe 26 58 Pb 82 204 Zn 30 66 Pt 78 196 14.2630
399605 Ru 44 99 Pb 82 208 Cd 48 113 Pt 78 194 14.2556
113565 Ar 18 40 Pb 82 204 Ti 22 46 Pt 78 198 14.2425
435025 Cd 48 106 Pb 82 208 Te 52 120 Pt 78 194 14.2276
283114 Ge 32 74 Pb 82 204 Kr 36 83 Pt 78 195 14.2221
399500 Ru 44 96 Pb 82 208 Cd 48 108 Pt 78 196 14.2174
398573 Ru 44 96 Pb 82 204 Cd 48 108 Pt 78 192 14.1950
398965 Ru 44 96 Pb 82 206 Cd 48 108 Pt 78 194 14.1922
343214 Sr 38 84 Pb 82 204 Mo 42 92 Pt 78 196 14.1345
415735 Pd 46 105 Pb 82 208 Sn 50 119 Pt 78 194 14.0507
399604 Ru 44 99 Pb 82 208 Cd 48 112 Pt 78 195 14.0320
419375 Ag 47 107 Pb 82 208 Sb 51 121 Pt 78 194 14.0227
235549 Ni 28 61 Pb 82 207 Ge 32 70 Pt 78 198 14.0097
303469 Se 34 78 Pb 82 206 Sr 38 86 Pt 78 198 13.9761
415772 Pd 46 106 Pb 82 208 Sn 50 122 Pt 78 192 13.9761
326592 Kr 36 84 Pb 82 204 Zr 40 92 Pt 78 196 13.9743
146475 Ca 20 44 Pb 82 204 Cr 24 50 Pt 78 198 13.9519
343271 Sr 38 86 Pb 82 204 Mo 42 96 Pt 78 194 13.9435
327252 Kr 36 84 Pb 82 208 Zr 40 96 Pt 78 196 13.9417
435115 Cd 48 110 Pb 82 208 Te 52 128 Pt 78 190 13.9296
326594 Kr 36 84 Pb 82 204 Zr 40 96 Pt 78 192 13.9193
435112 Cd 48 110 Pb 82 208 Te 52 126 Pt 78 192 13.9184
326932 Kr 36 84 Pb 82 206 Zr 40 96 Pt 78 194 13.9165
235016 Ni 28 61 Pb 82 204 Ge 32 70 Pt 78 195 13.8988
261006 Zn 30 70 Pb 82 206 Se 34 78 Pt 78 198 13.8942
415770 Pd 46 106 Pb 82 208 Sn 50 120 Pt 78 194 13.8830
467205 Te 52 120 Pb 82 207 Ba 56 137 Pt 78 190 13.8774
414884 Pd 46 104 Pb 82 204 Sn 50 118 Pt 78 190 13.8690
381269 Mo 42 95 Pb 82 207 Pd 46 108 Pt 78 194 13.8681
434875 Cd 48 111 Pb 82 207 Te 52 124 Pt 78 194 13.8215
435061 Cd 48 108 Pb 82 208 Te 52 122 Pt 78 194 13.8178
326931 Kr 36 84 Pb 82 206 Zr 40 94 Pt 78 196 13.8131
343707 Sr 38 86 Pb 82 207 Mo 42 98 Pt 78 195 13.8122
343274 Sr 38 86 Pb 82 204 Mo 42 100 Pt 78 190 13.7945
477719 Xe 54 124 Pb 82 206 Ce 58 140 Pt 78 190 13.7824
415239 Pd 46 104 Pb 82 206 Sn 50 118 Pt 78 192 13.7731
381196 Mo 42 92 Pb 82 207 Pd 46 105 Pt 78 194 13.7284
380965 Mo 42 94 Pb 82 206 Pd 46 110 Pt 78 190 13.7265
343554 Sr 38 86 Pb 82 206 Mo 42 100 Pt 78 192 13.6986
399244 Ru 44 96 Pb 82 207 Cd 48 108 Pt 78 195 13.6725
415734 Pd 46 105 Pb 82 208 Sn 50 118 Pt 78 195 13.6687
381487 Mo 42 94 Pb 82 208 Pd 46 108 Pt 78 194 13.6501
415775 Pd 46 106 Pb 82 208 Sn 50 124 Pt 78 190 13.6501
467010 Te 52 120 Pb 82 206 Ba 56 136 Pt 78 190 13.6427
415469 Pd 46 104 Pb 82 207 Sn 50 119 Pt 78 192 13.6352
235407 Ni 28 62 Pb 82 206 Ge 32 73 Pt 78 195 13.6101
453697 Sn 50 112 Pb 82 208 Xe 54 126 Pt 78 194 13.6045
398623 Ru 44 99 Pb 82 204 Cd 48 113 Pt 78 190 13.5896
283348 Ge 32 74 Pb 82 206 Kr 36 82 Pt 78 198 13.5840
266611 Ga 31 71 Pb 82 204 Br 35 79 Pt 78 196 13.5812
434139 Cd 48 106 Pb 82 204 Te 52 120 Pt 78 190 13.5616
20715 C 6 12 Pb 82 207 Ne 10 21 Pt 78 198 13.5244
415439 Pd 46 102 Pb 82 207 Sn 50 115 Pt 78 194 13.5048
211504 Fe 26 58 Pb 82 207 Zn 30 67 Pt 78 198 13.4983
453498 Sn 50 115 Pb 82 207 Xe 54 130 Pt 78 192 13.4955
399043 Ru 44 99 Pb 82 206 Cd 48 113 Pt 78 192 13.4936
327251 Kr 36 84 Pb 82 208 Zr 40 94 Pt 78 198 13.4862
20704 C 6 12 Pb 82 206 Ne 10 20 Pt 78 198 13.4824
434520 Cd 48 106 Pb 82 206 Te 52 120 Pt 78 192 13.4657
434956 Cd 48 113 Pb 82 207 Te 52 126 Pt 78 194 13.4657
343706 Sr 38 86 Pb 82 207 Mo 42 97 Pt 78 196 13.4387
343739 Sr 38 87 Pb 82 207 Mo 42 100 Pt 78 194 13.4210
20679 C 6 12 Pb 82 204 Ne 10 21 Pt 78 195 13.4135
381429 Mo 42 92 Pb 82 208 Pd 46 104 Pt 78 196 13.4070
419400 Ag 47 109 Pb 82 208 Sb 51 123 Pt 78 194 13.3986
327092 Kr 36 84 Pb 82 207 Zr 40 96 Pt 78 195 13.3967
211120 Fe 26 58 Pb 82 204 Zn 30 67 Pt 78 195 13.3874
380511 Mo 42 92 Pb 82 204 Pd 46 104 Pt 78 192 13.3846
414913 Pd 46 105 Pb 82 204 Sn 50 119 Pt 78 190 13.3846
434958 Cd 48 113 Pb 82 207 Te 52 128 Pt 78 192 13.3837
380912 Mo 42 92 Pb 82 206 Pd 46 104 Pt 78 194 13.3818
415814 Pd 46 108 Pb 82 208 Sn 50 122 Pt 78 194 13.3614
419152 Ag 47 107 Pb 82 204 Sb 51 121 Pt 78 190 13.3567
381357 Mo 42 97 Pb 82 207 Pd 46 110 Pt 78 194 13.3558
343738 Sr 38 87 Pb 82 207 Mo 42 98 Pt 78 196 13.3176
434808 Cd 48 108 Pb 82 207 Te 52 123 Pt 78 192 13.3092
415320 Pd 46 106 Pb 82 206 Sn 50 122 Pt 78 190 13.3073
415280 Pd 46 105 Pb 82 206 Sn 50 119 Pt 78 192 13.2887
419295 Ag 47 107 Pb 82 206 Sb 51 121 Pt 78 192 13.2608
478054 Xe 54 124 Pb 82 208 Ce 58 138 Pt 78 194 13.2589
434579 Cd 48 110 Pb 82 206 Te 52 126 Pt 78 190 13.2496
399550 Ru 44 98 Pb 82 208 Cd 48 110 Pt 78 196 13.2207
414944 Pd 46 106 Pb 82 204 Sn 50 120 Pt 78 190 13.2170
343551 Sr 38 86 Pb 82 206 Mo 42 96 Pt 78 196 13.2039
398593 Ru 44 98 Pb 82 204 Cd 48 110 Pt 78 192 13.1983
399000 Ru 44 98 Pb 82 206 Cd 48 110 Pt 78 194 13.1955
211383 Fe 26 58 Pb 82 206 Zn 30 66 Pt 78 198 13.1713
434152 Cd 48 108 Pb 82 204 Te 52 122 Pt 78 190 13.1518
415317 Pd 46 106 Pb 82 206 Sn 50 120 Pt 78 192 13.1210
399272 Ru 44 98 Pb 82 207 Cd 48 111 Pt 78 194 13.1136
435111 Cd 48 110 Pb 82 208 Te 52 124 Pt 78 194 13.0819
467361 Te 52 120 Pb 82 208 Ba 56 134 Pt 78 194 13.0726
399309 Ru 44 99 Pb 82 207 Cd 48 110 Pt 78 196 13.0661
434543 Cd 48 108 Pb 82 206 Te 52 122 Pt 78 192 13.0558
343484 Sr 38 84 Pb 82 206 Mo 42 92 Pt 78 198 13.0428
235122 Ni 28 64 Pb 82 204 Ge 32 72 Pt 78 196 13.0083
303072 Se 34 76 Pb 82 204 Sr 38 84 Pt 78 196 12.9860
380544 Mo 42 94 Pb 82 204 Pd 46 108 Pt 78 190 12.9841
435158 Cd 48 111 Pb 82 208 Te 52 125 Pt 78 194 12.9701
415816 Pd 46 108 Pb 82 208 Sn 50 124 Pt 78 192 12.9422
452759 Sn 50 112 Pb 82 204 Xe 54 126 Pt 78 190 12.9385
381575 Mo 42 96 Pb 82 208 Pd 46 110 Pt 78 194 12.9329
211014 Fe 26 56 Pb 82 204 Zn 30 64 Pt 78 196 12.9245
169407 Ti 22 48 Pb 82 204 Fe 26 54 Pt 78 198 12.9161
434960 Cd 48 113 Pb 82 207 Te 52 130 Pt 78 190 12.9086
380962 Mo 42 94 Pb 82 206 Pd 46 108 Pt 78 192 12.8882
326930 Kr 36 84 Pb 82 206 Zr 40 92 Pt 78 198 12.8826
343849 Sr 38 86 Pb 82 208 Mo 42 96 Pt 78 198 12.8770
381195 Mo 42 92 Pb 82 207 Pd 46 104 Pt 78 195 12.8621
283024 Ge 32 72 Pb 82 204 Kr 36 80 Pt 78 196 12.8425
453163 Sn 50 112 Pb 82 206 Xe 54 126 Pt 78 192 12.8425
330609 Rb 37 85 Pb 82 204 Nb 41 93 Pt 78 196 12.8341
478057 Xe 54 124 Pb 82 208 Ce 58 142 Pt 78 190 12.8304
438254 In 49 113 Pb 82 208 I 53 127 Pt 78 194 12.8192
260681 Zn 30 68 Pb 82 204 Se 34 76 Pt 78 196 12.7838
419170 Ag 47 109 Pb 82 204 Sb 51 123 Pt 78 190 12.7326
453777 Sn 50 115 Pb 82 208 Xe 54 131 Pt 78 192 12.7214
399402 Ru 44 101 Pb 82 207 Cd 48 114 Pt 78 194 12.7037
467265 Te 52 123 Pb 82 207 Ba 56 138 Pt 78 192 12.7037
190863 Cr 24 54 Pb 82 204 Ni 28 60 Pt 78 198 12.7009
414991 Pd 46 108 Pb 82 204 Sn 50 122 Pt 78 190 12.6953
381539 Mo 42 95 Pb 82 208 Pd 46 108 Pt 78 195 12.6907
453578 Sn 50 117 Pb 82 207 Xe 54 134 Pt 78 190 12.6776
399271 Ru 44 98 Pb 82 207 Cd 48 110 Pt 78 195 12.6758
415468 Pd 46 104 Pb 82 207 Sn 50 117 Pt 78 194 12.6571
399404 Ru 44 101 Pb 82 207 Cd 48 116 Pt 78 192 12.6478
435157 Cd 48 111 Pb 82 208 Te 52 124 Pt 78 195 12.6441
419318 Ag 47 109 Pb 82 206 Sb 51 123 Pt 78 192 12.6366
415369 Pd 46 108 Pb 82 206 Sn 50 122 Pt 78 192 12.5994
477430 Xe 54 124 Pb 82 204 Ce 58 138 Pt 78 190 12.5929
381430 Mo 42 92 Pb 82 208 Pd 46 105 Pt 78 195 12.5510
453733 Sn 50 114 Pb 82 208 Xe 54 126 Pt 78 196 12.5323
415813 Pd 46 108 Pb 82 208 Sn 50 120 Pt 78 196 12.5314
415506 Pd 46 105 Pb 82 207 Sn 50 116 Pt 78 196 12.5258
381268 Mo 42 95 Pb 82 207 Pd 46 106 Pt 78 196 12.5165
435193 Cd 48 112 Pb 82 208 Te 52 126 Pt 78 194 12.5118
452772 Sn 50 114 Pb 82 204 Xe 54 126 Pt 78 192 12.5100
414988 Pd 46 108 Pb 82 204 Sn 50 120 Pt 78 192 12.5090
453185 Sn 50 114 Pb 82 206 Xe 54 126 Pt 78 194 12.5072
415367 Pd 46 108 Pb 82 206 Sn 50 120 Pt 78 194 12.5062
283152 Ge 32 76 Pb 82 204 Kr 36 82 Pt 78 198 12.4969
477718 Xe 54 124 Pb 82 206 Ce 58 138 Pt 78 192 12.4969
266721 Ga 31 71 Pb 82 206 Br 35 79 Pt 78 198 12.4895
467204 Te 52 120 Pb 82 207 Ba 56 135 Pt 78 192 12.4895
453815 Sn 50 116 Pb 82 208 Xe 54 134 Pt 78 190 12.4876
343330 Sr 38 87 Pb 82 204 Mo 42 97 Pt 78 194 12.4811
453575 Sn 50 117 Pb 82 207 Xe 54 132 Pt 78 192 12.4504
435195 Cd 48 112 Pb 82 208 Te 52 128 Pt 78 192 12.4299
380757 Mo 42 100 Pb 82 204 Pd 46 110 Pt 78 194 12.4159
434174 Cd 48 110 Pb 82 204 Te 52 124 Pt 78 190 12.4159
466715 Te 52 120 Pb 82 204 Ba 56 134 Pt 78 190 12.4066
261129 Zn 30 68 Pb 82 207 Se 34 77 Pt 78 198 12.3879
399643 Ru 44 100 Pb 82 208 Cd 48 114 Pt 78 194 12.3740
415733 Pd 46 105 Pb 82 208 Sn 50 117 Pt 78 196 12.3358
415634 Pd 46 102 Pb 82 208 Sn 50 115 Pt 78 195 12.3274
399603 Ru 44 99 Pb 82 208 Cd 48 111 Pt 78 196 12.3265
434577 Cd 48 110 Pb 82 206 Te 52 124 Pt 78 192 12.3199
399645 Ru 44 100 Pb 82 208 Cd 48 116 Pt 78 192 12.3181
414912 Pd 46 105 Pb 82 204 Sn 50 117 Pt 78 192 12.3134
415279 Pd 46 105 Pb 82 206 Sn 50 117 Pt 78 194 12.3106
467009 Te 52 120 Pb 82 206 Ba 56 134 Pt 78 192 12.3106
398622 Ru 44 99 Pb 82 204 Cd 48 111 Pt 78 192 12.3041
434204 Cd 48 111 Pb 82 204 Te 52 125 Pt 78 190 12.3041
399042 Ru 44 99 Pb 82 206 Cd 48 111 Pt 78 194 12.3013
467407 Te 52 122 Pb 82 208 Ba 56 138 Pt 78 192 12.2994
381486 Mo 42 94 Pb 82 208 Pd 46 106 Pt 78 196 12.2985
435229 Cd 48 113 Pb 82 208 Te 52 126 Pt 78 195 12.2883
260682 Zn 30 68 Pb 82 204 Se 34 77 Pt 78 195 12.2771
380541 Mo 42 94 Pb 82 204 Pd 46 106 Pt 78 192 12.2762
380960 Mo 42 94 Pb 82 206 Pd 46 106 Pt 78 194 12.2734
415372 Pd 46 108 Pb 82 206 Sn 50 124 Pt 78 190 12.2734
380624 Mo 42 96 Pb 82 204 Pd 46 110 Pt 78 190 12.2668
2392 D 1 2 Pb 82 207 B 5 11 Pt 78 198 12.2631
453812 Sn 50 116 Pb 82 208 Xe 54 132 Pt 78 192 12.2603
343884 Sr 38 87 Pb 82 208 Mo 42 100 Pt 78 195 12.2436
343552 Sr 38 86 Pb 82 206 Mo 42 97 Pt 78 195 12.2361
415683 Pd 46 104 Pb 82 208 Sn 50 116 Pt 78 196 12.2147
434620 Cd 48 111 Pb 82 206 Te 52 125 Pt 78 192 12.2082
415841 Pd 46 110 Pb 82 208 Sn 50 124 Pt 78 194 12.1970
414883 Pd 46 104 Pb 82 204 Sn 50 116 Pt 78 192 12.1923
415238 Pd 46 104 Pb 82 206 Sn 50 116 Pt 78 194 12.1895
453497 Sn 50 115 Pb 82 207 Xe 54 128 Pt 78 194 12.1839
381610 Mo 42 97 Pb 82 208 Pd 46 110 Pt 78 195 12.1784
415768 Pd 46 106 Pb 82 208 Sn 50 118 Pt 78 196 12.1774
381052 Mo 42 96 Pb 82 206 Pd 46 110 Pt 78 192 12.1709
414943 Pd 46 106 Pb 82 204 Sn 50 118 Pt 78 192 12.1551
438048 In 49 113 Pb 82 204 I 53 127 Pt 78 190 12.1532
2376 D 1 2 Pb 82 204 B 5 11 Pt 78 195 12.1523
415316 Pd 46 106 Pb 82 206 Sn 50 118 Pt 78 194 12.1523
434837 Cd 48 110 Pb 82 207 Te 52 125 Pt 78 192 12.1262
343604 Sr 38 87 Pb 82 206 Mo 42 98 Pt 78 195 12.1150
235604 Ni 28 64 Pb 82 207 Ge 32 73 Pt 78 198 12.0787
438178 In 49 113 Pb 82 206 I 53 127 Pt 78 192 12.0573
453219 Sn 50 115 Pb 82 206 Xe 54 131 Pt 78 190 12.0526
467264 Te 52 123 Pb 82 207 Ba 56 136 Pt 78 194 12.0237
415557 Pd 46 106 Pb 82 207 Sn 50 119 Pt 78 194 12.0144
453466 Sn 50 114 Pb 82 207 Xe 54 126 Pt 78 195 11.9874
415587 Pd 46 108 Pb 82 207 Sn 50 120 Pt 78 195 11.9865
235123 Ni 28 64 Pb 82 204 Ge 32 73 Pt 78 195 11.9678
435197 Cd 48 112 Pb 82 208 Te 52 130 Pt 78 190 11.9548
399551 Ru 44 98 Pb 82 208 Cd 48 111 Pt 78 195 11.9362
359319 Zr 40 91 Pb 82 207 Ru 44 104 Pt 78 194 11.9306
235446 Ni 28 64 Pb 82 206 Ge 32 72 Pt 78 198 11.9166
303222 Se 34 80 Pb 82 204 Sr 38 86 Pt 78 198 11.9147
303390 Se 34 76 Pb 82 206 Sr 38 84 Pt 78 198 11.8942
434954 Cd 48 113 Pb 82 207 Te 52 124 Pt 78 196 11.8924
415840 Pd 46 110 Pb 82 208 Sn 50 122 Pt 78 196 11.8793
381356 Mo 42 97 Pb 82 207 Pd 46 108 Pt 78 196 11.8738
399041 Ru 44 99 Pb 82 206 Cd 48 110 Pt 78 195 11.8635
415039 Pd 46 110 Pb 82 204 Sn 50 122 Pt 78 192 11.8570
415410 Pd 46 110 Pb 82 206 Sn 50 122 Pt 78 194 11.8542
326591 Kr 36 84 Pb 82 204 Zr 40 90 Pt 78 198 11.8514
434233 Cd 48 112 Pb 82 204 Te 52 126 Pt 78 190 11.8458
343737 Sr 38 87 Pb 82 207 Mo 42 96 Pt 78 198 11.8374
211306 Fe 26 56 Pb 82 206 Zn 30 64 Pt 78 198 11.8328
435252 Cd 48 114 Pb 82 208 Te 52 128 Pt 78 194 11.8244
326633 Kr 36 86 Pb 82 204 Zr 40 96 Pt 78 194 11.8076
381633 Mo 42 98 Pb 82 208 Pd 46 110 Pt 78 196 11.8048
415507 Pd 46 105 Pb 82 207 Sn 50 117 Pt 78 195 11.7909
380708 Mo 42 98 Pb 82 204 Pd 46 110 Pt 78 192 11.7825
399310 Ru 44 99 Pb 82 207 Cd 48 111 Pt 78 195 11.7815
381134 Mo 42 98 Pb 82 206 Pd 46 110 Pt 78 194 11.7797
453574 Sn 50 117 Pb 82 207 Xe 54 130 Pt 78 194 11.7722
415037 Pd 46 110 Pb 82 204 Sn 50 120 Pt 78 194 11.7638
434658 Cd 48 112 Pb 82 206 Te 52 128 Pt 78 190 11.7610
359408 Zr 40 90 Pb 82 208 Ru 44 104 Pt 78 194 11.7592
381230 Mo 42 94 Pb 82 207 Pd 46 106 Pt 78 195 11.7536
283287 Ge 32 72 Pb 82 206 Kr 36 80 Pt 78 198 11.7508
434655 Cd 48 112 Pb 82 206 Te 52 126 Pt 78 192 11.7499
419399 Ag 47 109 Pb 82 208 Sb 51 121 Pt 78 196 11.7489
343269 Sr 38 86 Pb 82 204 Mo 42 94 Pt 78 196 11.7443
330701 Rb 37 85 Pb 82 206 Nb 41 93 Pt 78 198 11.7424
343603 Sr 38 87 Pb 82 206 Mo 42 97 Pt 78 196 11.7415
343329 Sr 38 87 Pb 82 204 Mo 42 96 Pt 78 195 11.7266
419168 Ag 47 109 Pb 82 204 Sb 51 121 Pt 78 192 11.7266
419316 Ag 47 109 Pb 82 206 Sb 51 121 Pt 78 194 11.7238
453776 Sn 50 115 Pb 82 208 Xe 54 129 Pt 78 194 11.7182
398655 Ru 44 100 Pb 82 204 Cd 48 114 Pt 78 190 11.7079
326632 Kr 36 86 Pb 82 204 Zr 40 94 Pt 78 196 11.7042
260973 Zn 30 68 Pb 82 206 Se 34 76 Pt 78 198 11.6921
399722 Ru 44 102 Pb 82 208 Cd 48 116 Pt 78 194 11.6847
381169 Mo 42 100 Pb 82 206 Pd 46 110 Pt 78 196 11.6763
415467 Pd 46 104 Pb 82 207 Sn 50 116 Pt 78 195 11.6698
399084 Ru 44 100 Pb 82 206 Cd 48 116 Pt 78 190 11.6493
467320 Te 52 125 Pb 82 207 Ba 56 138 Pt 78 194 11.6418
415556 Pd 46 106 Pb 82 207 Sn 50 118 Pt 78 195 11.6325
467046 Te 52 122 Pb 82 206 Ba 56 138 Pt 78 190 11.6306
467406 Te 52 122 Pb 82 208 Ba 56 136 Pt 78 194 11.6195
399081 Ru 44 100 Pb 82 206 Cd 48 114 Pt 78 192 11.6120
453646 Sn 50 119 Pb 82 207 Xe 54 134 Pt 78 192 11.6064
467437 Te 52 123 Pb 82 208 Ba 56 137 Pt 78 194 11.6008
359318 Zr 40 91 Pb 82 207 Ru 44 102 Pt 78 196 11.5943
453250 Sn 50 116 Pb 82 206 Xe 54 132 Pt 78 190 11.5915
453811 Sn 50 116 Pb 82 208 Xe 54 130 Pt 78 194 11.5822
434873 Cd 48 111 Pb 82 207 Te 52 122 Pt 78 196 11.5757
401879 Rh 45 103 Pb 82 208 In 49 115 Pt 78 196 11.5440
414987 Pd 46 108 Pb 82 204 Sn 50 118 Pt 78 194 11.5403
415042 Pd 46 110 Pb 82 204 Sn 50 124 Pt 78 190 11.5310
399692 Ru 44 101 Pb 82 208 Cd 48 114 Pt 78 195 11.5263
401759 Rh 45 103 Pb 82 204 In 49 115 Pt 78 192 11.5217
401833 Rh 45 103 Pb 82 206 In 49 115 Pt 78 194 11.5189
415684 Pd 46 104 Pb 82 208 Sn 50 117 Pt 78 195 11.4797
453644 Sn 50 119 Pb 82 207 Xe 54 132 Pt 78 194 11.4723
381574 Mo 42 96 Pb 82 208 Pd 46 108 Pt 78 196 11.4509
415412 Pd 46 110 Pb 82 206 Sn 50 124 Pt 78 192 11.4350
380621 Mo 42 96 Pb 82 204 Pd 46 108 Pt 78 192 11.4285
381050 Mo 42 96 Pb 82 206 Pd 46 108 Pt 78 194 11.4257
359407 Zr 40 90 Pb 82 208 Ru 44 102 Pt 78 196 11.4229
343883 Sr 38 87 Pb 82 208 Mo 42 97 Pt 78 198 11.4145
358814 Zr 40 90 Pb 82 204 Ru 44 102 Pt 78 192 11.4006
359097 Zr 40 90 Pb 82 206 Ru 44 102 Pt 78 194 11.3978
398781 Ru 44 104 Pb 82 204 Cd 48 114 Pt 78 194 11.3819
399400 Ru 44 101 Pb 82 207 Cd 48 112 Pt 78 196 11.3614
381655 Mo 42 100 Pb 82 208 Pd 46 110 Pt 78 198 11.3493
399752 Ru 44 104 Pb 82 208 Cd 48 116 Pt 78 196 11.3484
478092 Xe 54 126 Pb 82 208 Ce 58 140 Pt 78 194 11.3484
415610 Pd 46 110 Pb 82 207 Sn 50 122 Pt 78 195 11.3344
398783 Ru 44 104 Pb 82 204 Cd 48 116 Pt 78 192 11.3260
399213 Ru 44 104 Pb 82 206 Cd 48 116 Pt 78 194 11.3232
415278 Pd 46 105 Pb 82 206 Sn 50 116 Pt 78 195 11.3232
381013 Mo 42 95 Pb 82 206 Pd 46 106 Pt 78 195 11.3139
435274 Cd 48 116 Pb 82 208 Te 52 130 Pt 78 194 11.3121
456498 Sb 51 121 Pb 82 208 Cs* 55 137 Pt 78 192 11.3121
453648 Sn 50 119 Pb 82 207 Xe 54 136 Pt 78 190 11.2869
282953 Ge 32 70 Pb 82 204 Kr 36 78 Pt 78 196 11.2683
381391 Mo 42 98 Pb 82 207 Pd 46 110 Pt 78 195 11.2599
435253 Cd 48 114 Pb 82 208 Te 52 130 Pt 78 192 11.2562
235061 Ni 28 62 Pb 82 204 Ge 32 70 Pt 78 196 11.2301
419355 Ag 47 109 Pb 82 207 Sb 51 121 Pt 78 195 11.2040
434354 Cd 48 116 Pb 82 204 Te 52 126 Pt 78 194 11.2031
435156 Cd 48 111 Pb 82 208 Te 52 123 Pt 78 196 11.1714
435251 Cd 48 114 Pb 82 208 Te 52 126 Pt 78 196 11.1695
434309 Cd 48 114 Pb 82 204 Te 52 128 Pt 78 190 11.1584
434203 Cd 48 111 Pb 82 204 Te 52 123 Pt 78 192 11.1491
434306 Cd 48 114 Pb 82 204 Te 52 126 Pt 78 192 11.1472
434619 Cd 48 111 Pb 82 206 Te 52 123 Pt 78 194 11.1463
434732 Cd 48 114 Pb 82 206 Te 52 126 Pt 78 194 11.1444
435273 Cd 48 116 Pb 82 208 Te 52 128 Pt 78 196 11.1435
434356 Cd 48 116 Pb 82 204 Te 52 128 Pt 78 192 11.1211
434767 Cd 48 116 Pb 82 206 Te 52 128 Pt 78 194 11.1183
358817 Zr 40 90 Pb 82 204 Ru 44 104 Pt 78 190 11.0932
398572 Ru 44 96 Pb 82 204 Cd 48 106 Pt 78 194 11.0932
343705 Sr 38 86 Pb 82 207 Mo 42 95 Pt 78 198 11.0922
467231 Te 52 122 Pb 82 207 Ba 56 137 Pt 78 192 11.0922
326957 Kr 36 86 Pb 82 206 Zr 40 96 Pt 78 196 11.0680
434836 Cd 48 110 Pb 82 207 Te 52 123 Pt 78 194 11.0643
434734 Cd 48 114 Pb 82 206 Te 52 128 Pt 78 192 11.0624
452792 Sn 50 115 Pb 82 204 Xe 54 129 Pt 78 190 11.0522
435228 Cd 48 113 Pb 82 208 Te 52 125 Pt 78 196 11.0410
380706 Mo 42 98 Pb 82 204 Pd 46 108 Pt 78 194 11.0373
399641 Ru 44 100 Pb 82 208 Cd 48 112 Pt 78 196 11.0317
415409 Pd 46 110 Pb 82 206 Sn 50 120 Pt 78 196 11.0242
398732 Ru 44 102 Pb 82 204 Cd 48 116 Pt 78 190 11.0186
434272 Cd 48 113 Pb 82 204 Te 52 125 Pt 78 192 11.0186
434700 Cd 48 113 Pb 82 206 Te 52 125 Pt 78 194 11.0158
398652 Ru 44 100 Pb 82 204 Cd 48 112 Pt 78 192 11.0093
399079 Ru 44 100 Pb 82 206 Cd 48 112 Pt 78 194 11.0065
453775 Sn 50 115 Pb 82 208 Xe 54 128 Pt 78 195 11.0065
399721 Ru 44 102 Pb 82 208 Cd 48 114 Pt 78 196 11.0037
401856 Rh 45 103 Pb 82 207 In 49 115 Pt 78 195 10.9991
453851 Sn 50 117 Pb 82 208 Xe 54 131 Pt 78 194 10.9982
359099 Zr 40 90 Pb 82 206 Ru 44 104 Pt 78 192 10.9972
343270 Sr 38 86 Pb 82 204 Mo 42 95 Pt 78 195 10.9814
398729 Ru 44 102 Pb 82 204 Cd 48 114 Pt 78 192 10.9814
399165 Ru 44 102 Pb 82 206 Cd 48 114 Pt 78 194 10.9786
453218 Sn 50 115 Pb 82 206 Xe 54 129 Pt 78 192 10.9562
398592 Ru 44 98 Pb 82 204 Cd 48 108 Pt 78 194 10.9534
466737 Te 52 122 Pb 82 204 Ba 56 136 Pt 78 190 10.9534
74929 Si 14 30 Pb 82 204 Ar 18 36 Pt 78 198 10.9469
435191 Cd 48 112 Pb 82 208 Te 52 124 Pt 78 196 10.9385
466768 Te 52 123 Pb 82 204 Ba 56 137 Pt 78 190 10.9348
380756 Mo 42 100 Pb 82 204 Pd 46 108 Pt 78 196 10.9339
399167 Ru 44 102 Pb 82 206 Cd 48 116 Pt 78 192 10.9227
434231 Cd 48 112 Pb 82 204 Te 52 124 Pt 78 192 10.9162
452814 Sn 50 116 Pb 82 204 Xe 54 130 Pt 78 190 10.9162
434654 Cd 48 112 Pb 82 206 Te 52 124 Pt 78 194 10.9134
381320 Mo 42 96 Pb 82 207 Pd 46 108 Pt 78 195 10.9059
260581 Zn 30 66 Pb 82 204 Se 34 74 Pt 78 196 10.8854
359278 Zr 40 90 Pb 82 207 Ru 44 102 Pt 78 195 10.8780
260732 Zn 30 70 Pb 82 204 Se 34 76 Pt 78 198 10.8594
467044 Te 52 122 Pb 82 206 Ba 56 136 Pt 78 192 10.8575
467436 Te 52 123 Pb 82 208 Ba 56 136 Pt 78 195 10.8463
467081 Te 52 123 Pb 82 206 Ba 56 137 Pt 78 192 10.8389
415769 Pd 46 106 Pb 82 208 Sn 50 119 Pt 78 195 10.8370
435109 Cd 48 110 Pb 82 208 Te 52 122 Pt 78 196 10.8361
453248 Sn 50 116 Pb 82 206 Xe 54 130 Pt 78 192 10.8202
380510 Mo 42 92 Pb 82 204 Pd 46 102 Pt 78 194 10.8137
380619 Mo 42 96 Pb 82 204 Pd 46 106 Pt 78 194 10.8137
434173 Cd 48 110 Pb 82 204 Te 52 122 Pt 78 192 10.8137
434576 Cd 48 110 Pb 82 206 Te 52 122 Pt 78 194 10.8109
453884 Sn 50 118 Pb 82 208 Xe 54 134 Pt 78 192 10.8109
399476 Ru 44 104 Pb 82 207 Cd 48 116 Pt 78 195 10.8035
415365 Pd 46 108 Pb 82 206 Sn 50 118 Pt 78 196 10.8007
467463 Te 52 124 Pb 82 208 Ba 56 138 Pt 78 194 10.7904
326631 Kr 36 86 Pb 82 204 Zr 40 92 Pt 78 198 10.7737
358813 Zr 40 90 Pb 82 204 Ru 44 100 Pt 78 194 10.7671
359452 Zr 40 91 Pb 82 208 Ru 44 104 Pt 78 195 10.7532
327264 Kr 36 86 Pb 82 208 Zr 40 96 Pt 78 198 10.7411
434920 Cd 48 112 Pb 82 207 Te 52 125 Pt 78 194 10.7196
399363 Ru 44 100 Pb 82 207 Cd 48 113 Pt 78 194 10.7103
453539 Sn 50 116 Pb 82 207 Xe 54 131 Pt 78 192 10.7038
415839 Pd 46 110 Pb 82 208 Sn 50 120 Pt 78 198 10.6973
361724 Nb 41 93 Pb 82 204 Rh 45 103 Pt 78 194 10.6926
434699 Cd 48 113 Pb 82 206 Te 52 124 Pt 78 195 10.6898
477446 Xe 54 126 Pb 82 204 Ce 58 140 Pt 78 190 10.6824
453882 Sn 50 118 Pb 82 208 Xe 54 132 Pt 78 194 10.6768
381100 Mo 42 97 Pb 82 206 Pd 46 108 Pt 78 195 10.6712
415586 Pd 46 108 Pb 82 207 Sn 50 119 Pt 78 196 10.6628
380540 Mo 42 94 Pb 82 204 Pd 46 104 Pt 78 194 10.6554
343549 Sr 38 86 Pb 82 206 Mo 42 94 Pt 78 198 10.6526
434358 Cd 48 116 Pb 82 204 Te 52 130 Pt 78 190 10.6460
456445 Sb 51 121 Pb 82 206 Cs* 55 137 Pt 78 190 10.6433
399212 Ru 44 104 Pb 82 206 Cd 48 114 Pt 78 196 10.6423
434874 Cd 48 111 Pb 82 207 Te 52 123 Pt 78 195 10.6265
434991 Cd 48 114 Pb 82 207 Te 52 126 Pt 78 195 10.6246
326956 Kr 36 86 Pb 82 206 Zr 40 94 Pt 78 198 10.6125
358867 Zr 40 91 Pb 82 204 Ru 44 101 Pt 78 194 10.6088
438277 In 49 115 Pb 82 208 I 53 127 Pt 78 196 10.6013
435011 Cd 48 116 Pb 82 207 Te 52 128 Pt 78 195 10.5985
453850 Sn 50 117 Pb 82 208 Xe 54 130 Pt 78 195 10.5948
414911 Pd 46 105 Pb 82 204 Sn 50 115 Pt 78 194 10.5902
434736 Cd 48 114 Pb 82 206 Te 52 130 Pt 78 190 10.5874
477743 Xe 54 126 Pb 82 206 Ce 58 140 Pt 78 192 10.5864
438065 In 49 115 Pb 82 204 I 53 127 Pt 78 192 10.5790
438198 In 49 115 Pb 82 206 I 53 127 Pt 78 194 10.5762
414942 Pd 46 106 Pb 82 204 Sn 50 116 Pt 78 194 10.5715
380582 Mo 42 95 Pb 82 204 Pd 46 105 Pt 78 194 10.5622
434768 Cd 48 116 Pb 82 206 Te 52 130 Pt 78 192 10.5501
434955 Cd 48 113 Pb 82 207 Te 52 125 Pt 78 195 10.4961
453886 Sn 50 118 Pb 82 208 Xe 54 136 Pt 78 190 10.4914
343328 Sr 38 87 Pb 82 204 Mo 42 95 Pt 78 196 10.4868
399362 Ru 44 100 Pb 82 207 Cd 48 112 Pt 78 195 10.4868
415812 Pd 46 108 Pb 82 208 Sn 50 118 Pt 78 198 10.4737
467484 Te 52 125 Pb 82 208 Ba 56 138 Pt 78 195 10.4644
434766 Cd 48 116 Pb 82 206 Te 52 126 Pt 78 196 10.4635
399450 Ru 44 102 Pb 82 207 Cd 48 114 Pt 78 195 10.4588
399691 Ru 44 101 Pb 82 208 Cd 48 113 Pt 78 196 10.4076
456513 Sb 51 123 Pb 82 208 Cs* 55 137 Pt 78 194 10.3992
434919 Cd 48 112 Pb 82 207 Te 52 124 Pt 78 195 10.3936
359150 Zr 40 91 Pb 82 206 Ru 44 102 Pt 78 195 10.3917
435060 Cd 48 108 Pb 82 208 Te 52 120 Pt 78 196 10.3890
398693 Ru 44 101 Pb 82 204 Cd 48 113 Pt 78 192 10.3852
399130 Ru 44 101 Pb 82 206 Cd 48 113 Pt 78 194 10.3824
398727 Ru 44 102 Pb 82 204 Cd 48 112 Pt 78 194 10.3759
434618 Cd 48 111 Pb 82 206 Te 52 122 Pt 78 195 10.3731
358906 Zr 40 92 Pb 82 204 Ru 44 102 Pt 78 194 10.3666
434151 Cd 48 108 Pb 82 204 Te 52 120 Pt 78 192 10.3666
434542 Cd 48 108 Pb 82 206 Te 52 120 Pt 78 194 10.3638
359277 Zr 40 90 Pb 82 207 Ru 44 101 Pt 78 196 10.3554
398964 Ru 44 96 Pb 82 206 Cd 48 106 Pt 78 196 10.3536
452845 Sn 50 117 Pb 82 204 Xe 54 131 Pt 78 190 10.3321
399751 Ru 44 104 Pb 82 208 Cd 48 114 Pt 78 198 10.3154
434305 Cd 48 114 Pb 82 204 Te 52 124 Pt 78 194 10.3107
415555 Pd 46 106 Pb 82 207 Sn 50 117 Pt 78 196 10.2995
381133 Mo 42 98 Pb 82 206 Pd 46 108 Pt 78 196 10.2977
467360 Te 52 120 Pb 82 208 Ba 56 132 Pt 78 196 10.2958
453911 Sn 50 119 Pb 82 208 Xe 54 132 Pt 78 195 10.2949
434835 Cd 48 110 Pb 82 207 Te 52 122 Pt 78 195 10.2911
466714 Te 52 120 Pb 82 204 Ba 56 132 Pt 78 192 10.2734
467008 Te 52 120 Pb 82 206 Ba 56 132 Pt 78 194 10.2707
381229 Mo 42 94 Pb 82 207 Pd 46 105 Pt 78 196 10.2623
453288 Sn 50 117 Pb 82 206 Xe 54 131 Pt 78 192 10.2362
467318 Te 52 125 Pb 82 207 Ba 56 136 Pt 78 196 10.2250
398999 Ru 44 98 Pb 82 206 Cd 48 108 Pt 78 196 10.2138
415466 Pd 46 104 Pb 82 207 Sn 50 115 Pt 78 196 10.1971
283228 Ge 32 70 Pb 82 206 Kr 36 78 Pt 78 198 10.1766
381355 Mo 42 97 Pb 82 207 Pd 46 106 Pt 78 198 10.1701
399129 Ru 44 101 Pb 82 206 Cd 48 112 Pt 78 195 10.1589
453324 Sn 50 118 Pb 82 206 Xe 54 134 Pt 78 190 10.1421
235404 Ni 28 62 Pb 82 206 Ge 32 70 Pt 78 198 10.1384
435272 Cd 48 116 Pb 82 208 Te 52 126 Pt 78 198 10.1365
358961 Zr 40 94 Pb 82 204 Ru 44 104 Pt 78 194 10.1244
466796 Te 52 124 Pb 82 204 Ba 56 138 Pt 78 190 10.1244
92218 S 16 34 Pb 82 204 Ca 20 40 Pt 78 198 10.0741
380911 Mo 42 92 Pb 82 206 Pd 46 102 Pt 78 196 10.0741
381049 Mo 42 96 Pb 82 206 Pd 46 106 Pt 78 196 10.0741
380671 Mo 42 97 Pb 82 204 Pd 46 106 Pt 78 195 10.0592
415035 Pd 46 110 Pb 82 204 Sn 50 118 Pt 78 196 10.0583
453642 Sn 50 119 Pb 82 207 Xe 54 130 Pt 78 196 10.0573
438236 In 49 115 Pb 82 207 I 53 127 Pt 78 195 10.0564
467262 Te 52 123 Pb 82 207 Ba 56 134 Pt 78 196 10.0480
401757 Rh 45 103 Pb 82 204 In 49 113 Pt 78 194 10.0406
398779 Ru 44 104 Pb 82 204 Cd 48 112 Pt 78 196 10.0396
467112 Te 52 124 Pb 82 206 Ba 56 138 Pt 78 192 10.0285
359095 Zr 40 90 Pb 82 206 Ru 44 100 Pt 78 196 10.0275
399497 Ru 44 96 Pb 82 208 Cd 48 106 Pt 78 198 10.0266
359005 Zr 40 96 Pb 82 204 Ru 44 104 Pt 78 196 10.0210
452874 Sn 50 118 Pb 82 204 Xe 54 132 Pt 78 190 10.0108
359479 Zr 40 92 Pb 82 208 Ru 44 104 Pt 78 196 9.9884
190770 Cr 24 52 Pb 82 204 Ni 28 58 Pt 78 198 9.9772
381632 Mo 42 98 Pb 82 208 Pd 46 108 Pt 78 198 9.9707
358908 Zr 40 92 Pb 82 204 Ru 44 104 Pt 78 192 9.9661
359187 Zr 40 92 Pb 82 206 Ru 44 104 Pt 78 194 9.9633
6015 He 2 4 Pb 82 204 C 6 12 Pt 78 196 9.9586
434271 Cd 48 113 Pb 82 204 Te 52 123 Pt 78 194 9.9567
361797 Nb 41 93 Pb 82 206 Rh 45 103 Pt 78 196 9.9530
478053 Xe 54 124 Pb 82 208 Ce 58 136 Pt 78 196 9.9512
477429 Xe 54 124 Pb 82 204 Ce 58 136 Pt 78 192 9.9288
477717 Xe 54 124 Pb 82 206 Ce 58 136 Pt 78 194 9.9260
380958 Mo 42 94 Pb 82 206 Pd 46 104 Pt 78 196 9.9158
453321 Sn 50 118 Pb 82 206 Xe 54 132 Pt 78 192 9.9148
415633 Pd 46 102 Pb 82 208 Sn 50 114 Pt 78 196 9.9139
414862 Pd 46 102 Pb 82 204 Sn 50 114 Pt 78 192 9.8915
415203 Pd 46 102 Pb 82 206 Sn 50 114 Pt 78 194 9.8887
399547 Ru 44 98 Pb 82 208 Cd 48 108 Pt 78 198 9.8869
435110 Cd 48 110 Pb 82 208 Te 52 123 Pt 78 195 9.8869
359317 Zr 40 91 Pb 82 207 Ru 44 100 Pt 78 198 9.8720
359149 Zr 40 91 Pb 82 206 Ru 44 101 Pt 78 196 9.8692
399401 Ru 44 101 Pb 82 207 Cd 48 113 Pt 78 195 9.8627
415277 Pd 46 105 Pb 82 206 Sn 50 115 Pt 78 196 9.8506
434807 Cd 48 108 Pb 82 207 Te 52 120 Pt 78 195 9.8440
381168 Mo 42 100 Pb 82 206 Pd 46 108 Pt 78 198 9.8422
453930 Sn 50 120 Pb 82 208 Xe 54 134 Pt 78 194 9.8422
415314 Pd 46 106 Pb 82 206 Sn 50 116 Pt 78 196 9.8319
381012 Mo 42 95 Pb 82 206 Pd 46 105 Pt 78 196 9.8226
381267 Mo 42 95 Pb 82 207 Pd 46 104 Pt 78 198 9.8068
467483 Te 52 125 Pb 82 208 Ba 56 137 Pt 78 196 9.8021
467230 Te 52 122 Pb 82 207 Ba 56 135 Pt 78 194 9.7975
260893 Zn 30 66 Pb 82 206 Se 34 74 Pt 78 198 9.7937
358960 Zr 40 94 Pb 82 204 Ru 44 102 Pt 78 196 9.7881
466830 Te 52 125 Pb 82 204 Ba 56 137 Pt 78 192 9.7798
467141 Te 52 125 Pb 82 206 Ba 56 137 Pt 78 194 9.7770
453696 Sn 50 112 Pb 82 208 Xe 54 124 Pt 78 196 9.7649
358866 Zr 40 91 Pb 82 204 Ru 44 100 Pt 78 195 9.7611
467203 Te 52 120 Pb 82 207 Ba 56 132 Pt 78 195 9.7509
381426 Mo 42 92 Pb 82 208 Pd 46 102 Pt 78 198 9.7472
381573 Mo 42 96 Pb 82 208 Pd 46 106 Pt 78 198 9.7472
452758 Sn 50 112 Pb 82 204 Xe 54 124 Pt 78 192 9.7425
453162 Sn 50 112 Pb 82 206 Xe 54 124 Pt 78 194 9.7397
456369 Sb 51 123 Pb 82 204 Cs* 55 137 Pt 78 190 9.7332
399306 Ru 44 99 Pb 82 207 Cd 48 108 Pt 78 198 9.7323
453572 Sn 50 117 Pb 82 207 Xe 54 128 Pt 78 196 9.7239
359406 Zr 40 90 Pb 82 208 Ru 44 100 Pt 78 198 9.7006
453538 Sn 50 116 Pb 82 207 Xe 54 129 Pt 78 194 9.7006
380581 Mo 42 95 Pb 82 204 Pd 46 104 Pt 78 195 9.6959
380705 Mo 42 98 Pb 82 204 Pd 46 106 Pt 78 196 9.6857
485345 Ba 56 130 Pb 82 208 Nd 60 142 Pt 78 196 9.6736
484879 Ba 56 130 Pb 82 204 Nd 60 142 Pt 78 192 9.6512
343371 Sr 38 88 Pb 82 204 Mo 42 98 Pt 78 194 9.6493
485094 Ba 56 130 Pb 82 206 Nd 60 142 Pt 78 194 9.6484
467404 Te 52 122 Pb 82 208 Ba 56 134 Pt 78 196 9.6438
456464 Sb 51 123 Pb 82 206 Cs* 55 137 Pt 78 192 9.6372
399163 Ru 44 102 Pb 82 206 Cd 48 112 Pt 78 196 9.6363
478094 Xe 54 126 Pb 82 208 Ce 58 142 Pt 78 192 9.6344
434352 Cd 48 116 Pb 82 204 Te 52 124 Pt 78 196 9.6298
359186 Zr 40 92 Pb 82 206 Ru 44 102 Pt 78 196 9.6270
361840 Nb 41 93 Pb 82 208 Rh 45 103 Pt 78 198 9.6261
398621 Ru 44 99 Pb 82 204 Cd 48 108 Pt 78 195 9.6214
466736 Te 52 122 Pb 82 204 Ba 56 134 Pt 78 192 9.6214
467043 Te 52 122 Pb 82 206 Ba 56 134 Pt 78 194 9.6186
456496 Sb 51 121 Pb 82 208 Cs 55 133 Pt 78 196 9.6158
398651 Ru 44 100 Pb 82 204 Cd 48 110 Pt 78 194 9.6028
283111 Ge 32 74 Pb 82 204 Kr 36 80 Pt 78 198 9.6000
456347 Sb 51 121 Pb 82 204 Cs 55 133 Pt 78 192 9.5935
456442 Sb 51 121 Pb 82 206 Cs 55 133 Pt 78 194 9.5907
381485 Mo 42 94 Pb 82 208 Pd 46 104 Pt 78 198 9.5888
467293 Te 52 124 Pb 82 207 Ba 56 137 Pt 78 194 9.5832
453496 Sn 50 115 Pb 82 207 Xe 54 126 Pt 78 196 9.5739
434730 Cd 48 114 Pb 82 206 Te 52 124 Pt 78 196 9.5711
467435 Te 52 123 Pb 82 208 Ba 56 135 Pt 78 196 9.5692
414861 Pd 46 102 Pb 82 204 Sn 50 112 Pt 78 194 9.5562
466767 Te 52 123 Pb 82 204 Ba 56 135 Pt 78 192 9.5469
467080 Te 52 123 Pb 82 206 Ba 56 135 Pt 78 194 9.5441
359451 Zr 40 91 Pb 82 208 Ru 44 101 Pt 78 198 9.5422
435192 Cd 48 112 Pb 82 208 Te 52 125 Pt 78 195 9.5422
453809 Sn 50 116 Pb 82 208 Xe 54 128 Pt 78 196 9.5338
399642 Ru 44 100 Pb 82 208 Cd 48 113 Pt 78 195 9.5329
415732 Pd 46 105 Pb 82 208 Sn 50 115 Pt 78 198 9.5236
452813 Sn 50 116 Pb 82 204 Xe 54 128 Pt 78 192 9.5115
453247 Sn 50 116 Pb 82 206 Xe 54 128 Pt 78 194 9.5087
415767 Pd 46 106 Pb 82 208 Sn 50 116 Pt 78 198 9.5050
381538 Mo 42 95 Pb 82 208 Pd 46 105 Pt 78 198 9.4957
415366 Pd 46 108 Pb 82 206 Sn 50 119 Pt 78 195 9.4603
359362 Zr 40 92 Pb 82 207 Ru 44 104 Pt 78 195 9.4435
485347 Ba 56 130 Pb 82 208 Nd 60 144 Pt 78 194 9.4398
453931 Sn 50 120 Pb 82 208 Xe 54 136 Pt 78 192 9.4295
478091 Xe 54 126 Pb 82 208 Ce 58 138 Pt 78 196 9.4193
453010 Sn 50 124 Pb 82 204 Xe 54 134 Pt 78 194 9.4090
434230 Cd 48 112 Pb 82 204 Te 52 122 Pt 78 194 9.4072
452771 Sn 50 114 Pb 82 204 Xe 54 124 Pt 78 194 9.4072
477909 Xe 54 124 Pb 82 207 Ce 58 136 Pt 78 195 9.4062
477445 Xe 54 126 Pb 82 204 Ce 58 138 Pt 78 192 9.3969
343602 Sr 38 87 Pb 82 206 Mo 42 95 Pt 78 198 9.3950
477742 Xe 54 126 Pb 82 206 Ce 58 138 Pt 78 194 9.3941
359229 Zr 40 94 Pb 82 206 Ru 44 104 Pt 78 196 9.3848
434990 Cd 48 114 Pb 82 207 Te 52 125 Pt 78 196 9.3774
467461 Te 52 124 Pb 82 208 Ba 56 136 Pt 78 196 9.3736
415438 Pd 46 102 Pb 82 207 Sn 50 114 Pt 78 195 9.3690
466794 Te 52 124 Pb 82 204 Ba 56 136 Pt 78 192 9.3513
467111 Te 52 124 Pb 82 206 Ba 56 136 Pt 78 194 9.3485
399449 Ru 44 102 Pb 82 207 Cd 48 113 Pt 78 196 9.3401
453949 Sn 50 122 Pb 82 208 Xe 54 136 Pt 78 194 9.3364
359004 Zr 40 96 Pb 82 204 Ru 44 102 Pt 78 198 9.3326
399720 Ru 44 102 Pb 82 208 Cd 48 112 Pt 78 198 9.3094
401832 Rh 45 103 Pb 82 206 In 49 113 Pt 78 196 9.3010
359478 Zr 40 92 Pb 82 208 Ru 44 102 Pt 78 198 9.3000
434951 Cd 48 113 Pb 82 207 Te 52 122 Pt 78 198 9.2944
453910 Sn 50 119 Pb 82 208 Xe 54 131 Pt 78 196 9.2833
466891 Te 52 128 Pb 82 204 Ba 56 138 Pt 78 194 9.2767
468674 I 53 127 Pb 82 208 La 57 139 Pt 78 196 9.2730
453880 Sn 50 118 Pb 82 208 Xe 54 130 Pt 78 196 9.2618
452911 Sn 50 119 Pb 82 204 Xe 54 131 Pt 78 192 9.2609
453359 Sn 50 119 Pb 82 206 Xe 54 131 Pt 78 194 9.2581
453849 Sn 50 117 Pb 82 208 Xe 54 129 Pt 78 196 9.2581
467319 Te 52 125 Pb 82 207 Ba 56 137 Pt 78 195 9.2572
468604 I 53 127 Pb 82 204 La 57 139 Pt 78 192 9.2507
468648 I 53 127 Pb 82 206 La 57 139 Pt 78 194 9.2479
435250 Cd 48 114 Pb 82 208 Te 52 124 Pt 78 198 9.2441
452872 Sn 50 118 Pb 82 204 Xe 54 130 Pt 78 192 9.2395
453320 Sn 50 118 Pb 82 206 Xe 54 130 Pt 78 194 9.2367
452844 Sn 50 117 Pb 82 204 Xe 54 129 Pt 78 192 9.2358
453287 Sn 50 117 Pb 82 206 Xe 54 129 Pt 78 194 9.2330
380755 Mo 42 100 Pb 82 204 Pd 46 106 Pt 78 198 9.2302
414985 Pd 46 108 Pb 82 204 Sn 50 116 Pt 78 196 9.2199
453443 Sn 50 112 Pb 82 207 Xe 54 124 Pt 78 195 9.2199
434698 Cd 48 113 Pb 82 206 Te 52 123 Pt 78 196 9.2171
467498 Te 52 126 Pb 82 208 Ba 56 138 Pt 78 196 9.2171
477985 Xe 54 129 Pb 82 207 Ce 58 140 Pt 78 196 9.2041
466859 Te 52 126 Pb 82 204 Ba 56 138 Pt 78 192 9.1948
398692 Ru 44 101 Pb 82 204 Cd 48 111 Pt 78 194 9.1929
467164 Te 52 126 Pb 82 206 Ba 56 138 Pt 78 194 9.1920
434270 Cd 48 113 Pb 82 204 Te 52 122 Pt 78 195 9.1836
452945 Sn 50 120 Pb 82 204 Xe 54 134 Pt 78 190 9.1761
359096 Zr 40 90 Pb 82 206 Ru 44 101 Pt 78 195 9.1529
485234 Ba 56 130 Pb 82 207 Nd 60 142 Pt 78 195 9.1286
453612 Sn 50 118 Pb 82 207 Xe 54 131 Pt 78 194 9.1203
466912 Te 52 130 Pb 82 204 Ba 56 138 Pt 78 196 9.1081
467229 Te 52 122 Pb 82 207 Ba 56 134 Pt 78 195 9.0988
415315 Pd 46 106 Pb 82 206 Sn 50 117 Pt 78 195 9.0970
453390 Sn 50 120 Pb 82 206 Xe 54 134 Pt 78 192 9.0802
456478 Sb 51 121 Pb 82 207 Cs 55 133 Pt 78 195 9.0709
380959 Mo 42 94 Pb 82 206 Pd 46 105 Pt 78 195 9.0597
359506 Zr 40 94 Pb 82 208 Ru 44 104 Pt 78 198 9.0578
343902 Sr 38 88 Pb 82 208 Mo 42 100 Pt 78 196 9.0383
467263 Te 52 123 Pb 82 207 Ba 56 135 Pt 78 195 9.0243
467140 Te 52 125 Pb 82 206 Ba 56 136 Pt 78 195 9.0225
453958 Sn 50 124 Pb 82 208 Xe 54 136 Pt 78 196 9.0187
343372 Sr 38 88 Pb 82 204 Mo 42 100 Pt 78 192 9.0159
343635 Sr 38 88 Pb 82 206 Mo 42 100 Pt 78 194 9.0131
453948 Sn 50 122 Pb 82 208 Xe 54 134 Pt 78 196 9.0122
485235 Ba 56 130 Pb 82 207 Nd 60 143 Pt 78 194 9.0057
211117 Fe 26 58 Pb 82 204 Zn 30 64 Pt 78 198 9.0038
358904 Zr 40 92 Pb 82 204 Ru 44 100 Pt 78 196 8.9964
453011 Sn 50 124 Pb 82 204 Xe 54 136 Pt 78 192 8.9964
415237 Pd 46 104 Pb 82 206 Sn 50 115 Pt 78 195 8.9945
453434 Sn 50 124 Pb 82 206 Xe 54 136 Pt 78 194 8.9936
452983 Sn 50 122 Pb 82 204 Xe 54 134 Pt 78 192 8.9898
453537 Sn 50 116 Pb 82 207 Xe 54 128 Pt 78 195 8.9889
453416 Sn 50 122 Pb 82 206 Xe 54 134 Pt 78 194 8.9871
401877 Rh 45 103 Pb 82 208 In 49 113 Pt 78 198 8.9740
453929 Sn 50 120 Pb 82 208 Xe 54 132 Pt 78 196 8.9712
415408 Pd 46 110 Pb 82 206 Sn 50 118 Pt 78 198 8.9666
477745 Xe 54 126 Pb 82 206 Ce 58 142 Pt 78 190 8.9656
452942 Sn 50 120 Pb 82 204 Xe 54 132 Pt 78 192 8.9489
399211 Ru 44 104 Pb 82 206 Cd 48 112 Pt 78 198 8.9479
453388 Sn 50 120 Pb 82 206 Xe 54 132 Pt 78 194 8.9461
359255 Zr 40 96 Pb 82 206 Ru 44 104 Pt 78 198 8.9293
434918 Cd 48 112 Pb 82 207 Te 52 123 Pt 78 196 8.9209
343634 Sr 38 88 Pb 82 206 Mo 42 98 Pt 78 196 8.9097
435227 Cd 48 113 Pb 82 208 Te 52 123 Pt 78 198 8.8902
477931 Xe 54 126 Pb 82 207 Ce 58 138 Pt 78 195 8.8743
6032 He 2 4 Pb 82 206 C 6 12 Pt 78 198 8.8669
399399 Ru 44 101 Pb 82 207 Cd 48 110 Pt 78 198 8.8660
399077 Ru 44 100 Pb 82 206 Cd 48 110 Pt 78 196 8.8632
303173 Se 34 78 Pb 82 204 Sr 38 84 Pt 78 198 8.8594
452981 Sn 50 122 Pb 82 204 Xe 54 132 Pt 78 194 8.8557
453358 Sn 50 119 Pb 82 206 Xe 54 130 Pt 78 195 8.8548
467079 Te 52 123 Pb 82 206 Ba 56 134 Pt 78 195 8.8455
415609 Pd 46 110 Pb 82 207 Sn 50 119 Pt 78 198 8.8287
467292 Te 52 124 Pb 82 207 Ba 56 136 Pt 78 195 8.8287
415202 Pd 46 102 Pb 82 206 Sn 50 112 Pt 78 196 8.8166
399361 Ru 44 100 Pb 82 207 Cd 48 111 Pt 78 196 8.7812
484880 Ba 56 130 Pb 82 204 Nd 60 144 Pt 78 190 8.7737
453392 Sn 50 120 Pb 82 206 Xe 54 136 Pt 78 190 8.7607
398691 Ru 44 101 Pb 82 204 Cd 48 110 Pt 78 195 8.7551
453643 Sn 50 119 Pb 82 207 Xe 54 131 Pt 78 195 8.7383
478134 Xe 54 128 Pb 82 208 Ce 58 140 Pt 78 196 8.7383
468666 I 53 127 Pb 82 207 La 57 139 Pt 78 195 8.7281
415036 Pd 46 110 Pb 82 204 Sn 50 119 Pt 78 195 8.7179
453611 Sn 50 118 Pb 82 207 Xe 54 130 Pt 78 195 8.7169
477468 Xe 54 128 Pb 82 204 Ce 58 140 Pt 78 192 8.7160
453573 Sn 50 117 Pb 82 207 Xe 54 129 Pt 78 195 8.7132
477778 Xe 54 128 Pb 82 206 Ce 58 140 Pt 78 194 8.7132
359228 Zr 40 94 Pb 82 206 Ru 44 102 Pt 78 198 8.6964
456366 Sb 51 123 Pb 82 204 Cs 55 133 Pt 78 194 8.6806
485095 Ba 56 130 Pb 82 206 Nd 60 144 Pt 78 192 8.6778
467340 Te 52 126 Pb 82 207 Ba 56 138 Pt 78 195 8.6722
452985 Sn 50 122 Pb 82 204 Xe 54 136 Pt 78 190 8.6703
453433 Sn 50 124 Pb 82 206 Xe 54 134 Pt 78 196 8.6694
434652 Cd 48 112 Pb 82 206 Te 52 122 Pt 78 196 8.6676
453184 Sn 50 114 Pb 82 206 Xe 54 124 Pt 78 196 8.6676
399475 Ru 44 104 Pb 82 207 Cd 48 113 Pt 78 198 8.6517
467405 Te 52 122 Pb 82 208 Ba 56 135 Pt 78 195 8.6200
2375 D 1 2 Pb 82 204 B 5 10 Pt 78 196 8.6173
415585 Pd 46 108 Pb 82 207 Sn 50 117 Pt 78 198 8.5958
381132 Mo 42 98 Pb 82 206 Pd 46 106 Pt 78 198 8.5940
343901 Sr 38 88 Pb 82 208 Mo 42 98 Pt 78 198 8.5828
453417 Sn 50 122 Pb 82 206 Xe 54 136 Pt 78 192 8.5744
380670 Mo 42 97 Pb 82 204 Pd 46 105 Pt 78 196 8.5679
398780 Ru 44 104 Pb 82 204 Cd 48 113 Pt 78 195 8.5409
434765 Cd 48 116 Pb 82 206 Te 52 124 Pt 78 198 8.5381
453009 Sn 50 124 Pb 82 204 Xe 54 132 Pt 78 196 8.5381
467184 Te 52 128 Pb 82 206 Ba 56 138 Pt 78 196 8.5371
399640 Ru 44 100 Pb 82 208 Cd 48 110 Pt 78 198 8.5362
453810 Sn 50 116 Pb 82 208 Xe 54 129 Pt 78 195 8.5232
343369 Sr 38 88 Pb 82 204 Mo 42 96 Pt 78 196 8.5213
453286 Sn 50 117 Pb 82 206 Xe 54 128 Pt 78 195 8.5213
466858 Te 52 126 Pb 82 204 Ba 56 136 Pt 78 194 8.5148
235120 Ni 28 64 Pb 82 204 Ge 32 70 Pt 78 198 8.4962
343771 Sr 38 88 Pb 82 207 Mo 42 100 Pt 78 195 8.4934
415630 Pd 46 102 Pb 82 208 Sn 50 112 Pt 78 198 8.4896
414986 Pd 46 108 Pb 82 204 Sn 50 117 Pt 78 195 8.4850
466829 Te 52 125 Pb 82 204 Ba 56 135 Pt 78 194 8.4850
453690 Sn 50 124 Pb 82 207 Xe 54 136 Pt 78 195 8.4738
453686 Sn 50 122 Pb 82 207 Xe 54 134 Pt 78 195 8.4673
380617 Mo 42 96 Pb 82 204 Pd 46 104 Pt 78 196 8.4561
399128 Ru 44 101 Pb 82 206 Cd 48 111 Pt 78 196 8.4533
453672 Sn 50 120 Pb 82 207 Xe 54 132 Pt 78 195 8.4263
467462 Te 52 124 Pb 82 208 Ba 56 137 Pt 78 195 8.4058
453217 Sn 50 115 Pb 82 206 Xe 54 126 Pt 78 195 8.3713
435010 Cd 48 116 Pb 82 207 Te 52 125 Pt 78 198 8.3443
453957 Sn 50 124 Pb 82 208 Xe 54 134 Pt 78 198 8.3425
435188 Cd 48 112 Pb 82 208 Te 52 122 Pt 78 198 8.3406
453731 Sn 50 114 Pb 82 208 Xe 54 124 Pt 78 198 8.3406
452941 Sn 50 120 Pb 82 204 Xe 54 130 Pt 78 194 8.2707
452910 Sn 50 119 Pb 82 204 Xe 54 129 Pt 78 194 8.2577
434353 Cd 48 116 Pb 82 204 Te 52 125 Pt 78 195 8.2335
359361 Zr 40 92 Pb 82 207 Ru 44 101 Pt 78 198 8.2325
398725 Ru 44 102 Pb 82 204 Cd 48 110 Pt 78 196 8.2325
477986 Xe 54 129 Pb 82 207 Ce 58 142 Pt 78 194 8.2270
467510 Te 52 128 Pb 82 208 Ba 56 138 Pt 78 198 8.2102
477956 Xe 54 128 Pb 82 207 Ce 58 140 Pt 78 195 8.1934
2367 H 1 1 Pb 82 204 B 5 11 Pt 78 194 8.1776
434731 Cd 48 114 Pb 82 206 Te 52 125 Pt 78 195 8.1748
399164 Ru 44 102 Pb 82 206 Cd 48 113 Pt 78 195 8.1375
415364 Pd 46 108 Pb 82 206 Sn 50 116 Pt 78 198 8.1282
399690 Ru 44 101 Pb 82 208 Cd 48 111 Pt 78 198 8.1264
485348 Ba 56 130 Pb 82 208 Nd 60 146 Pt 78 192 8.1264
358905 Zr 40 92 Pb 82 204 Ru 44 101 Pt 78 195 8.1217
434172 Cd 48 110 Pb 82 204 Te 52 120 Pt 78 194 8.1217
453415 Sn 50 122 Pb 82 206 Xe 54 132 Pt 78 196 8.1161
466793 Te 52 124 Pb 82 204 Ba 56 134 Pt 78 194 8.1124
330635 Rb 37 87 Pb 82 204 Nb 41 93 Pt 78 198 8.1031
358959 Zr 40 94 Pb 82 204 Ru 44 100 Pt 78 198 8.0658
434303 Cd 48 114 Pb 82 204 Te 52 122 Pt 78 196 8.0649
467195 Te 52 130 Pb 82 206 Ba 56 138 Pt 78 198 8.0164
467339 Te 52 126 Pb 82 207 Ba 56 137 Pt 78 196 8.0099
477815 Xe 54 129 Pb 82 206 Ce 58 140 Pt 78 195 8.0015
466713 Te 52 120 Pb 82 204 Ba 56 130 Pt 78 194 7.9820
453881 Sn 50 118 Pb 82 208 Xe 54 131 Pt 78 195 7.9429
456462 Sb 51 123 Pb 82 206 Cs 55 133 Pt 78 196 7.9410
452871 Sn 50 118 Pb 82 204 Xe 54 128 Pt 78 194 7.9279
343266 Sr 38 86 Pb 82 204 Mo 42 92 Pt 78 198 7.9261
485236 Ba 56 130 Pb 82 207 Nd 60 145 Pt 78 192 7.9252
359185 Zr 40 92 Pb 82 206 Ru 44 100 Pt 78 198 7.9047
467316 Te 52 125 Pb 82 207 Ba 56 134 Pt 78 198 7.8972
468665 I 53 127 Pb 82 207 La 57 138 Pt 78 196 7.8795
466889 Te 52 128 Pb 82 204 Ba 56 136 Pt 78 196 7.8599
485346 Ba 56 130 Pb 82 208 Nd 60 143 Pt 78 195 7.8283
434870 Cd 48 111 Pb 82 207 Te 52 120 Pt 78 198 7.7947
453947 Sn 50 122 Pb 82 208 Xe 54 132 Pt 78 198 7.7892
466828 Te 52 125 Pb 82 204 Ba 56 134 Pt 78 195 7.7864
467162 Te 52 126 Pb 82 206 Ba 56 136 Pt 78 196 7.7752
478135 Xe 54 128 Pb 82 208 Ce 58 142 Pt 78 194 7.7612
467139 Te 52 125 Pb 82 206 Ba 56 135 Pt 78 196 7.7454
434653 Cd 48 112 Pb 82 206 Te 52 123 Pt 78 195 7.7184
381319 Mo 42 96 Pb 82 207 Pd 46 105 Pt 78 198 7.7109
434202 Cd 48 111 Pb 82 204 Te 52 120 Pt 78 195 7.6839
343770 Sr 38 88 Pb 82 207 Mo 42 97 Pt 78 198 7.6643
453640 Sn 50 119 Pb 82 207 Xe 54 128 Pt 78 198 7.6569
452812 Sn 50 116 Pb 82 204 Xe 54 126 Pt 78 194 7.6383
456511 Sb 51 123 Pb 82 208 Cs 55 133 Pt 78 198 7.6140
380618 Mo 42 96 Pb 82 204 Pd 46 105 Pt 78 195 7.6001
466735 Te 52 122 Pb 82 204 Ba 56 132 Pt 78 194 7.5814
399078 Ru 44 100 Pb 82 206 Cd 48 111 Pt 78 195 7.5786
343370 Sr 38 88 Pb 82 204 Mo 42 97 Pt 78 195 7.5535
467291 Te 52 124 Pb 82 207 Ba 56 135 Pt 78 196 7.5516
452909 Sn 50 119 Pb 82 204 Xe 54 128 Pt 78 195 7.5460
398778 Ru 44 104 Pb 82 204 Cd 48 110 Pt 78 198 7.5442
453386 Sn 50 120 Pb 82 206 Xe 54 130 Pt 78 196 7.5311
2387 D 1 2 Pb 82 206 B 5 10 Pt 78 198 7.5255
477467 Xe 54 128 Pb 82 204 Ce 58 138 Pt 78 194 7.5237
453357 Sn 50 119 Pb 82 206 Xe 54 129 Pt 78 196 7.5181
415554 Pd 46 106 Pb 82 207 Sn 50 115 Pt 78 198 7.4873
381099 Mo 42 97 Pb 82 206 Pd 46 105 Pt 78 198 7.4762
485097 Ba 56 130 Pb 82 206 Nd 60 146 Pt 78 190 7.4575
467496 Te 52 126 Pb 82 208 Ba 56 136 Pt 78 198 7.4482
453432 Sn 50 124 Pb 82 206 Xe 54 132 Pt 78 198 7.4464
452979 Sn 50 122 Pb 82 204 Xe 54 130 Pt 78 196 7.4408
2382 H 1 1 Pb 82 206 B 5 11 Pt 78 196 7.4380
343633 Sr 38 88 Pb 82 206 Mo 42 96 Pt 78 198 7.4296
467482 Te 52 125 Pb 82 208 Ba 56 135 Pt 78 198 7.4184
453671 Sn 50 120 Pb 82 207 Xe 54 131 Pt 78 196 7.4147
260678 Zn 30 68 Pb 82 204 Se 34 74 Pt 78 198 7.4091
477524 Xe 54 130 Pb 82 204 Ce 58 140 Pt 78 194 7.4044
415034 Pd 46 110 Pb 82 204 Sn 50 116 Pt 78 198 7.3858
434575 Cd 48 110 Pb 82 206 Te 52 120 Pt 78 196 7.3821
453610 Sn 50 118 Pb 82 207 Xe 54 129 Pt 78 196 7.3802
414941 Pd 46 106 Pb 82 204 Sn 50 115 Pt 78 195 7.3765
467109 Te 52 124 Pb 82 206 Ba 56 134 Pt 78 196 7.3728
381048 Mo 42 96 Pb 82 206 Pd 46 104 Pt 78 198 7.3644
484895 Ba 56 132 Pb 82 204 Nd 60 142 Pt 78 194 7.3597
380539 Mo 42 94 Pb 82 204 Pd 46 102 Pt 78 196 7.3476
466910 Te 52 130 Pb 82 204 Ba 56 136 Pt 78 198 7.3392
414882 Pd 46 104 Pb 82 204 Sn 50 114 Pt 78 194 7.3206
467007 Te 52 120 Pb 82 206 Ba 56 130 Pt 78 196 7.2424
434989 Cd 48 114 Pb 82 207 Te 52 123 Pt 78 198 7.2265
453928 Sn 50 120 Pb 82 208 Xe 54 130 Pt 78 198 7.2042
453909 Sn 50 119 Pb 82 208 Xe 54 129 Pt 78 198 7.1911
453318 Sn 50 118 Pb 82 206 Xe 54 128 Pt 78 196 7.1883
399162 Ru 44 102 Pb 82 206 Cd 48 110 Pt 78 198 7.1408
434304 Cd 48 114 Pb 82 204 Te 52 123 Pt 78 195 7.1157
398591 Ru 44 98 Pb 82 204 Cd 48 106 Pt 78 196 7.1148
478028 Xe 54 131 Pb 82 207 Ce 58 140 Pt 78 198 7.1120
2394 H 1 1 Pb 82 208 B 5 11 Pt 78 198 7.1110
6040 He 2 4 Pb 82 207 C 6 13 Pt 78 198 7.0952
477470 Xe 54 128 Pb 82 204 Ce 58 142 Pt 78 190 7.0952
399448 Ru 44 102 Pb 82 207 Cd 48 111 Pt 78 198 7.0589
435106 Cd 48 110 Pb 82 208 Te 52 120 Pt 78 198 7.0551
478159 Xe 54 129 Pb 82 208 Ce 58 142 Pt 78 195 7.0495
467459 Te 52 124 Pb 82 208 Ba 56 134 Pt 78 198 7.0458
434349 Cd 48 116 Pb 82 204 Te 52 122 Pt 78 198 7.0318
467349 Te 52 128 Pb 82 207 Ba 56 137 Pt 78 198 7.0030
477560 Xe 54 131 Pb 82 204 Ce 58 140 Pt 78 195 7.0011
477780 Xe 54 128 Pb 82 206 Ce 58 142 Pt 78 192 6.9992
6016 He 2 4 Pb 82 204 C 6 13 Pt 78 195 6.9843
380704 Mo 42 98 Pb 82 204 Pd 46 104 Pt 78 198 6.9760
434727 Cd 48 114 Pb 82 206 Te 52 122 Pt 78 198 6.9732
398726 Ru 44 102 Pb 82 204 Cd 48 111 Pt 78 195 6.9480
477983 Xe 54 129 Pb 82 207 Ce 58 138 Pt 78 198 6.9229
467259 Te 52 123 Pb 82 207 Ba 56 132 Pt 78 198 6.9191
467358 Te 52 120 Pb 82 208 Ba 56 130 Pt 78 198 6.9154
453246 Sn 50 116 Pb 82 206 Xe 54 126 Pt 78 196 6.8986
466890 Te 52 128 Pb 82 204 Ba 56 137 Pt 78 195 6.8921
453878 Sn 50 118 Pb 82 208 Xe 54 128 Pt 78 198 6.8614
467042 Te 52 122 Pb 82 206 Ba 56 132 Pt 78 196 6.8418
477444 Xe 54 126 Pb 82 204 Ce 58 136 Pt 78 194 6.8260
477499 Xe 54 129 Pb 82 204 Ce 58 138 Pt 78 195 6.8120
466766 Te 52 123 Pb 82 204 Ba 56 132 Pt 78 195 6.8083
467163 Te 52 126 Pb 82 206 Ba 56 137 Pt 78 195 6.8074
477777 Xe 54 128 Pb 82 206 Ce 58 138 Pt 78 196 6.7841
453008 Sn 50 124 Pb 82 204 Xe 54 130 Pt 78 198 6.7710
467182 Te 52 128 Pb 82 206 Ba 56 136 Pt 78 198 6.7682
453569 Sn 50 117 Pb 82 207 Xe 54 126 Pt 78 198 6.7617
358865 Zr 40 91 Pb 82 204 Ru 44 99 Pt 78 196 6.7608
283021 Ge 32 72 Pb 82 204 Kr 36 78 Pt 78 198 6.7561
468647 I 53 127 Pb 82 206 La 57 138 Pt 78 195 6.6769
477841 Xe 54 130 Pb 82 206 Ce 58 140 Pt 78 196 6.6648
452843 Sn 50 117 Pb 82 204 Xe 54 126 Pt 78 195 6.6509
398650 Ru 44 100 Pb 82 204 Cd 48 108 Pt 78 196 6.6211
485120 Ba 56 132 Pb 82 206 Nd 60 142 Pt 78 196 6.6201
415236 Pd 46 104 Pb 82 206 Sn 50 114 Pt 78 196 6.5810
453806 Sn 50 116 Pb 82 208 Xe 54 126 Pt 78 198 6.5717
415503 Pd 46 105 Pb 82 207 Sn 50 114 Pt 78 198 6.5652
466856 Te 52 126 Pb 82 204 Ba 56 134 Pt 78 196 6.5391
467401 Te 52 122 Pb 82 208 Ba 56 132 Pt 78 198 6.5149
478029 Xe 54 131 Pb 82 207 Ce 58 142 Pt 78 196 6.4869
478132 Xe 54 128 Pb 82 208 Ce 58 138 Pt 78 198 6.4571
414910 Pd 46 105 Pb 82 204 Sn 50 114 Pt 78 195 6.4543
358811 Zr 40 90 Pb 82 204 Ru 44 98 Pt 78 196 6.4348
485380 Ba 56 132 Pb 82 208 Nd 60 144 Pt 78 196 6.4115
484896 Ba 56 132 Pb 82 204 Nd 60 144 Pt 78 192 6.3891
485122 Ba 56 132 Pb 82 206 Nd 60 144 Pt 78 194 6.3863
453414 Sn 50 122 Pb 82 206 Xe 54 130 Pt 78 198 6.3491
467110 Te 52 124 Pb 82 206 Ba 56 135 Pt 78 195 6.3491
478178 Xe 54 130 Pb 82 208 Ce 58 140 Pt 78 198 6.3379
485379 Ba 56 132 Pb 82 208 Nd 60 142 Pt 78 198 6.2932
380955 Mo 42 94 Pb 82 206 Pd 46 102 Pt 78 198 6.2559
415680 Pd 46 104 Pb 82 208 Sn 50 114 Pt 78 198 6.2541
414881 Pd 46 104 Pb 82 204 Sn 50 112 Pt 78 196 6.2485
453685 Sn 50 122 Pb 82 207 Xe 54 131 Pt 78 198 6.2326
452939 Sn 50 120 Pb 82 204 Xe 54 128 Pt 78 196 6.2224
453387 Sn 50 120 Pb 82 206 Xe 54 131 Pt 78 195 6.2121
453319 Sn 50 118 Pb 82 206 Xe 54 129 Pt 78 195 6.1777
359276 Zr 40 90 Pb 82 207 Ru 44 99 Pt 78 198 6.1553
452980 Sn 50 122 Pb 82 204 Xe 54 131 Pt 78 195 6.1218
477741 Xe 54 126 Pb 82 206 Ce 58 136 Pt 78 196 6.0864
358812 Zr 40 90 Pb 82 204 Ru 44 99 Pt 78 195 6.0445
398996 Ru 44 98 Pb 82 206 Cd 48 106 Pt 78 198 6.0230
477584 Xe 54 132 Pb 82 204 Ce 58 140 Pt 78 196 5.9895
434229 Cd 48 112 Pb 82 204 Te 52 120 Pt 78 196 5.9783
485254 Ba 56 132 Pb 82 207 Nd 60 143 Pt 78 196 5.9774
485349 Ba 56 130 Pb 82 208 Nd 60 148 Pt 78 190 5.9746
343367 Sr 38 88 Pb 82 204 Mo 42 94 Pt 78 198 5.9699
485255 Ba 56 132 Pb 82 207 Nd 60 144 Pt 78 195 5.8665
485382 Ba 56 132 Pb 82 208 Nd 60 146 Pt 78 194 5.8349
478089 Xe 54 126 Pb 82 208 Ce 58 136 Pt 78 198 5.7594
478179 Xe 54 130 Pb 82 208 Ce 58 142 Pt 78 196 5.7129
477526 Xe 54 130 Pb 82 204 Ce 58 142 Pt 78 192 5.6905
477842 Xe 54 130 Pb 82 206 Ce 58 142 Pt 78 194 5.6877
359148 Zr 40 91 Pb 82 206 Ru 44 99 Pt 78 198 5.6691
485256 Ba 56 132 Pb 82 207 Nd 60 145 Pt 78 194 5.6337
467338 Te 52 126 Pb 82 207 Ba 56 135 Pt 78 198 5.6262
466887 Te 52 128 Pb 82 204 Ba 56 134 Pt 78 198 5.5321
399074 Ru 44 100 Pb 82 206 Cd 48 108 Pt 78 198 5.5293
466857 Te 52 126 Pb 82 204 Ba 56 135 Pt 78 195 5.5154
477523 Xe 54 130 Pb 82 204 Ce 58 138 Pt 78 196 5.4753
467160 Te 52 126 Pb 82 206 Ba 56 134 Pt 78 198 5.4474
479065 Cs 55 133 Pb 82 204 Pr 59 141 Pt 78 196 5.3915
453494 Sn 50 115 Pb 82 207 Xe 54 124 Pt 78 198 5.3822
359093 Zr 40 90 Pb 82 206 Ru 44 98 Pt 78 198 5.3431
466792 Te 52 124 Pb 82 204 Ba 56 132 Pt 78 196 5.3356
453670 Sn 50 120 Pb 82 207 Xe 54 129 Pt 78 198 5.3226
452870 Sn 50 118 Pb 82 204 Xe 54 126 Pt 78 196 5.3179
477865 Xe 54 131 Pb 82 206 Ce 58 142 Pt 78 195 5.2844
452791 Sn 50 115 Pb 82 204 Xe 54 124 Pt 78 195 5.2713
452940 Sn 50 120 Pb 82 204 Xe 54 129 Pt 78 195 5.2117
484898 Ba 56 132 Pb 82 204 Nd 60 146 Pt 78 190 5.1689
478008 Xe 54 130 Pb 82 207 Ce 58 142 Pt 78 195 5.1679
415233 Pd 46 104 Pb 82 206 Sn 50 112 Pt 78 198 5.1568
453384 Sn 50 120 Pb 82 206 Xe 54 128 Pt 78 198 5.1307
485123 Ba 56 132 Pb 82 206 Nd 60 146 Pt 78 192 5.0729
452977 Sn 50 122 Pb 82 204 Xe 54 128 Pt 78 198 5.0403
477585 Xe 54 132 Pb 82 204 Ce 58 142 Pt 78 194 5.0124
414940 Pd 46 106 Pb 82 204 Sn 50 114 Pt 78 196 4.9630
398722 Ru 44 102 Pb 82 204 Cd 48 108 Pt 78 198 4.8987
477882 Xe 54 132 Pb 82 206 Ce 58 140 Pt 78 198 4.8978
434649 Cd 48 112 Pb 82 206 Te 52 120 Pt 78 198 4.8866
380614 Mo 42 96 Pb 82 204 Pd 46 102 Pt 78 198 4.7963
485121 Ba 56 132 Pb 82 206 Nd 60 143 Pt 78 195 4.7748
477607 Xe 54 134 Pb 82 204 Ce 58 140 Pt 78 198 4.7665
484919 Ba 56 134 Pb 82 204 Nd 60 142 Pt 78 196 4.5830
466734 Te 52 122 Pb 82 204 Ba 56 130 Pt 78 196 4.5531
485381 Ba 56 132 Pb 82 208 Nd 60 145 Pt 78 195 4.4563
477839 Xe 54 130 Pb 82 206 Ce 58 138 Pt 78 198 4.3836
494459 Nd 60 150 Pb 82 204 Gd 64 158 Pt 78 196 4.3762
484921 Ba 56 134 Pb 82 204 Nd 60 144 Pt 78 194 4.3491
358902 Zr 40 92 Pb 82 204 Ru 44 98 Pt 78 198 4.3119
479101 Cs 55 133 Pb 82 206 Pr 59 141 Pt 78 198 4.2998
434300 Cd 48 114 Pb 82 204 Te 52 120 Pt 78 198 4.2839
477883 Xe 54 132 Pb 82 206 Ce 58 142 Pt 78 196 4.2728
467106 Te 52 124 Pb 82 206 Ba 56 132 Pt 78 198 4.2439
453315 Sn 50 118 Pb 82 206 Xe 54 126 Pt 78 198 4.2262
477466 Xe 54 128 Pb 82 204 Ce 58 136 Pt 78 196 4.2159
477608 Xe 54 134 Pb 82 204 Ce 58 142 Pt 78 196 4.1414
478202 Xe 54 132 Pb 82 208 Ce 58 142 Pt 78 198 3.9458
489508 Ce 58 136 Pb 82 208 Sm 62 148 Pt 78 196 3.9151
489260 Ce 58 136 Pb 82 204 Sm 62 148 Pt 78 192 3.8927
489380 Ce 58 136 Pb 82 206 Sm 62 148 Pt 78 194 3.8899
415311 Pd 46 106 Pb 82 206 Sn 50 114 Pt 78 198 3.8713
494458 Nd 60 150 Pb 82 204 Gd 64 156 Pt 78 198 3.8648
452811 Sn 50 116 Pb 82 204 Xe 54 124 Pt 78 196 3.7986
484949 Ba 56 135 Pb 82 204 Nd 60 143 Pt 78 196 3.7614
485301 Ba 56 135 Pb 82 207 Nd 60 144 Pt 78 198 3.7614
477582 Xe 54 132 Pb 82 204 Ce 58 138 Pt 78 198 3.7083
489510 Ce 58 136 Pb 82 208 Sm 62 150 Pt 78 194 3.6552
484950 Ba 56 135 Pb 82 204 Nd 60 144 Pt 78 195 3.6505
485153 Ba 56 134 Pb 82 206 Nd 60 144 Pt 78 196 3.6095
485383 Ba 56 132 Pb 82 208 Nd 60 148 Pt 78 192 3.5900
494460 Nd 60 150 Pb 82 204 Gd 64 160 Pt 78 194 3.5853
414937 Pd 46 106 Pb 82 204 Sn 50 112 Pt 78 198 3.5387
485302 Ba 56 135 Pb 82 207 Nd 60 146 Pt 78 196 3.5369
485152 Ba 56 134 Pb 82 206 Nd 60 142 Pt 78 198 3.4912
477623 Xe 54 136 Pb 82 204 Ce 58 142 Pt 78 198 3.4652
467040 Te 52 122 Pb 82 206 Ba 56 130 Pt 78 198 3.4614
484951 Ba 56 135 Pb 82 204 Nd 60 145 Pt 78 194 3.4177
466853 Te 52 126 Pb 82 204 Ba 56 132 Pt 78 198 3.4102
499443 Sm 62 154 Pb 82 204 Dy 66 162 Pt 78 196 3.3795
489456 Ce 58 136 Pb 82 207 Sm 62 148 Pt 78 195 3.3701
499673 Sm 62 149 Pb 82 207 Dy 66 162 Pt 78 194 3.3049
489259 Ce 58 136 Pb 82 204 Sm 62 144 Pt 78 196 3.2956
494591 Nd 60 150 Pb 82 206 Gd 64 158 Pt 78 198 3.2844
485413 Ba 56 134 Pb 82 208 Nd 60 144 Pt 78 198 3.2826
452936 Sn 50 120 Pb 82 204 Xe 54 126 Pt 78 198 3.2602
414982 Pd 46 108 Pb 82 204 Sn 50 114 Pt 78 198 3.2593
499445 Sm 62 154 Pb 82 204 Dy 66 164 Pt 78 194 3.2034
489455 Ce 58 136 Pb 82 207 Sm 62 147 Pt 78 196 3.1643
477775 Xe 54 128 Pb 82 206 Ce 58 136 Pt 78 198 3.1242
505591 Gd 64 155 Pb 82 207 Er 68 168 Pt 78 194 3.0721
485414 Ba 56 134 Pb 82 208 Nd 60 146 Pt 78 196 3.0581
499416 Sm 62 152 Pb 82 204 Dy 66 162 Pt 78 194 3.0544
477897 Xe 54 134 Pb 82 206 Ce 58 142 Pt 78 198 3.0497
484922 Ba 56 134 Pb 82 204 Nd 60 146 Pt 78 192 3.0357
489457 Ce 58 136 Pb 82 207 Sm 62 149 Pt 78 194 3.0348
485155 Ba 56 134 Pb 82 206 Nd 60 146 Pt 78 194 3.0329
2388 H 1 1 Pb 82 207 B 5 10 Pt 78 198 3.0311
489261 Ce 58 136 Pb 82 204 Sm 62 150 Pt 78 190 2.9892
501387 Eu 63 151 Pb 82 208 Ho 67 165 Pt 78 194 2.9472
485124 Ba 56 132 Pb 82 206 Nd 60 148 Pt 78 190 2.9212
2366 H 1 1 Pb 82 204 B 5 10 Pt 78 195 2.9202
505589 Gd 64 155 Pb 82 207 Er 68 166 Pt 78 196 2.8942
489381 Ce 58 136 Pb 82 206 Sm 62 150 Pt 78 192 2.8932
485278 Ba 56 134 Pb 82 207 Nd 60 145 Pt 78 196 2.8569
485277 Ba 56 134 Pb 82 207 Nd 60 143 Pt 78 198 2.8485
494592 Nd 60 150 Pb 82 206 Gd 64 160 Pt 78 196 2.8457
499671 Sm 62 149 Pb 82 207 Dy 66 160 Pt 78 196 2.8103
505645 Gd 64 152 Pb 82 208 Er 68 166 Pt 78 194 2.7609
484920 Ba 56 134 Pb 82 204 Nd 60 143 Pt 78 195 2.7377
453244 Sn 50 116 Pb 82 206 Xe 54 124 Pt 78 198 2.7069
499632 Sm 62 147 Pb 82 207 Dy 66 160 Pt 78 194 2.6808
485184 Ba 56 135 Pb 82 206 Nd 60 145 Pt 78 196 2.6780
485183 Ba 56 135 Pb 82 206 Nd 60 143 Pt 78 198 2.6697
505396 Gd 64 160 Pb 82 204 Er 68 168 Pt 78 196 2.6343
489512 Ce 58 136 Pb 82 208 Sm 62 152 Pt 78 192 2.6305
499414 Sm 62 152 Pb 82 204 Dy 66 160 Pt 78 196 2.5597
499442 Sm 62 154 Pb 82 204 Dy 66 160 Pt 78 198 2.5327
508494 Dy 66 156 Pb 82 208 Yb 70 170 Pt 78 194 2.5281
494741 Nd 60 150 Pb 82 208 Gd 64 160 Pt 78 198 2.5188
485279 Ba 56 134 Pb 82 207 Nd 60 146 Pt 78 195 2.5132
499613 Sm 62 154 Pb 82 206 Dy 66 164 Pt 78 196 2.4638
494437 Nd 60 148 Pb 82 204 Gd 64 158 Pt 78 194 2.4582
499633 Sm 62 147 Pb 82 207 Dy 66 162 Pt 78 192 2.4387
398647 Ru 44 100 Pb 82 204 Cd 48 106 Pt 78 198 2.4303
499674 Sm 62 149 Pb 82 207 Dy 66 164 Pt 78 192 2.3921
484971 Ba 56 136 Pb 82 204 Nd 60 144 Pt 78 196 2.3734
485432 Ba 56 135 Pb 82 208 Nd 60 145 Pt 78 198 2.3511
485185 Ba 56 135 Pb 82 206 Nd 60 146 Pt 78 195 2.3343
499596 Sm 62 152 Pb 82 206 Dy 66 162 Pt 78 196 2.3148
505625 Gd 64 157 Pb 82 207 Er 68 168 Pt 78 196 2.3073
494435 Nd 60 148 Pb 82 204 Gd 64 156 Pt 78 196 2.2989
499612 Sm 62 154 Pb 82 206 Dy 66 162 Pt 78 198 2.2877
501261 Eu 63 151 Pb 82 204 Ho 67 165 Pt 78 190 2.2812
499390 Sm 62 150 Pb 82 204 Dy 66 160 Pt 78 194 2.2719
484970 Ba 56 136 Pb 82 204 Nd 60 142 Pt 78 198 2.2551
508495 Dy 66 156 Pb 82 208 Yb 70 172 Pt 78 192 2.2486
499782 Sm 62 149 Pb 82 208 Dy 66 163 Pt 78 194 2.2300
489377 Ce 58 136 Pb 82 206 Sm 62 144 Pt 78 198 2.2039
505646 Gd 64 152 Pb 82 208 Er 68 168 Pt 78 192 2.2021
501340 Eu 63 151 Pb 82 206 Ho 67 165 Pt 78 192 2.1853
499811 Sm 62 152 Pb 82 208 Dy 66 164 Pt 78 196 2.1639
499417 Sm 62 152 Pb 82 204 Dy 66 164 Pt 78 192 2.1415
499598 Sm 62 152 Pb 82 206 Dy 66 164 Pt 78 194 2.1387
499819 Sm 62 154 Pb 82 208 Dy 66 164 Pt 78 198 2.1368
499781 Sm 62 149 Pb 82 208 Dy 66 162 Pt 78 195 2.1275
358809 Zr 40 90 Pb 82 204 Ru 44 96 Pt 78 198 2.1042
505395 Gd 64 160 Pb 82 204 Er 68 166 Pt 78 198 2.1042
505294 Gd 64 152 Pb 82 204 Er 68 166 Pt 78 190 2.0949
501401 Eu 63 153 Pb 82 208 Ho 67 165 Pt 78 196 2.0707
499795 Sm 62 150 Pb 82 208 Dy 66 162 Pt 78 196 2.0521
505693 Gd 64 155 Pb 82 208 Er 68 167 Pt 78 196 2.0521
501270 Eu 63 153 Pb 82 204 Ho 67 165 Pt 78 192 2.0484
501352 Eu 63 153 Pb 82 206 Ho 67 165 Pt 78 194 2.0456
499391 Sm 62 150 Pb 82 204 Dy 66 162 Pt 78 192 2.0297
505319 Gd 64 155 Pb 82 204 Er 68 167 Pt 78 192 2.0297
485303 Ba 56 135 Pb 82 207 Nd 60 148 Pt 78 194 2.0288
499572 Sm 62 150 Pb 82 206 Dy 66 162 Pt 78 194 2.0269
505495 Gd 64 155 Pb 82 206 Er 68 167 Pt 78 194 2.0269
505674 Gd 64 154 Pb 82 208 Er 68 168 Pt 78 194 2.0251
505354 Gd 64 157 Pb 82 204 Er 68 167 Pt 78 194 2.0018
505459 Gd 64 152 Pb 82 206 Er 68 166 Pt 78 192 1.9990
499810 Sm 62 152 Pb 82 208 Dy 66 162 Pt 78 198 1.9878
489379 Ce 58 136 Pb 82 206 Sm 62 147 Pt 78 195 1.9617
489383 Ce 58 136 Pb 82 206 Sm 62 152 Pt 78 190 1.9617
466790 Te 52 124 Pb 82 204 Ba 56 130 Pt 78 198 1.9552
499711 Sm 62 152 Pb 82 207 Dy 66 163 Pt 78 196 1.8975
499726 Sm 62 144 Pb 82 208 Dy 66 160 Pt 78 192 1.8947
505694 Gd 64 155 Pb 82 208 Er 68 168 Pt 78 195 1.8947
499797 Sm 62 150 Pb 82 208 Dy 66 164 Pt 78 194 1.8760
499720 Sm 62 154 Pb 82 207 Dy 66 163 Pt 78 198 1.8704
508341 Dy 66 156 Pb 82 204 Yb 70 170 Pt 78 190 1.8621
489509 Ce 58 136 Pb 82 208 Sm 62 149 Pt 78 195 1.8574
499780 Sm 62 149 Pb 82 208 Dy 66 161 Pt 78 196 1.8565
505672 Gd 64 154 Pb 82 208 Er 68 166 Pt 78 196 1.8472
505374 Gd 64 158 Pb 82 204 Er 68 168 Pt 78 194 1.8434
499375 Sm 62 149 Pb 82 204 Dy 66 161 Pt 78 192 1.8341
499555 Sm 62 149 Pb 82 206 Dy 66 161 Pt 78 194 1.8313
505304 Gd 64 154 Pb 82 204 Er 68 166 Pt 78 192 1.8248
505334 Gd 64 156 Pb 82 204 Er 68 166 Pt 78 194 1.8248
505474 Gd 64 154 Pb 82 206 Er 68 166 Pt 78 194 1.8220
477521 Xe 54 130 Pb 82 204 Ce 58 136 Pt 78 198 1.8155
505554 Gd 64 152 Pb 82 207 Er 68 167 Pt 78 192 1.8146
484973 Ba 56 136 Pb 82 204 Nd 60 146 Pt 78 194 1.7969
499756 Sm 62 148 Pb 82 208 Dy 66 162 Pt 78 194 1.7922
505624 Gd 64 157 Pb 82 207 Er 68 166 Pt 78 198 1.7773
508417 Dy 66 156 Pb 82 206 Yb 70 170 Pt 78 192 1.7661
505644 Gd 64 152 Pb 82 208 Er 68 164 Pt 78 196 1.7633
499444 Sm 62 154 Pb 82 204 Dy 66 163 Pt 78 195 1.7596
499727 Sm 62 144 Pb 82 208 Dy 66 162 Pt 78 190 1.7456
505293 Gd 64 152 Pb 82 204 Er 68 164 Pt 78 192 1.7410
505397 Gd 64 160 Pb 82 204 Er 68 170 Pt 78 194 1.7410
505458 Gd 64 152 Pb 82 206 Er 68 164 Pt 78 194 1.7382
499742 Sm 62 147 Pb 82 208 Dy 66 161 Pt 78 194 1.7270
494580 Nd 60 148 Pb 82 206 Gd 64 158 Pt 78 196 1.7186
505494 Gd 64 155 Pb 82 206 Er 68 166 Pt 78 195 1.6916
505353 Gd 64 157 Pb 82 204 Er 68 166 Pt 78 195 1.6664
505372 Gd 64 158 Pb 82 204 Er 68 166 Pt 78 196 1.6655
489515 Ce 58 136 Pb 82 208 Sm 62 154 Pt 78 190 1.6618
485154 Ba 56 134 Pb 82 206 Nd 60 145 Pt 78 195 1.6543
505567 Gd 64 154 Pb 82 207 Er 68 167 Pt 78 194 1.6376
508449 Dy 66 156 Pb 82 207 Yb 70 171 Pt 78 192 1.6283
499635 Sm 62 147 Pb 82 207 Dy 66 164 Pt 78 190 1.6189
499712 Sm 62 152 Pb 82 207 Dy 66 164 Pt 78 195 1.6189
499697 Sm 62 150 Pb 82 207 Dy 66 163 Pt 78 194 1.6096
499554 Sm 62 149 Pb 82 206 Dy 66 160 Pt 78 195 1.6078
508418 Dy 66 156 Pb 82 206 Yb 70 172 Pt 78 190 1.5798
499376 Sm 62 149 Pb 82 204 Dy 66 163 Pt 78 190 1.5640
505303 Gd 64 154 Pb 82 204 Er 68 164 Pt 78 194 1.5640
485415 Ba 56 134 Pb 82 208 Nd 60 148 Pt 78 194 1.5500
505587 Gd 64 155 Pb 82 207 Er 68 164 Pt 78 198 1.5444
505544 Gd 64 160 Pb 82 206 Er 68 168 Pt 78 198 1.5426
505460 Gd 64 152 Pb 82 206 Er 68 168 Pt 78 190 1.5332
499570 Sm 62 150 Pb 82 206 Dy 66 160 Pt 78 196 1.5323
501376 Eu 63 153 Pb 82 207 Ho 67 165 Pt 78 195 1.5258
499696 Sm 62 150 Pb 82 207 Dy 66 162 Pt 78 195 1.5072
505590 Gd 64 155 Pb 82 207 Er 68 167 Pt 78 195 1.5072
499741 Sm 62 147 Pb 82 208 Dy 66 160 Pt 78 195 1.5034
499631 Sm 62 147 Pb 82 207 Dy 66 158 Pt 78 196 1.4690
499556 Sm 62 149 Pb 82 206 Dy 66 163 Pt 78 192 1.4680
499595 Sm 62 152 Pb 82 206 Dy 66 160 Pt 78 198 1.4680
505593 Gd 64 155 Pb 82 207 Er 68 170 Pt 78 192 1.4420
505318 Gd 64 155 Pb 82 204 Er 68 164 Pt 78 195 1.4336
499725 Sm 62 144 Pb 82 208 Dy 66 158 Pt 78 194 1.4196
505626 Gd 64 157 Pb 82 207 Er 68 170 Pt 78 194 1.4140
494735 Nd 60 148 Pb 82 208 Gd 64 158 Pt 78 198 1.3917
484999 Ba 56 137 Pb 82 204 Nd 60 145 Pt 78 196 1.3861
484998 Ba 56 137 Pb 82 204 Nd 60 143 Pt 78 198 1.3777
499743 Sm 62 147 Pb 82 208 Dy 66 163 Pt 78 192 1.3637
505305 Gd 64 154 Pb 82 204 Er 68 168 Pt 78 190 1.3590
508496 Dy 66 156 Pb 82 208 Yb 70 174 Pt 78 190 1.3358
489276 Ce 58 138 Pb 82 204 Sm 62 148 Pt 78 194 1.3218
499672 Sm 62 149 Pb 82 207 Dy 66 161 Pt 78 195 1.3115
508450 Dy 66 156 Pb 82 207 Yb 70 173 Pt 78 190 1.3115
505566 Gd 64 154 Pb 82 207 Er 68 166 Pt 78 195 1.3022
499755 Sm 62 148 Pb 82 208 Dy 66 160 Pt 78 196 1.2976
505709 Gd 64 156 Pb 82 208 Er 68 168 Pt 78 196 1.2883
485204 Ba 56 136 Pb 82 206 Nd 60 144 Pt 78 198 1.2817
499359 Sm 62 148 Pb 82 204 Dy 66 160 Pt 78 192 1.2752
499532 Sm 62 148 Pb 82 206 Dy 66 160 Pt 78 194 1.2724
505335 Gd 64 156 Pb 82 204 Er 68 168 Pt 78 192 1.2659
505475 Gd 64 154 Pb 82 206 Er 68 168 Pt 78 192 1.2631
505509 Gd 64 156 Pb 82 206 Er 68 168 Pt 78 194 1.2631
505523 Gd 64 157 Pb 82 206 Er 68 167 Pt 78 196 1.2622
499669 Sm 62 149 Pb 82 207 Dy 66 158 Pt 78 198 1.2463
499695 Sm 62 150 Pb 82 207 Dy 66 161 Pt 78 196 1.2361
499512 Sm 62 144 Pb 82 206 Dy 66 160 Pt 78 190 1.2258
505553 Gd 64 152 Pb 82 207 Er 68 164 Pt 78 195 1.2184
494434 Nd 60 148 Pb 82 204 Gd 64 154 Pt 78 198 1.2100
499392 Sm 62 150 Pb 82 204 Dy 66 164 Pt 78 190 1.2100
494579 Nd 60 148 Pb 82 206 Gd 64 156 Pt 78 198 1.2072
499794 Sm 62 150 Pb 82 208 Dy 66 160 Pt 78 198 1.2054
499710 Sm 62 152 Pb 82 207 Dy 66 161 Pt 78 198 1.1718
485330 Ba 56 137 Pb 82 207 Nd 60 146 Pt 78 198 1.1532
508511 Dy 66 158 Pb 82 208 Yb 70 172 Pt 78 194 1.1495
499374 Sm 62 149 Pb 82 204 Dy 66 158 Pt 78 195 1.1355
452868 Sn 50 118 Pb 82 204 Xe 54 124 Pt 78 198 1.1262
499360 Sm 62 148 Pb 82 204 Dy 66 162 Pt 78 190 1.1262
499573 Sm 62 150 Pb 82 206 Dy 66 164 Pt 78 192 1.1141
505524 Gd 64 157 Pb 82 206 Er 68 168 Pt 78 195 1.1048
505535 Gd 64 158 Pb 82 206 Er 68 168 Pt 78 196 1.1038
505508 Gd 64 156 Pb 82 206 Er 68 166 Pt 78 196 1.0852
494649 Nd 60 145 Pb 82 207 Gd 64 158 Pt 78 194 1.0694
499351 Sm 62 147 Pb 82 204 Dy 66 161 Pt 78 190 1.0610
499415 Sm 62 152 Pb 82 204 Dy 66 161 Pt 78 195 1.0610
499389 Sm 62 150 Pb 82 204 Dy 66 158 Pt 78 196 1.0600
485205 Ba 56 136 Pb 82 206 Nd 60 146 Pt 78 196 1.0572
485000 Ba 56 137 Pb 82 204 Nd 60 146 Pt 78 195 1.0423
499533 Sm 62 148 Pb 82 206 Dy 66 162 Pt 78 192 1.0302
485385 Ba 56 132 Pb 82 208 Nd 60 150 Pt 78 190 1.0284
505545 Gd 64 160 Pb 82 206 Er 68 170 Pt 78 196 1.0014
499412 Sm 62 152 Pb 82 204 Dy 66 158 Pt 78 198 0.9958
499651 Sm 62 148 Pb 82 207 Dy 66 161 Pt 78 194 0.9762
499520 Sm 62 147 Pb 82 206 Dy 66 161 Pt 78 192 0.9650
494736 Nd 60 148 Pb 82 208 Gd 64 160 Pt 78 196 0.9529
505720 Gd 64 157 Pb 82 208 Er 68 167 Pt 78 198 0.9352
494439 Nd 60 148 Pb 82 204 Gd 64 160 Pt 78 192 0.9306
499619 Sm 62 144 Pb 82 207 Dy 66 161 Pt 78 190 0.9296
494581 Nd 60 148 Pb 82 206 Gd 64 160 Pt 78 194 0.9278
505292 Gd 64 152 Pb 82 204 Er 68 162 Pt 78 194 0.9212
510209 Er 68 162 Pb 82 208 Hf 72 176 Pt 78 194 0.9166
494648 Nd 60 145 Pb 82 207 Gd 64 156 Pt 78 196 0.9101
505609 Gd 64 156 Pb 82 207 Er 68 167 Pt 78 196 0.9008
508477 Dy 66 161 Pb 82 207 Yb 70 172 Pt 78 196 0.8914
484923 Ba 56 134 Pb 82 204 Nd 60 148 Pt 78 190 0.8840
499757 Sm 62 148 Pb 82 208 Dy 66 164 Pt 78 192 0.8793
485433 Ba 56 135 Pb 82 208 Nd 60 148 Pt 78 195 0.8514
494672 Nd 60 148 Pb 82 207 Gd 64 157 Pt 78 198 0.8458
505333 Gd 64 156 Pb 82 204 Er 68 164 Pt 78 196 0.8272
505473 Gd 64 154 Pb 82 206 Er 68 164 Pt 78 196 0.8244
499358 Sm 62 148 Pb 82 204 Dy 66 158 Pt 78 194 0.8002
506176 Tb 65 159 Pb 82 204 Tm 69 169 Pt 78 194 0.8002
494405 Nd 60 146 Pb 82 204 Gd 64 156 Pt 78 194 0.7908
485156 Ba 56 134 Pb 82 206 Nd 60 148 Pt 78 192 0.7880
505726 Gd 64 158 Pb 82 208 Er 68 168 Pt 78 198 0.7769
505708 Gd 64 156 Pb 82 208 Er 68 166 Pt 78 198 0.7582
499346 Sm 62 144 Pb 82 204 Dy 66 158 Pt 78 190 0.7536
499650 Sm 62 148 Pb 82 207 Dy 66 160 Pt 78 195 0.7526
505610 Gd 64 156 Pb 82 207 Er 68 168 Pt 78 195 0.7433
494436 Nd 60 148 Pb 82 204 Gd 64 157 Pt 78 195 0.7349
485445 Ba 56 136 Pb 82 208 Nd 60 146 Pt 78 198 0.7303
499521 Sm 62 147 Pb 82 206 Dy 66 163 Pt 78 190 0.6949
499597 Sm 62 152 Pb 82 206 Dy 66 163 Pt 78 195 0.6949
508510 Dy 66 158 Pb 82 208 Yb 70 170 Pt 78 196 0.6921
505730 Gd 64 160 Pb 82 208 Er 68 170 Pt 78 198 0.6744
508347 Dy 66 158 Pb 82 204 Yb 70 170 Pt 78 192 0.6697
508427 Dy 66 158 Pb 82 206 Yb 70 170 Pt 78 194 0.6669
505648 Gd 64 152 Pb 82 208 Er 68 170 Pt 78 190 0.6651
499511 Sm 62 144 Pb 82 206 Dy 66 158 Pt 78 192 0.6576
508478 Dy 66 161 Pb 82 207 Yb 70 174 Pt 78 194 0.6222
499652 Sm 62 148 Pb 82 207 Dy 66 163 Pt 78 192 0.6129
485017 Ba 56 138 Pb 82 204 Nd 60 144 Pt 78 198 0.6045
489405 Ce 58 138 Pb 82 206 Sm 62 148 Pt 78 196 0.5822
505534 Gd 64 158 Pb 82 206 Er 68 166 Pt 78 198 0.5738
494611 Nd 60 143 Pb 82 207 Gd 64 156 Pt 78 194 0.5663
485318 Ba 56 136 Pb 82 207 Nd 60 145 Pt 78 198 0.5291
508461 Dy 66 158 Pb 82 207 Yb 70 171 Pt 78 194 0.5291
505670 Gd 64 154 Pb 82 208 Er 68 164 Pt 78 198 0.4974
508348 Dy 66 158 Pb 82 204 Yb 70 172 Pt 78 190 0.4834
505673 Gd 64 154 Pb 82 208 Er 68 167 Pt 78 195 0.4602
499796 Sm 62 150 Pb 82 208 Dy 66 163 Pt 78 195 0.4322
484972 Ba 56 136 Pb 82 204 Nd 60 145 Pt 78 195 0.4182
494673 Nd 60 148 Pb 82 207 Gd 64 160 Pt 78 195 0.4080
505675 Gd 64 154 Pb 82 208 Er 68 170 Pt 78 192 0.3950
505710 Gd 64 156 Pb 82 208 Er 68 170 Pt 78 194 0.3950
505634 Gd 64 158 Pb 82 207 Er 68 167 Pt 78 198 0.3894
508428 Dy 66 158 Pb 82 206 Yb 70 172 Pt 78 192 0.3875
485018 Ba 56 138 Pb 82 204 Nd 60 146 Pt 78 196 0.3800
508362 Dy 66 161 Pb 82 204 Yb 70 171 Pt 78 194 0.3530
489544 Ce 58 138 Pb 82 208 Sm 62 150 Pt 78 196 0.3474
508382 Dy 66 164 Pb 82 204 Yb 70 172 Pt 78 196 0.3335
489277 Ce 58 138 Pb 82 204 Sm 62 150 Pt 78 192 0.3251
489406 Ce 58 138 Pb 82 206 Sm 62 150 Pt 78 194 0.3223
505370 Gd 64 158 Pb 82 204 Er 68 164 Pt 78 198 0.3158
508376 Dy 66 163 Pb 82 204 Yb 70 173 Pt 78 194 0.3065
485219 Ba 56 137 Pb 82 206 Nd 60 145 Pt 78 198 0.2944
505373 Gd 64 158 Pb 82 204 Er 68 167 Pt 78 195 0.2785
499519 Sm 62 147 Pb 82 206 Dy 66 158 Pt 78 195 0.2664
489543 Ce 58 138 Pb 82 208 Sm 62 148 Pt 78 198 0.2552
510141 Er 68 162 Pb 82 204 Hf 72 176 Pt 78 190 0.2506
508487 Dy 66 163 Pb 82 207 Yb 70 174 Pt 78 196 0.2487
505721 Gd 64 157 Pb 82 208 Er 68 170 Pt 78 195 0.2366
494726 Nd 60 146 Pb 82 208 Gd 64 158 Pt 78 196 0.2357
505727 Gd 64 158 Pb 82 208 Er 68 170 Pt 78 196 0.2357
494406 Nd 60 146 Pb 82 204 Gd 64 158 Pt 78 192 0.2133
505375 Gd 64 158 Pb 82 204 Er 68 170 Pt 78 192 0.2133
494561 Nd 60 146 Pb 82 206 Gd 64 158 Pt 78 194 0.2105
499534 Sm 62 148 Pb 82 206 Dy 66 164 Pt 78 190 0.2105
505536 Gd 64 158 Pb 82 206 Er 68 170 Pt 78 194 0.2105
508355 Dy 66 160 Pb 82 204 Yb 70 170 Pt 78 194 0.1947
510208 Er 68 162 Pb 82 208 Hf 72 174 Pt 78 196 0.1891
505457 Gd 64 152 Pb 82 206 Er 68 162 Pt 78 196 0.1816
510140 Er 68 162 Pb 82 204 Hf 72 174 Pt 78 192 0.1667
508486 Dy 66 163 Pb 82 207 Yb 70 172 Pt 78 198 0.1658
510178 Er 68 162 Pb 82 206 Hf 72 174 Pt 78 194 0.1639
508368 Dy 66 162 Pb 82 204 Yb 70 172 Pt 78 194 0.1574
510179 Er 68 162 Pb 82 206 Hf 72 176 Pt 78 192 0.1546
508460 Dy 66 158 Pb 82 207 Yb 70 170 Pt 78 195 0.1472
508512 Dy 66 158 Pb 82 208 Yb 70 174 Pt 78 192 0.1435
510210 Er 68 162 Pb 82 208 Hf 72 178 Pt 78 192 0.1341
508462 Dy 66 158 Pb 82 207 Yb 70 173 Pt 78 192 0.1192
489318 Ce 58 142 Pb 82 204 Sm 62 150 Pt 78 196 0.1099
508476 Dy 66 161 Pb 82 207 Yb 70 170 Pt 78 198 0.0820
508383 Dy 66 164 Pb 82 204 Yb 70 174 Pt 78 194 0.0643
499531 Sm 62 148 Pb 82 206 Dy 66 158 Pt 78 196 0.0605
506201 Tb 65 159 Pb 82 206 Tm 69 169 Pt 78 196 0.0605
489545 Ce 58 138 Pb 82 208 Sm 62 152 Pt 78 194 0.0596
508375 Dy 66 163 Pb 82 204 Yb 70 172 Pt 78 195 0.0550
494404 Nd 60 146 Pb 82 204 Gd 64 154 Pt 78 196 0.0540
494560 Nd 60 146 Pb 82 206 Gd 64 156 Pt 78 196 0.0512
499571 Sm 62 150 Pb 82 206 Dy 66 161 Pt 78 195 0.0335
489317 Ce 58 142 Pb 82 204 Sm 62 148 Pt 78 198 0.0177
511520 Yb 70 176 Pb 82 204 W 74 182 Pt 78 198 0.0084
505302 Gd 64 154 Pb 82 204 Er 68 162 Pt 78 196 0.0075
So there are a great number of elements which will successfully interact with lead to transmute into platinum.
Some interesting ones (picked based upon the easy availability of the elements, and the ease with which they can be separated after processing):
id E1 Z1 A1 E2 Z2 A2 E3 Z3 A3 E4 Z4 A4 MeV
92343 S 16 32 Pb 82 207 Ca 20 44 Pt 78 195 25.7670
Now the only thing left to do is to figure out the procedure by which to most efficiently transmute any given element into any other given element... usually it's done via electrical discharge, but other methods might increase yield (by combining any of pressure, temperature or bombardment with protons, neutrons or electrons)
To produce electrons is easy enough... it's just electrical current.
To produce protons, use a device similar to the Cockroft / Walton device:
To produce neutrons takes a bit more work because you have to overcome the strong fundamental force... first you have to strip the electrons from 2He, leaving only the nucleus (two protons, two neutrons). This is done by hitting the 2He atom with sufficiently strong light to ionize it. Then hit the nucleus with strong x-ray energy to break apart the protons and neutrons, then attract away the protons with a DC-biased plate, leaving only the neutrons.
Or, you can create deuterium by electrolyzing water to remove the light water, leaving only the heavy water (deuterium), then adding more water and electrolyzing again, etc., etc... eventually you'll build up a large quantity of deuterium (this is the way the Nazis did it at the Vemork plant in Norway, before the Allies destroyed it).
Or keep the water at an exact temperature to evaporate the light water away (D2O boils at 101.4 C, whereas H2O boils at 99.97 C at atmospheric pressure... you can increase the evaporation rate by drawing a vacuum and running a lower temperature to save energy).
Or do both... first electrolyze, then evaporate. In normal water, there is only one deuterium atom for every 6400 hydrogen atoms, but deuterium is more prevalent in the residue of water used as an electrolyte. An analysis of the residues from the Vemork hydroelectric plant, a large-scale hydrogen production plant using electrolysis of water for ammonia production, showed a hydrogen/deuterium ratio of 48. So electrolyzing the water increases the hydrogen/deuterium ratio by 33.33 times, leaving less water to be evaporated later to further concentrate the heavy water.
Deuterium contains one proton and one neutron, so you can then use the above techniques to strip the protons away, leaving only the neutrons. Free neutrons have a half-life of ~14 minutes 42 seconds, so you need to continually produce them, Their decay involves the emission of a W− boson from one of the down quarks within the neutron, converting the down quark into an up quark and the neutron into a proton; the W− then decays into an electron and an electron antineutrino.
