EXHAUST MIXING FOR FUEL EFFICIENCY GAINS
waqas148
« on January 19th, 2012, 11:39 PM »
I recently tested exhaust gas re circulation in my car's air in take with the Compressed Natural Gas as the fuel source
and by just doing that i got a fuel mileage of 287km/cylinder of NG... before that it was 180km/cylinder max (mileage tested on highway)....
thats about
62.71% gain to previous and about 31.35% overall gain.
Acceleration of the car was a bit low than previous but top speed was the same i-e 100km/hr
I think its a proof of concept that exhaust gas mixing does infact reduce burn rate and increases the fuel volume propotionally.
Cheers!!!! ;)
RE: EXHAUST MIXING FOR FUEL EFFICIENCY GAINS
« Reply #1, on January 20th, 2012, 12:23 AM »
Quote from waqas148 on January 19th, 2012, 11:39 PM
thats about
Cheers!!!! ;)
i wonder if this could be applied to LP gas or even Normal Gas engines?
also, are you metering the NG going in to the engine with a valve?  or is the throttle doing that? and there is a normal air intake on it? im not familiar with a NG engine.
sweet stuff!!!
waqas148
« Reply #2, on January 20th, 2012, 12:38 AM »
Quote from ~Russ/Rwg42985 on January 20th, 2012, 12:23 AM
thats about
Cheers!!!! ;)
sweet stuff!!!
Hi Russ!!
My setup is exactly same as for LPG.
I am not metering NG, its done through throttle ... the valve is to control the air-fuel mixture and is adjusted once so that engine vacuum suck in equal proportion of air-fuel mixture upon full range of throttle.
cheers :)
« Reply #3, on January 20th, 2012, 03:15 AM »
Quote from waqas148 on January 20th, 2012, 12:38 AM
thats about
Cheers!!!! ;)
sweet stuff!!!
Hi Russ!!
cheers :)
ok, interesting... :) thanks! ~Russ
CocaCola
« Reply #4, on March 9th, 2012, 02:54 AM »
Quote from ~Russ/Rwg42985 on January 20th, 2012, 03:15 AM
thats about
Cheers!!!! ;)
sweet stuff!!!
Hi Russ!!
cheers :)
I drive a car on methane. A month ago I could not ride it due to clogged exhaust. Mehanic  told me that the catalyst was dissolved, but when I cut the middle of the pipe , it  was full of ice. I melt it and put it back into place and drilled the holes for the water goes out , and now it's ok.
conclusion - methane is converted into water. I do not know if it would happen without a catalyst?
« Reply #5, on March 9th, 2012, 03:06 AM »
Quote from CocaCola on March 9th, 2012, 02:54 AM
thats about
Cheers!!!! ;)
sweet stuff!!!
Hi Russ!!
cheers :)
interesting...that's crazy! so its  cold enough where you are that it stayed frozen?
thanks! ~Russ
CocaCola
« Reply #6, on March 9th, 2012, 03:40 AM »
Quote from ~Russ/Rwg42985 on March 9th, 2012, 03:06 AM
sweet stuff!!!
Hi Russ!!
cheers :)
thanks! ~Russ
This was the coldest winter in Europe. 20 days the temperature was below zero (Celsius).
So , the gas  is so pure that is possible to go back into the engine without consequences . I would like to make benefited from it ,and verify the exact composition of these gases. If you know a method send it.
