Five Thousand Inventions in Limbo...
Kinda like the Electrolyzers that put out 900 bar no compressor. Invisible
There is hope. According to the Invention Secrecy Act, "The only way an inventor can avoid the risk of such imposed secrecy is to forgo patent protection". So there is a way around it.
The irony in all this is the U.S. Patent Office could publicly release all of these patents and the world would not noticeably change.
The only secret they are trying desperately to conceal is that your own thought and intentions dictate the kind of world you have. None of those 5000 patents will even work unless you believe they will work.
Basically we need someone to figure it out and not want to patent it and just explain it to everyone haha.
Once an idea becomes mainstream it falls into the category of common knowledge
and therefore can not be up for a patent. But I must warn you. If you create a device
that could be used by another country's government to cause harm, you will be deemed
a terrorist by aiding and embedding. Once it is out game on and good luck.
^ This..... so whatever gets created it has to be benign but capable of powering stuff and being useful.... problem is the power needed to run lets say a car or house appliances without gas is something that could probably be used to create enough power that could be misused in some way.
Re: Five Thousand Inventions in Limbo...
« Reply #8, on April 4th, 2018, 01:38 AM »Last edited on April 4th, 2018, 08:44 AM
https://en.wikipedia.org/wiki/I_Saw_the_Figure_5_in_Gold
...https://www.youtube.com/watch?v=95WvoqVKMUQ
http://mashable.com/2016/08/24/street-art-tribute-omran-daqneesh/
We might speak at great length about the relation of the number 7 to the number 12
and have to leave much that concerns the deep mysteries of our universe still incomprehensible.
http://wn.rsarchive.org/Lectures/GA113/English/RSPC1940/19090831p01.html
Golden Spiral
http://halexandria.org/dward103.htm
NINE PALACES (JIUGONG):
Magic Squares (Hetu and Luoshu)
According to Chinese tradition Huangdi (2688 BC) invented magic squares to counter and slay black serpents. Magic squares are instruments of prophecy, and also tools to explain the processes of interior alchemy (neidan).
There are conflicting stories about the origins of the diagrams, Hetu and Luoshu. The most common legend claims that they were discovered by Fu Xi who then used them to derive the bagua. The Hetu was on the back of a dragon-horse emerging from the Yellow River, while the Luoshu was on the back of a turtle emerging from the River Luo. Another tradition states that Dayu was the discoverer. Yet another tradition claims that Fu Xi discovered the Hetu and Dayu discovered the Luoshu. Until the 12th c.CE, the names of the two diagrams were reversed (the present Hetu was known as the Luoshu, and vice versa). They were given their present names by Taoist philosopher Juxi.
The nine palaces relate directly to the legendary arithmetic of the nine numbers within the Hetu and the Loshu, which actually derive the former and later heaven sequences of trigrams respectively. In both diagrams, even (yin) numbers are represented by white circles, and odd (yang) numbers are represented by black circles. Confucianism claims that these two magical diagrams in additon to the concept of the five elements (wuxing) are the mathematical origins of the Yijing.
According to the Shangqing pai, the brain is divided into nine palaces which are inhabited by nine deities (shen). The palaces are arranged between the forehead and the nape of the neck in two rows, of four and five compartments. The highest palaces are the first three palaces of the lower row, where Huang Laojun and his assistants reside. The palace found at the center of the brain is called niwan, after the Buddhist nirvana, where Taiyi resides.
Hetu: Former Heaven Sequence (see fig. 37-39)
Legend: (2943 BC)
The pattern that became the prototype for the Former Heaven Sequence, was discovered on a dragon-horse, or unicorn (chiling) emerging from the river He by the shaman-king Fu Xi (demigod).
Arithmetic:
? Excluding 5, odd and even numbers add up to 20
? Inner four numbers add up to 10
? Outer four numbers add up to 30
? Outer number minus the inner number of any side is equal to 5
Numerology:
? 5 neutralizes and unifies
? 5 is derived from adding or subtracting one yang and one yin number
? 5 implies establishment
? All numbers contain 0 and 1
? 1 is the established factor
? 0 is that which is established
? 5 can be expressed as 0: for it can go further up or down from a central reference position
COSMOLOGY
http://www.boneoracle.com/Cosmology.htm
Squaring the Circle using the Pythagorean Triangle
http://www.benpadiah.com/MISC_diagrams/pages/equations/squarecircles.html
Yang Hui magic concentric circle
http://www.wikiwand.com/en/Magic_circle_(mathematics)
I then began to change my trail of thought;
I began to think of the name of our Creator in my own language, which created lightness to my energy,
almost as if all the tension of sitting for now NINE DAYS was being washed away.
M. DUCHAMP Rotary Glass Plates (Precision Optics). 1969
https://vimeo.com/29887718
...https://www.youtube.com/watch?v=eGjTc7iIJbg
https://i.pinimg.com/originals/1d/2d/fc/1d2dfcc35376d848763a5cf21f82f581.gif
He saith unto them, How many loaves have ye?
GO AND SEE.
And when they knew, they say, PHIve, and TWO fishes.
.Science history
http://open-source-energy.org/?topic=3224.msg49185#msg49185
https://www.flickr.com/photos/sanchtv/4192677571/
Notice every other number. Never touches PHIve though. The double helix works with 2 waves.
http://www.gorillagrow.org/home.html
« Reply #9, on April 12th, 2018, 12:59 PM »Last edited on April 12th, 2018, 01:33 PM
Outline of MAGNETISM lecture in July Science & Energy conference
https://www.youtube.com/watch?v=JoZP9ZkRxac
Friday 1100am~1230pm KEN WHEELER – UNCOVERING THE MISSING SECRETS OF MAGNETISM (90 min)
Ken Wheeler is an expert in Ancient Greek, Pali, & Russian and has worked for various governmental agencies as a translator. He was the founder of a popular website that focused heavily on the teachings and history of Buddhism with a heavy focus on the etymology of its related language. Ken is passionate about learning, exploring and teaching various subjects, especially magnetism. Several years ago, he released a free book called Uncovering the Missing Secrets of Magnetism, which is already in its fourth edition. This work was dedicated to some of Ken’s personal friends and associates, but also to those that have paved the way for the electrical sciences with clarity and that includes Tesla, Maxwell, Steinmetz, Heaviside and Eric P. Dollard. The book is available here: https://archive.org/details/magnetism1small (3rd edition)
http://energyscienceconference.com/2018-speakers/
LIGHT: Destroying the 'wave particle' fantasy. Phase & Kinematic interference
...https://www.youtube.com/watch?v=MVMvxz0hAi0
« Reply #10, on April 19th, 2018, 02:04 AM »Last edited on April 19th, 2018, 02:47 AM
Light cannot be an emission by definition & other Atomistic fantasies about the nature of LIGHT
https://www.youtube.com/watch?v=OkFPGKrMi0k
“While learning the HOW, we have never learned the WHY or WHAT. That is why science today has so little knowledge of CAUSE. It produces effects but cannot tell the WHY of those effects.”
- Walter Russell
https://wikischool.org/divided_light
Nature's Field Metaphysics GRAND UNITY within Field Theory
...https://www.youtube.com/watch?v=qC5JLA75i64
- Walter Russell
« Reply #12, on April 19th, 2018, 02:55 AM »Last edited on April 19th, 2018, 01:35 PM
We look at our dual-trace oscilloscopes and very few recognized the signal, the energy, is actually spinning or at least trying to. Kind of sad. :-(
spiral sQuar
"Stop acting so small. You are the universe in ecstatic motion."
:shocked:
Frequencies in sun
https://vimeo.com/265362435
The space octaves and all their frequencies (or wave vibrations) are gathered in the sun. Those frequencies reproduce themselves at a time frequency of 186,000 miles per second and they build the sun gereo-actively, which is a concentrative action of Mind, until the sun becomes a full sphere and then it will start its death cycle … the body will come to rest in the reverse of those frequencies …. the sun will turn itself inside out … and while doing so it will give life out of decay in lesser frequencies …
https://www.youtube.com/user/helenahannah/videos?disable_polymer=1
Spirals by Mike Callinan and Larry Shook
http://jwilson.coe.uga.edu/emt669/Student.Folders/Callinan.Michael/Essays/spirals/Spirals.html
The Spiral of Theodorus
https://sites.google.com/site/jbutterfieldmath378/investigation-4
Bode's Law Doesn't Bode Well for Us
http://www.mostlycolor.ch/2010/04/bodes-law-doesnt-bode-well-for-us.html
http://www.astro.cornell.edu/academics/courses/astro201/bodes_law.htm
THE BIRTH OF A NEW DAY
https://forum.davidicke.com/showthread.php?t=61370&page=75
In reference to the symbolism of eight in the Resurrection, one author wrote, “Christ rose from the dead on ‘the first day of the week,’ that was of necessity the eighth day.”
“The octagon draws on the symbolism of the number eight, emblematic of renewal. Eight-sided forms were felt to mediate between the symbolism of the square, representing earthly existence, and the circle (standing for heaven or eternity).” Of course, Christ is the great mediator between heaven and earth—between man and God. Thus the number eight is best seen as a symbol of Jesus and that which he has done for those who seek to follow him.
The Seal of Melchizedek?
https://rsc.byu.edu/archived/volume-11-number-3-2010/seal-melchizedek-0
There are 8 “5’s”
https://www.google.nl/search?q=resurrection%2040%20days
Since four divided by pi is equal to the square root of phi (accurate to 99.9%),
the height, sq rt phi, is also 4/pi, as shown in the diagram.
http://grahamhancock.com/phorum/read.php?1,153200,153200
To account for the true Area Under The Curve, based on Fractal realization, Jain 108 of Oz, has determined that Pi must be based on Phi (ϕ = 1.618033…) considering that the area of the circle in proportion to the area of its circumscribing square, is naturally in a Phi-Ratioed Harmonic expressed as 1:1.272… which is the Square Root of Phi aka The Golden Root, and precisely the height of the Cheops Pyramid in Gizeh which has stored this ancient knowledge in stone for millennia.
The BOOK Of PHI, vol 9: Is Pi A Lie?
https://jain108.com/product/the-book-of-phi-vol-9-is-pi-a-lie/
Ashtalakshmi.. Star of Goddess Laksmi, it represents the eight forms of health..These emanations represent eight forms of wealth: monetary, ability to transport, endless prosperity, victory, patience, health and nourishment, knowledge, and family.
https://www.facebook.com/photo.php?fbid=1750060408603131&set=a.1750059518603220.1073741974.100007975667128&type=3
https://www.cropcirclecenter.com/ccdata/2015/07/16/DE20150716_A.html
