Voltrolysis Coined by Secure Supplies with comparisions to Stanley Meyer / Tesla
« on March 19th, 2018, 07:19 PM »Last edited on February 12th, 2023, 09:56 AM
Voltrolysis
Explanation For those who want to know
Electrolysis
i In chemistry and manufacturing, electrolysis is a technique that uses a direct electric current
(DC) to drive an otherwise non-spontaneous chemical reaction. Electrolysis is commercially important
 as a stage in the separation of elements from naturally occurring sources such as ores using an electrolytic cell.
Very Different from Voltrolysis cell Electrolysis uses a variety of salts electrolyte to cause a dielectric breakdown
and high amp draw to disassociate chemical bonds creating a exothermic heat in the process.
Voltrolysis
by Stanley Meyer In Chemistry and Ionization and Disassociation of Gas is a technique Using no Electrolyte
 and uses a a Indirect Voltage Source a Voltage Plasma Field Based on a DC to Cause the Ionic Dissociation
of Chemical Bonds in Liquids and Gas Chemistry. The primary coil is electrically isolated (no electrical connection
between primary and secondary coil) to form Voltage Intensifier Circuit
Voltage amplitude or voltage potential is increased when secondary coil is wrapped with more turns of wire.
 Isolated electrical ground (J) prevents electron flow from input circuit ground causing a Charge on Cell Plates
 and a Volt Based Plasma Field which acts as a Catalyst to dissociate chemical Bonds. Very Different from Electrolytic
cells and Not Electrolysis as no electrolyte. A Low Amp high Voltage Solution Similar to how a Fluro Light
Works with a
choke/ballast restricting amps Having a Cold Process with little of no Exothermic Reaction heat as no electrolyte
shorting
 cell and grounding the dissolved gases which make the water a fuel a carrier.?
So Use Volts not amps and BIngo your alot closer
Thermo
THE WATER FUEL CELL AND THE FIRST AND SECOND LAWS OF THERMODYNAMICS
The Water Fuel Cell technology encounters a credibility gap because it appears to run counter to the long
established laws governing our interpretation of Nature. In fact, the water Fuel Cell is entirely natural.
It merely demonstrates a new and revolutionary way of harnessing what nature has always had on offer.
It does not infringe the two main laws of thermodynamics, i.e.:
THE FIRST LAW: "The total energy of a theromdynamic system remains constant although it may be transformed
from one form to another." In the case of Water Fuel Cell technology, the system is global. The
energy required to drive the engine comes from the zero-point energy contained in the water, a virtually
 inexhaustible source. The exhaust from the engine is water vapour which returns to the atmosphere.
Manage
 THE SECOND LAW: As originally formulated by R. Clausius in 1865, this law states that "The entropy of
the World strives towards a maximum". As recently formulated by Prigogine and Stengers, this law "contains
 two fundamental elements: (1) a negative one that expresses the impossibility of certain processes (e.g.
heat flowing from a cold to a hot source) and (2) a positive, constructive one. It is the impossibility of
certain processes that permits us to introduce a function, entropy, which increases uniformly and behaves as
an attractor for isolated systems". It is at maximum when the system is in equilibrium. Non-equilibrium is the
source of order and brings order out of chaos. Since Water Fuel Cell technology postulates non-equilibrium,
it can be said to be supported by the positive element of this Law.?
Use this Knowledge Well Teach the Correct Explanations of what is occuring
