EPG UNDERSTANDING MORE
Re: EPG UNDERSTANDING MORE
« Reply #1, on December 20th, 2017, 01:38 AM »
Some Important Notes from alot of study
 After Studying Searl Magnetic SEG 2 things seam very apparent and possible with Stand machines
I call these Introvert (Stans Way)  and extrovert.( electrons from our side tube)
Introvert
1a
The Stan Meyer Invert Method his stated method  of having a magnetic gas move through tube,
could in fact be improved by have sensitive fer rite pickup inside the tube to make the voltage spikes, further enhancing stand magnetic stimulation of coils on outside of tube.  Some of this was thought of as Searl Using the Gathering and Damming of electron using ferit in his system.
1b
 it could also extract elections from gas inside tube which is not necessary;y same as Stan methods
similar to a Magnetic Flow Meter which would increase sensitivity of a could pickup or magnetic movement of a pick up coil, ( as there seam to be some debate about the copper preventing the magnetic gas making flux in pick up coils coil.
Extrovert
It seams pulsing gas with LED Laser will cause lithium oxygen and h2 to cool and become magnetic.
Also  of Large Turbine use pure h2 to cool the machines ,gas flows through and cool the steel
some run the gas through the stators.
it is total possible that h2 or Magnetic gas compose could impart more electrons into the stator by attracting electron from air.
And Such the Epg Stans Unit will get vert cold when gas flowing as a rate of speed through it
it will in fact attract electron from air these could be harvested just like searl did. As the Ionising and air will flow to centre of egp.
Further pulsing with laser  will increase the effect
Reference
Scientists Create First Ever Magnetic Gas
By Stuart Fox September 18, 2009
https://www.popsci.com/scitech/article/2009-09/scientists-create-first-ever-magnetic-gas
« Reply #2, on December 20th, 2017, 01:38 AM »
​Article Clipping
For decades, scientists have debated whether or not gasses could display the same magnetic properties
as solids.  Now, thanks to some MIT scientists, they know the answer is a freezing cold yes.
MIT researchers have observed magnetism in an atomic gas of lithium cooled down to 150 millionths
of a degree above absolute zero. This experiment represents a point of unification between condensed
matter research and the field of atomic science and lasers, and could influence areas such as data storage
and medical diagnostics.
To get the lithium gas so cold, the researchers trained an infrared laser beam on the gaseous cloud.
Laser cooling is the primary method physicists use to lower gas temperatures to near absolute zero.
The laser essentially stun the atoms, slowing them down, and thus lowering the temperature.
After initially growing, the cloud began to shrink. That shrinkage, combined with the speed of
expansion after the laser turned off, indicated that the lithium atoms had become magnetic.
"It's very important from an overall theoretical point of view because it gives us an understanding
of magnetism at its smallest possible scale," Scott Pritchard, an MIT professor, and one of
the experiment leaders, told us.
« Reply #3, on December 20th, 2017, 01:40 AM »
    It may Be Possible to have this type of arrangement making arc with ferrite and at same time have ferite pickups be fluxed by gas at other points  Electro  is doing some thing very close to this
I Share this as we seam to be sitting on our hands in regards to EPG in USA LOL ..............https://youtu.be/FaqQhMzBLFU
« Reply #7, on December 20th, 2017, 10:12 AM »
Put this one together it is interesting , that magnetic gas may may ring like plasmoids
« Reply #9, on August 29th, 2018, 01:05 AM »
stan had spiral inserts in egp tube
tesla had a very similar fueless generator
More importantly, these modifications on the Faraday design eliminated one of the biggest problems in any physical system - the reaction to every action. It is this reaction that works to cancel out whatever effort goes into causing the original action. In an electrical system if there are two turns of wire wound next to each other and a current is sent through the wire, the current passing through the first loop will set up a magnetic field that will work against the current passing through the second loop.
The spiral divisions in the disk cause the current to travel the full radius of the disk or, as in his alternative version of the generator, to make a full trip around the outside edge of the disk. Because the current is flowing in a large circle at the rim of the disk, the magnetic field created by the current not only does not work against the field magnet above the circular plate, as in conventional generators, but it actually reinforces the magnet. So as the disk cuts the magnetic lines to produce a current, the current coming off of the disk strengthens the magnet, allowing it to produce even more current.
Like conventional direct current generators, the unipolar dynamo also functions as a motor if current is put into the disk while under the magnet, and this seems to be the last element that could make the device self-sustaining, that is, capable of generating a current after being disconnected from an outside source of movement like falling water or steam.
Rotation is started by, say, a motor powered by line current. Both a generator and a motor disk are mounted in the magnetic enclosure. As the disks gain speed, current is produced which, in turn, reinforces the magnets, which cause more current to be generated. That current is, likely, first directed to the motor disk which increases the speed of the system. At a certain point the speed of the two disks is great enough that the magnetic field created by the current has the strength to keep the dynamo/motor going by itself.
« Reply #10, on August 30th, 2018, 08:24 AM »Last edited on May 30th, 2020, 03:21 AM
UPDATED
here are Gerber,  Welcome  assistance in labeling parts and checking circuit
Bom added and refined board more enjoy
« Reply #13, on June 4th, 2020, 09:10 AM »Last edited on June 4th, 2020, 11:06 AM
Working on the Multi Coil
Circuit version 3  EPG
Daniel
« Reply #14, on June 5th, 2020, 04:53 AM »Last edited on June 6th, 2020, 11:07 AM
getting there
« Reply #15, on June 5th, 2020, 05:22 AM »Last edited on June 10th, 2020, 07:25 AM
GERBER
HERE
RIP STANLEY MEYERS
BULD BABY BUILD
« Reply #16, on June 6th, 2020, 11:08 AM »Last edited on June 8th, 2020, 02:40 AM
Pictures of the geber above
bom coming soon
« Reply #17, on June 8th, 2020, 02:35 AM »Last edited on June 10th, 2020, 07:26 AM
Here is Bom ,
I am looking for  single Pin pcb though board connectors /single connector terminal +
 single pin eatiher screq or other  slim for the  red out to coils from diodes
need slim types I tried add dual terminal block but not fit well
I want to reduce soldering for others as much as possible
if you have any good  pin connectors part number let me know  and I add to the assemble bom and gerber,
ATTACHED
item   board ref   part  number    type   number of pcs    manufacturer    factory
1   C1   1000 UF 35V   AXIAL   3
2   U1   LM340   TO-220   1
3   C2   .33UF   AXIAL   1
4   U2   555 IC   DIP 8   1
5   U3   7940 IC   DIP 14   3
6   U4   7404 IC   DIP 14   3
7   C3   100NF   WIMA 0.1U/63V   1
8   Q1   2N3055   TO-3   10
9   R1   100R   AXIAL-0.4   1
10   R2   220R   AXIAL-0.4   7
11   R3   8.6K   AXIAL-0.4   10
12   U5   H11D1   DIP 3   10
13   R4   100K POT   POT   1
14   R5   5K   TRIMMER   2
15   S1   10 DIP SWITCH   SW-TH_DS-10RP   1
16   to-3   to-3   heat sink TO3SD - TO-3 Heatsink Small Diamond Shape   10   TO3SD   Futurlec Part Number
17   tc 1   EK500A-02P-R   2 pn connector Terminal Block Header 2 Position 45 Angle Screw 5mm Solder Thru-Hole 20A   11   Dinkle   Jameco Part no.: 161067
18   tc2   EK500A-03P-R   3 pin connectorerminal Block Header 3 Position 45 Angle Screw 5mm Solder Thru-Hole 20A   2   Dinkle   Jameco Part no.: 161059
19   ics1   112214   Socket IC 14-Pin Dual Wipe Low Profile 0.3 Inch Wide   6    Jameco Valuepro    14LPD
20   isc2   112206   8-Pin IC Socket Dual Wipe Low Profile 0.30 Inch Wide   1    Jameco Valuepro   8LPD
21   isc3   112193   Socket IC 06 Pin Dual Wipe Low Profile Soldertail 0.30 Inch Width   10    Jameco Valuepro   6LPD
added some pin out for easy connect the red line to coils
Arkiver1940
« Reply #19, on April 3rd, 2021, 12:11 PM »
miller at ionizationx may be using silicone inserts for the spiral dividers then bending the copper tube into a spiral
they are of course non magnetic. the use of a non magnetic steel M-1)? might work but harder to fabricate
« Reply #20, on April 3rd, 2021, 11:49 PM »Last edited on April 3rd, 2021, 11:53 PM
People with working EPG'S here are using the  cooper skin + charge effect of the copper  to  maintain the ionization state
and the segmented magnet rings  to keep  gas/liquid  polarized against the  tube and spinning no need for the divider,
as was shown to make resistance as higher speed or velocity = higher voltage
 the  peristaltic pump which was discovered to stop grounding of gas and liquid is a feature of these working EPG's
to get best effect for controllable speeds , sure is interesting  how much mis information is out there from Others.
Magnetic Spiral Divider
Russ RWG did show some very interesting magnetic impregnations
which helped people re discover that posted some what in this forum.
God Speed for those skilled in the Art.
Arkiver1940
« Reply #21, on April 5th, 2021, 06:15 AM »
I think there are probably a lot of configurations and methods to make working EPG devices
once the basic principles are understood. Stanley Meyer had about 3 or 4 different types
I do not know if they worked or were just demonstration models for the patent 101 applications
For the working EPG's that you are aware of, what is the ratio of input power to output power?
The  EPG documents that  were reportedly seen in the storage unit had a COP of about 3
« Reply #22, on April 5th, 2021, 08:19 PM »Last edited on April 5th, 2021, 08:55 PM
At this time  the working epgs are spreading rather fast
I am sure at some point you will see the information posted to youtube or forums
The EPGs are running on RF high voltages 10 kw to 20 kw  the amps and regulation if applying that
are set by the delivery electronics, some people are using the RF to drive various things with out amps and only
rf volt control using the well known methods shown by many now
As always only those who seek find
exciting times.
crackedit
« Reply #23,  »
you state that people have working epg.... how exactly.... if you know how to get these to work why is it not public??
« Reply #24,  »
Hi I am sure if you think long enough you will realize why it is spreading garage to garage for the people by the people.
All answers are online.
