I like your air system analogies... I get it; same with hydraulics....
re; a single wire's magnetic field, this is just the momentum of the air/liquid going through the pipe.
Re: a resonant system... a simple resonant systeem can have a lot of energy stored in it, but if you put a load that does consume it (an LED/incandescent bulb) there are loads that consume ... (maybe)... but if you pull off more power than you put into it you'll drain the reserve stored in the resonance... ... another model : a child on a swing, You push a little, and they swing a bit, each time you push a little, adding more energy to the reonsonance - and they go higher. and faster... If you have a tray /lefter on a ladder connected to some other load so at a certain height each time they kick the lever, they will lose some of their stored energy, and owon't go higher... each push you add into the system, they go back up and kick the lever, but only that much energy is available. If the leverl consumes more than you put in, then you will have to push a couple times to get them back to the same height/speed... If the lever is at the very bottom, is a treadmill belt instead maybe, right at the bottom, then each time you push, the energy is immediately transferred and they don't get any height/speed....
This is not to be discouraging; I've seen what seem like OU Effects in the toroidal coils(rodin/abha). To such a point I was working to try and loop it. I ended up with an output that was ungrounded (floating) with at least as much potential difference stored in it as was the input; but it was -100V from ground and -112V from ground, and when I grounded it to the same side, it arced and the connecting wire disintegrated immediately. and it was only a few microfarads cap that I was trying to attach, I'm not really sure where so much current came from....
I do have a question though; if you carry your videos forward, how do you represent induction in an air system? A couple air tanks, with motor and flywheel (each 1V, and 1H inductance and 1A current) they should transfer all potential from one side to the other in some amount of time (takes time to spinup the flywheel, and time for it to spin down) but then with no diode/checkvalve, it will oscillate forever emptying from the other side, spinning up the field, and getting pumped to completion in the other side... (default circuit on
http://www.falstad.com/circuit/ )
I also have a theory that the electrons that induce a magnetic field that in turn induces a magnetic field in another coil are the same electrons coming out as went in, and that they hop wires. But I've seen no other study that can confirm it; other than that you can get a great deal of power output on an open circuit side of an induction based coupling, so really the electrons must jump from one wire to the other to be re-emitted as photons? I dunno maybe that's not quite right... maybe it's just that wire itself is also a capacitance and the pico-farads in the wire itself is enough to supply the resonanting current
Anyway as always, look forward to more; I saw your live stream start a few days ago, but didn't get to watch it to the end, and was unable to find it on your live stremas list which the first is 2mo ago for us on the outside...
https://www.youtube.com/user/rwg42985/videos?view=2&flow=grid
