We all know about Thane Heins' bi-toroid transformer, it consumes reactive power in the primary, and outputs real power on the two secondary windings. It has no magnetic coupling from the secondary flux path back to the primary flux path at magnetic flux saturation of the primary flux path, so the primary coil sees no bEMF.
What if, rather than a primary winding inputting the magnetic flux to the bi-toroid core, there was a rotor with magnets?
And what if, rather than two secondary magnetic flux paths of equal length (and thus equal travel time for the magnetic flux within each side of the secondary flux paths), one of the secondary flux paths was sufficiently long such that the bEMF from that secondary coil was reflected into the secondary flux path such that it arrived at the other secondary coil at the same exact time as the magnetic flux from the primary flux path?
You'd have a generator which would consume the same amount of input power regardless of output power (you'd have no bEMF on the rotor's motive driver)... the rotor would merely be there to set the magnetic flux in motion.
You'd also have a generator which constructively reinforced the secondary flux with the primary flux... and given the powerful nature of today's magnets, one can set up quite a powerful magnetic flux.
We're essentially creating a magnetic relay, using a small input energy to trigger a much larger cascade of energy in the system.
