Finally figured out why no one can get voltage on their cell in the 5 coil vic. It's very simple and you can check it out yourself. It's because the negative choke is not isolated from system ground and neither is the negative half of the water fuel cell. On every cycle the system builds voltage on the positive plate and the negative plate also builds a negative charge but during pulse on, the entire voltage is dumped back into the source impedance via system ground.
The VIC has to be isolated from the source impedance completely so that each step charge stays on the WFC. Stan has created a system on his 5 coil vic where the secondary and two chokes are isolated from the source impedance, not sure how he's done it but he definately has.
There is another way to overcome it though and that is by creating your own isolation transformer.
You will never build voltage onto the fuel cell unless you create an isolated circuit where the negative voltage cannot escape to system ground. Please read up about isolation transformers.
Stan creates a system where he chokes out an high impedance signal from a lower impedance signal but he totally isolates the circuit in which he captures the high impedance so that the voltage cannot escape to system ground.
R1 places a small load on the secondary of T1, enough load so that it is not open circuit and so that T2 can choke out the higher impedance signal. T2 chokes out the high impedance signal to the capacitor but the capacitor is isolated from system ground via the 1:1 isolation transformer T2.
Stan has created an isolation transformer within the vic so its actually two transformers in one but we can do it this way:
