I'll drink to that! :-D
Just stick with it Nav, you are making great progress and what you are showing is really starting to match up with our understanding of how this gizmo works. Piece by piece the mystery is dissolving...
Got lots to do before I can think about the cell but basically we are now at this point:
1. The secondary is reactive at the gate frequency but passive of another frequency. This works best when you match a resistor to the secondary gate impedance so that the high impedance signal passes through the resistor with ease.
2. The choke is reactive at its own self resonant frequency but passive of the gate frequency. This slightly increases the load on the resistor circuit because of the magnetising force of the chokes.
3. You can find the self resonant frequency of the chokes by placing a small pickup coil on the chokes core then frequency sweep block by block. Where the chokes are the most reactive and the voltage is highest on the pickup is the frequency you need. You can set the secondary to become passive at that same frequency but this passive frequency through the secondary is doubled by the diode so if the chokes are reactive at 9khz then you set the secondary passive frequency to 4.5khz.
4. You can change the reactive and passive parameters in both the secondary transformer and the chokes with cardboard, paper, thin plastic sheet etc as gaps in the core.
I'm going to need a bigger probe, my probe is 10x and 30v max into the scope. Going to order 100x and 1000x so I can continue to show the forum this reactive and passive effect.
