Fine structure constant and pair production from Quantum Vacuum
Cycle
« on April 30th, 2017, 07:23 PM »Last edited on April 30th, 2017, 08:25 PM by Cycle
https://en.wikipedia.org/wiki/Virtual_particle
Quote from wikipedia.org
Another example is pair production in very strong electric fields, sometimes called vacuum decay. If, for example, a pair of atomic nuclei are merged to very briefly form a nucleus with a charge greater than about 140, (that is, larger than about the inverse of the fine structure constant, which is a dimensionless quantity), the strength of the electric field will be such that it will be energetically favorable to create positron-electron pairs out of the vacuum or Dirac sea, with the electron attracted to the nucleus to annihilate the positive charge.
Now, what if we were to generate a sufficiently high positive charge, and interpose plates between the central positive electrode and the incoming pair-produced electrons, such that we capture those electrons and put them to use, then route them from the circuit we're using them in to a second plate spaced closer to the central positive electrode.
We'd be pulling electrons from the quantum vacuum at a high energy, using them for our purposes, then annihilating them on the central electrode. Would there be any net gain from doing so?
The fifth postulate of QM states:
The pair production of particles and antiparticles becomes certain when energy E≫mE≫m is available or when fields are squeezed at distances ℓ≪1/mℓ≪1/m (much) shorter than the Compton wavelength.
This means that, rather than a plate to capture those electrons, we used sharp spikes tapering to an exceedingly fine point (the point would have to be only a single atom in width), we'd have a greater probability of pair production and thus electron capture... we'd have to magnetize the spikes such that the positron of the electron-positron pair was diverted away from the spike and the electron attracted toward it.
