Greetings all! This will be my last attemp at Meyer circuitry and an HHO system and everything i've learned thus far has gone into it. The drive circuit which is based on two NEC 555's architecture, two optocouplers and a TIP 3055 is the most accurate i've built so far and works great.
I've decided to use two transformers in this design, T1 is producing 200v output with 5 amps available from the 3055, which will input into T2 and you'll notice i've half rectified the signal between T1 and T2 with a diode (D2). This is because I've decided to bias the voltage into T2 then bias it again with D3 before it goes into the chokes which are Tesla coils.
During pulse on time the secondary and the chokes of T2 are additive and inductive corresponding with the flux path of the core and the bias diode D3. During pulse off time, the secondary and both chokes's induction field tries to reverse direction but connot because of the blocking diode D3. So D3 is a forward bias during pulse on and blocking diode during pulse off.
The Tesla chokes: Having read Tesla's 1894 patent on his bifilar pancake coil, where the induction field is cancelling the voltage calculation is staggering and if this array doesn't produce the voltage we need then nothing will I guess.
Wish me luck guys because this is last chance saloon for me, having had a three months break from five years of tinkering and time to think about it this is it for me. Thanks to all who helped me work on the HHO system.
