Dear members, this is my first post here on Open-Source-Energy.
My question is: Can the linear electric field inside a parallel-plate capacitor be used to continuously push electrons around a circuit?
Basically, a wire runs down through the middle of the plates, parallel to the field lines. (Fig 1)
Now the plates themselves are not connected to the circuit; they should not discharge. Only the field lines interacts with the wire segment between the plates.
Now in my simplistic view, the electric field should push electrons along the wire segment towards the + plate.
Once the electrons bunch up near the + plate, what happens then? All these electrons are trying to repel each other, but are still attracted to the + plate. (Fig 2 & 3)
Now if the wire segment were opened between the plates, the situation should be as in Fig 4: two reversely charged capacitors (each capacitor is formed by one of the charged plates and the charges bunching up on the wire nearest the plate). If the switch in Fig 4 were closed (representing the light bulb load), would the connected plates discharge themselves through the load?
If so, you would be right back to the original situation, and the process could repeat. (once you reestablish the wire between the plates.
