ill have more to add but for now:
https://youtu.be/899R0ARdpfU?t=4241
a better cutter, more speed on the cutter, and slower feed rate, should provide some good results...
i made the cutter so its not that sharp...
more to do, next we will do the Etching way. with a marker. that will be better and faster, less noisy and better to set up lol lots to do ! setting the height is critical, but for a first rush though test it is doable.
PS i will have a formal video on this later, once is all said and done...
