Hello fellow researchers.
It’s been several years since I posted here. The last was when I got scammed by the Papp engine group.
I am a retired Nuclear and Coal fired Power Plant, Control Room Operator. I have been involved with alternative energy research for over 40 years.
I have 46 solar panels, 12kw, that I use to offset 95% of my home’s electric usage, using net metering. I Have been trying to figure a way to use the energy as a catalyst to produce even more energy from the ether.
.Last year, I stumbled on a device, used in auto body shops to heat up metal and bolts to extremely high temps, in a short time, with little energy expended. The device, Mini-ductor 2, (MD2) appears to have a COP of at least 3, maybe more. Here is a short intro video video I posted on YouTube. I bought several of the units from Amazon, for testing purposes.
At present, I am working on a boiler design with a bundle of galvanized deck screws, with 4 turns of #10 copper wire wrapped around them. The MD2 supplies the coil with around 500 amps at 40 volts. The 500 amps is a resonant standing wave circuit with a very high magnetic field strength.
The 500 amps is producing an E field, through a 1 ohm inductor coil, oscillating between 2,000 and 9,000 Hz.; At a right angle to the E field, is the B field. This B field is shaking the iron atoms in the galvanized/iron screw bundle, making them very hot. They would melt if not submerged in water. The neat thing about it is, there is no counter feed-back of the B field into the E field primary circuit. The E field is humming along, drawing 600 watts of grid power, while supplying at least 1800 watts of magnetic energy to the B field, producing lots of excess BTUs. Since 1 BTU is equal to 52 foot pounds of mechanical force, there is abundant energy to be tapped. The MD2 is rated at 1000 watts. I’m working to try to tap its full capability.
I used this configuration to heat water to supplement my home heating for over 4 months last winter.
I can furnish mass/energy calculations to show how I arrived at an estimated COP of 3, if you wish.
I am looking for collaborators to join in the effort of bringing this technology to the market place to supply HVAC and hot water to homes and industry.
On my wish list is to find more iron alloys with very high hysteresis and eddy current capabilities.
The project is open source. Please feel free to share this info with any interested parties.
More info furnished on request. I am open to any suggestions you might have on furthering this research.
Regards,
zerwell
Chuck Bagwell
Regards,
zerwell
Chuck Bagwell
