Steve Meyer, Last Seen
What a F... was that? Neally at his best...
To be Honest about Steven, I don't think Stan every told him how to make the gas. I can about bet money on it. Knowing what I know about all this mess, one slip of the tongue and everyone could do it. Stan was very careful in what he said in his patents and in his lectures. Stan made a few slip up's in a couple of his lectures but caught himself and stopped right in the middle and changed the subject. I am sure Steven is a great man and smart as a tack in electronics. I thank him for everything he helped Stan with, for I know what it means to have help on a project this size. But finding the right people to help out these days that you can trust is hard to find in the world we live in today.
gpssonar I'm not so shure about that, twin brothers are very close to each other.
I can say that by my own experience :-)
Maybe there is some key he may not know in detail, but it is possible he knows the basic principles and the key points of overall system.
He can be affraid for his life, who knows?
http://www.blogtalkradio.com/waterfuelmuseum/2007/03/25/stephen-meyer-part-1
there are Manny parts...
Re: Steve Meyer, Last Seen
« Reply #5, on August 26th, 2016, 11:10 AM »Last edited on August 26th, 2016, 11:12 AM
Cool stuff >russ<. I remember you replicating Talker Stalker Walkers work. Did you get any bubbles? You and that Alex guy. Livestreamed, I believe.
Please join the conversation. Might proof interesting.
http://open-source-energy.org/?top
SSUr~
PS. see how i handled that... yeah, no names, no BS, no clams, just real life...
But will never do anything but idle a car maybe. Time will tell once you hook it up to your VW engine. Who knows you may get a few REV's out of it.
If the gas is made "a different way", then it's likely possible to lean the mixture out much more and still do the job. Les Banki was adamant about this fact. Moray King has suggested many times that if the gas is produced in what he terms "water clusters", it is far better when used as a fuel. I highly suspect Stan's methodology fixes both ends--the gas takes very little power to produce and the gas itself is much more energetic. That's the target as it has always been.
Hello to all,
following the invitation of @reverandkilljoy,
I followed some years ago the work of Ravi, an Indian guy that 9 years ago "successfully" replicate the Meyers effects.
This is the channel,
https://www.youtube.com/channel/UCHOqjIDsdF9VPpsXgqrqF0Q
and here one of the many videos he posted:
https://www.youtube.com/watch?v=-WsKOdxLIJU
Cheers,
Denis
Cheers,
Denis
dennisforrest this was not properly Meyer replication. It was more Ravi himself approach without VIC transformer, pulsed electrolysis with "conditioning" as catalyst. It really look promising but was not exactly a Meyer replication.
But anyway, i would like to see if anyone get somehing grateful replicating that.
If I remember correctly, Ravi had several aproaches.
Anyway. Glad to see people joining in on the conversation here.
See X-Blade........people read the truth.....truth does not scare anyone. If every would help look for the truth, everyone would stand up and say what they know.
Water Monkey Russ gave you both this thread : http://open-source-energy.org/?topic=2732.new#new
Enjoy the truth.
Enjoy the truth.
@X-Blade, @Water Monkey, as I remember, ravi uses a sort of "VIC", that was also described on a panacea-bocaf report that I attach here:
Looks here:
http://www.tuks.nl/WFCProject/pdf/ravi.pdf
Here the page about the VIC:
http://screenpresso.com/=MH1dd
Looks here:
Dennis, Ravi used a bifilar coil made of 100 turns on a 3/8 or 9,5mm ferrite rod. It seems to act (in my opinion) like a buck converter.
But the most important key of the overall process was the conditioning and the type of the tubes (seamless).
Yes @X-Blade,
Ravi schematic it's not the same setup of Meyers, but 9 years ago I fully replicated the RAVI setup... with also the driver for coils etc... but without luck.
Maybe I can resume all the stuff that now is packaged and try to reassemble it..
We're unable to discover the real "key"... we conditioned the tubes, that was coated with a blank layer, but unfortunatly the amperage of the entire process was very high and we never seen any of the effects Ravi says.
Denis
Denis
Do you have some pictures of the setup?
seems i may have messed that up some how on the posting on that thread... i'm working on it...
my fault, ( see i own up to my mistakes)
just hang in there... working on it...
I passed from "Aproved Member" to Jr. Member without any reason.
I am not able to login too, Im only here until my browser cache / cookies was deleted.
Anyway...
dont worry, know one is perfect... including me. so you should be good to go.
your log in thing im still not sure about, but you did not email me yet?? when you do we can work on it and see what is going on.
also , yes, i gave the wood to throw... with the effect that it would help...
PS, i moved those posts over to a new place in that bench...
bye!
