Stephen Meyers Dual 3 Phase Production
Re: Stephen Meyers Dual 3 Phase Production
« Reply #25, on December 13th, 2020, 07:26 PM »Last edited on December 13th, 2020, 07:29 PM
Quote from warj1990 on December 10th, 2020, 08:12 PM
Been a long time since I have really studied circuit boards...
I don't think the 6 amp slow blow fuse can be surface mounted...maybe need holes in the board for external front display fuse mount.
yes can of coarse similar to 9xb box
I read bifilar coils on the board...I will have to look at the patent again, but I don't recall anything
stating that for the 1.7 mH chokes.
this ties into the 9xg and the alternator being able to have stainless chokes built in
assembly can be in alternator or external as shown by several builders.
Also, I only see the "top" of the board, so no way to confirm lower trace is correct.
the gerbers are posted just open in in gerber viewer
W.
« Reply #26, on April 17th, 2022, 10:23 AM »Last edited on April 17th, 2022, 10:36 AM
Mr  Petkov Testing Stephen Meyers
 Balun balancing circuit
on 3 tubes
 https://youtu.be/vErg4LVz_b8
DD
Note Form Petkov
Now, the three coils, placed on "common ferrite core", have equal number of turns (the "3-filar coil" is "not tuned"),
only C2, is connected on "opposite direction".  TRIFILAR " Think  Alternator . like electro also showing but here is balun load balancing circuit
The Osciloscope probe is connected between the "Test point T1" (Input) and "Test point T2" (Ground).
Very important:
To the "Impedance matching circuit" is applying "only" Sinusoidal signal,
with fixed frequency about 500 Hz.
The "ringing" Resonant signal at 13,5 kHz, is "forming" from the Resonance inductors.
Important note:
1981 schematic of phase 4 voltage intensifier circuit this tells me
it took 10 years to find the winding recipe for chokes This is very important to see
Linked
https://www.youtube.com/redirect?event=video_description&redir_token=QUFFLUhqbnExa2dEbVliYlBFZlJoRGc0cHdyUnB0cHRMZ3xBQ3Jtc0trX2RJLXJtdEg3MW5EdVkwc0E2ME5kNzhnOWVkRDlnQkFyV0lhWjY5cXJQUzl2M3QzN0hDeDY3NmFtdFNNOTVXVEEtVi1qa29aN1RTai1ZZVQ3cmR2TDB5cnhWUFNwYmNWYmNtUXhESEg2enBEdVZrTQ&q=https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F1CtMGGV7XexNaX_PwunbmJiHD7jGP1_KU%2Fview%3Fusp%3Dsharing
Stephen Meyer`s Patent US 2005/0246059 A1:
https://www.youtube.com/redirect?event=video_description&redir_token=QUFFLUhqbGc5RmQxYkpBdFJYSVFONnY2T0pZREFUcGcwZ3xBQ3Jtc0trRWVxNW5VZ0xqMmdIQ18xdmxfTHJHS3BFakxDN00xUEM3OEJSMGlvLW9TY1hwS3BlVlg4ZWVfekdMTUFMVEJkQ3BVNEpGN3UxZndHN21adWhJQWlwQ2NhOHBXUHF6cXhiY3JaUzdSUnNfU0M3WjdtWQ&q=https%3A%2F%2Fpatents.google.com%2Fpatent%2FUS20050246059
My Circuit diagram:
https://www.youtube.com/redirect?event=video_description&redir_token=QUFFLUhqa2VjaTM1MmRRaTJIcUZrWXJmM0J1bDJOZjh1Z3xBQ3Jtc0tsWWlySW5wZ1lpM0w3NnBmeE9OQl9fRGNpZHVXYzZRMzNVaEhOSmRmaU9PdjRjQjdaY2UwcUhOZGdTa1B6VjFqblZJWjJWWHFmUzZyNnBldmxzcXY1NDJfUkRVWGs0U05pZE9TOXNaMk1jYno5dmZfQQ&q=https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F1eEvpcipKHj25Pldxg9jMAdkz1FMLbRNq%2Fview%3Fusp%3Dsharing
My 3-filar coil:
https://www.youtube.com/redirect?event=video_description&redir_token=QUFFLUhqbTktbkY0S0FDNW56UkxJRmNVSjBueWZXU21fd3xBQ3Jtc0tsY2JJU29wNGRnVmVVWENwUHhsLWprT1lUWVEyMU1hTF9Hdm50UjE1Z2NyZlUyVlE0QmpIRmJpMngyZWRDZjJsa0FMSlpSVmxLNFhvZUNtOFk4ZVRuWVJqSmo3ZFNLNU1xUUI5OFBMRWtZUFNkd1VXQQ&q=https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F1zq5bhFLRtYy5l073FrQP1-_-ZISyiyc0%2Fview%3Fusp%3Dsharing
"Output signal" to the Water Fuel Cell:
https://www.youtube.com/redirect?event=video_description&redir_token=QUFFLUhqbDhSc1ZOcHlYZHUtdUpqLXhVZzdENWY1ZmdRd3xBQ3Jtc0tsUUtQbThDWXFwN29rRHdrNUdfa0VqMmk2QjdKbUkzRUVhb3UxdVlSVnBidDh5TjBEMXZGYUh3djJUMF9iWWVITjZ5c3hHS21SeFp3blJtbU5NVVVWY3k2a2JPSk90bUhlb0pXTWhpbXNrTmhXN1NnYw&q=https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F1bUl-fV61j3Snzw9-4L2Q8SUd7JAC84D_%2Fview%3Fusp%3Dsharing
The "Ringing" Resonant signal (the Inductors "not tuned"):
https://www.youtube.com/redirect?event=video_description&redir_token=QUFFLUhqbGMwbDBfRTQzd3F2Y1FveGMyV292cmYyVWY1QXxBQ3Jtc0trazRJQ1FqWHJVSG1scVI5X0xXc1huV3JuT0RpWFAwM056NjdZOUd6ZW5hZ2xrSk4wYXBxRDVFbUdJeklMcFpyWWlvb1hFck90aFl5WW5yUXhEYjRKQ1R4LV8xU1pWeTI2SmRDTVdEWERKSkwwMzN1MA&q=https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F1JpRLBaWr_1j4ndemWTssWCoWZSEbvO0r%2Fview%3Fusp%3Dsharing
"Identical" Stanley Meyer's circuit diagrams, with "third electrode" added:
https://www.youtube.com/redirect?event=video_description&redir_token=QUFFLUhqa3V4N285ZHlGeExweFJDdEtmX1JqaDBJUEdfQXxBQ3Jtc0tuR21pR0l1WEVtbjhYdk9ra0Jka0F0ZGRLUWtsVlNnR3NCQ1liV25Wb2FTQ1JrX1d0WElTRl8zckNPWHF1QXcyWHZqZEtSRGdYMXo5UUlTaVBIOHUzRHVVYUlxY2M0NjJyekw3Uld6QUJwMnRQRmEzbw&q=https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F1iZMyCg_Qnn31zuCaNnu6wSPMzMbjUZbm%2Fview%3Fusp%3Dsharing
https://www.youtube.com/redirect?event=video_description&redir_token=QUFFLUhqbFBJT1RHZGNDck5EUUlLZU5hQzJMYk5mNjRnUXxBQ3Jtc0tuUF9EWEZyYXp1UXQxUEZkOVhCdjlMdV9CODZQc2NZMmdNZG9hd1kyUW9rV1p5eWh4d250YmFvZnRnb0lnc1B1dENUb1h2Nno5MTBiaHVsNUZmSVY3X1dnR2FMNmd0azh4dEdYYVRENWNlWmhSVXI3SQ&q=https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F1EanMkGt1ewKJSKfkeILVUlV2tP94QqrE%2Fview%3Fusp%3Dsharing
The "oldest" Stanley Meyer`s invention, use Car Alternator as AC Sinusoidal power source:
https://www.youtube.com/redirect?event=video_description&redir_token=QUFFLUhqbHZ6N0kxREc4bjVVUnVfNkd6RWhQSWtzVzlpZ3xBQ3Jtc0trSWszU1NHQUoxU0Zqbi1FMU5BVk1uZVc3OF9fVUxrU1B0N1J5dElYV3BsQmhyX0k4QWxoVHJCS3hQTk9YOGdkU3M4Mnk3OGtuOFlKSWZPeFExYVl5bThpaDZkVlB2UDcwN2VUV2xjUkJOdnNvaktsVQ&q=https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F19sghzMLW2fZtMHKXX0puvA40dlCuGxzc%2Fview%3Fusp%3Dsharing
https://www.youtube.com/redirect?event=video_description&redir_token=QUFFLUhqbHIyM1VWWTMybG5MTVVsdkZ1NUJxdmpMdVdKZ3xBQ3Jtc0tsemVFTjdfQnp4dmhLczAtdTByVmYyZlNoZUdFMmxEZU9IOEFWN1BxamJOQWFTNTRTNWR6NVJJSnRHNmJOVXNPZERfaDdmVnhuamRmbnZncFVTZ1VJUGJ2UkRLRkFEUFo1SURxSGlHUVlrb0k3SWVhZw&q=https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F15ObvfJdWTXg4TkbW2UEGSkSoRUe5cHh5%2Fview%3Fusp%3Dsharing
https://www.youtube.com/redirect?event=video_description&redir_token=QUFFLUhqbkRzZXQwTUp2LTFTWnhJUWl1RUNtYlFGUjhLZ3xBQ3Jtc0treVZjMXlhRVNzaC1LUkJLRVM5aFpFa3VJSFdWX211SEZkcUN5cUE4WE40NzhWOUVZWTAwUnVmX1A1bEdLVzlYeUhpTUdGT09NT2tIZHQ5VVhVLVcxemNlSGlaa1FoY3dVZzJGY1hIR2V4YUtsVTFjOA&q=https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F1tkju3dpe4C4dyfBnPOiU4uumE8-eEfI2%2Fview%3Fusp%3Dsharing
https://www.youtube.com/redirect?event=video_description&redir_token=QUFFLUhqbnJlcFpJR053RDFkaTlBNC1qQkpJWnFJcHJHQXxBQ3Jtc0ttX2luT3M0LXR2Qk1naGNEa1BmVGQ5ZTJWVVlza19aRnhGTlFiSEJTYjdROWNBcHVqVmx0ZTBiQmlZUEpKLVlJc1NibC0zamtIVVVXRUZBSk9pcWZOcnVpYWxWX1VjVDBVaTZrT2ZPVTJXbjB5QzZqVQ&q=https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F1fdr-MiBEwz2iwjTRrSbL_mAvFSow3iIS%2Fview%3Fusp%3Dsharing
« Reply #28, on September 20th, 2023, 06:40 PM »
it is very important to secure a copy of the boards .
  stan designed the systems to be in cars so the reason is there is a high impedance which is tunable, mains power is 0 imprudence not  tuneable.  so he has alternator and systems to  allow for that
you can not make ac circuit resonate due to 0
you need to have  stator from a genset or water wheel wind turbine to get a   4 to 6 to resonate to and or tune to
than his system makes nano bubble water fuel. This is what Stephen did which  is rumored to
 have upset Stan
Some smart people have put it to work on gensets and use it today it is likely to continue spreading
DD
