9 tube WFC Stan Meyers Plans Size Dimensions Water Fuel Cell
« on July 13th, 2016, 04:13 AM »
Home Builder Replications
9 Cell
The Critical InFo you Want
Outer tubes 1 inch diameter,
inner tubes 3/4 inch diameter
Thickness 1/16 inch
316 L Stainless Steel. or higher.
16 to 18  inches long 418 mm to 458 mm
Gap 1mm to 2mm
9 Tube sets ( 18 Tubes inner and outer)
Clear tube acrylic 600/610 mm Aprox or 24 inches
end caps
can 3d print end caps for spacing see thingiverse .com
allo lift base of tube from base of cell 2-3 inches
can reson set end caps or mill from acrylic
Note make a acrylic flange don't tap into the cylinder not strong enough.
when bolt end caps. use this 3d end cap to get spacing right. can adjust in www.blender.com
http://www.thingiverse.com/thing:84135
Never forget the basics
Re: 9 tube WFC Stan Meyers Plans Size Dimensions Water Fuel Cell
« Reply #1, on June 23rd, 2018, 02:32 AM »
Just Some Mirrors from Ionization x for people to look close
at
sizing
Picture from VSUTEC004
Caliper readings left to right
 262 Cap screw length
 423 Thickness of TEC
 242 Length of Gas Escape Hole
 409 Thickness of TEC viewed from greater distance
 159 Thickness of  TEC flange
Picture VSUTEC005
Caliper Readings Left to Right
258 Cap Screw Length
243 Length of Gas Escape Hole
175 Distance from Bottom of Gas Escape Hole to Bottom of  TEC
Caliper Readings Top to Bottom
881 Diameter of TEC Flange
812 Diameter of CH Cell Housing
21.89 Angle of Beveled Gas Collector
(True angle may be greater due to angle of view)
Note space at bottom of left and right cap screw holes  0.25?
« Reply #3, on June 25th, 2018, 01:52 AM »Last edited on June 25th, 2018, 02:09 AM
Posting Work that is now off in the deep web  some was found online some found ion x and others save from sources on old drive 10 years ago
reposing as more people need to see not only the progression but the data,
« Reply #4, on June 25th, 2018, 02:09 AM »Last edited on June 25th, 2018, 02:13 AM
continued
Hopes this helps people build more 9 tube cells the longer the tube the more gas you get the putter + cathod electrode is bigger surface area than the inner negative anode makes alot more gas than plate cells
« Reply #5, on August 1st, 2019, 12:43 PM »Last edited on August 1st, 2019, 12:47 PM
OK What size nuts and bolt shown here   ?
base
Bolts 9 pc   size    length   ?  thread size ?
Nuts 9 pc    size   thread size ?
to inner tube
HammerWolf
« Reply #10, on June 9th, 2020, 11:38 PM »
Nice!
I think it's kinda funny how Stan said that he built this thing just as a show piece for the patent guys to make a bunch of gas in a dramatic way! haha But it IS the most basic and simple application of the "voltage pulling apart the water molecule" and therefore a great thing to get down. Also, if you wanted to be crude, you could just run a hose off the top of this thing right to the intake manifold of an old engine and simply adjust the timing to just after top-dead-center. Good stuff!
« Reply #16, on March 11th, 2021, 10:23 AM »Last edited on March 11th, 2021, 10:25 AM
Missing and now found
OPtimus I was reviewing the Files and noticed this was no in the Stp or 3 d object etc IGES
I put this together with some   notes which are closer to stand original
1 Vents in side for gas  rising
2 mounts small holes it appears stand made some little bracket to hold the spacer securely
DD
« Reply #17, on September 16th, 2021, 09:01 AM »Last edited on September 16th, 2021, 09:05 AM
Sound these Cool Switch panels to speed up people
you can see in these pictures the basic wire layout, you can get 4 and 8 point bus bars also if you want to
  improve on the ring connect hub / jumper.
https://mgispeedware.com/
The Guys at USA Made MGI speedware can build all adjustments to order.
They are great examples and can be custom made from  to 0
allows  fast connection to tubes,
DD
« Reply #20, on February 14th, 2022, 07:18 AM »
worth note-ing  stan used 9 tube to learn I believe he learnt cells to be in series pairs and the 9th tube is heater.
here is a pic using by pass diode so series cells do not collapse others and pairs balance inner outer resistance
relevant to 5 , 9, 11 & 7 tube wfc units all have heater tubes
« Reply #21, on December 12th, 2022, 12:33 AM »Last edited on December 12th, 2022, 07:19 PM
To assist with things people have left out or forgotten
here is top divider as drawn  in 3d files readt print close as possible to original size
Stanley A Meyer 9 Cell WFC Tube Holder PLate Top
I am working on one with vents
all takes stime
Ohhh  YeaaH God Speed
DD
« Reply #22, on December 12th, 2022, 12:37 AM »Last edited on December 12th, 2022, 07:12 PM
here is base anode should be ss steel
 base joiner as drawn  in 3d files readyprint close as possible to original size so to cut steel ones
Stanley A Meyer 9 Cell WFC Tube Holder PLate botom
DD
