007 Rodin coil ideas
PJ
« on June 14th, 2016, 12:28 AM »Last edited on June 14th, 2016, 01:45 AM
This is my first post ever on a forum like this so please forgive if I'm  not following correct protocols.
I have an interest in free energy work - particularly using coils as well as interests in Ed Leedskalnins theory on magnetic current
I just wanted to share a couple of ideas about the 007 Rodin coil and general possible ideal coil proportions. These ideas may have already heen discussed so appologies in advance if so.
007  Rodin coil design ideas
1/
One thing that caught my attention with this coil design was that it looks like the gap space is equal between all wires over the entire outside and possibly centre of the coil!
I like this idea as in my mind what may happen is the magnetic field builds up evenly around each wire until the fields join with neighbouring wires at the same time across the whole coil at which time the inside space of the coil becomes fully sealed from releasing energy which then becomes trapped / stored within the torus.
This then leads to idea 2
2/
If the spacing between wires is equal over the entire entire torus it may be necessary to encourage the fields to join first at the most important point - centre of torus - and this may have been why 007 'shorted' several wires as he wanted to maintain initial field joining in the centre.
Possiple best torus proportions - PHI
I came across a great youtube clip which you csn find if you search for "PHI torus". I will try attach a link.  This clip comes across the same number patterns as Marko Rodin found but starts with the Fibonacci sequence!
It suggests that best torus proportions may relate to phi.
First torus - outer diameter = phi, inner diam = 1 ( proportion)
Next torus - outer diameter = phi cubed, inner diam = 1 (proportion)
The clip also suggests best winding paths / numbers based on the area of each 'diamond' on the torus surface being the same.
Worth a look
https://youtu.be/1KS5XvP_rGI
Anyway thats my first post on some ideas i wanted to share.
I hope someone finds this interesting
