My thoughts on a unified field theory.
chuff1
« on September 28th, 2015, 10:07 PM »Last edited on February 14th, 2016, 05:38 PM
Hello again,
     I have an unrelenting quest to find out what everything actually is.  I would like for the first time
to get it out there for people to contemplate and critique.  This might be a little long winded
but to really grasp what I am saying, I am going to go through my thought processes and
where the ideas originated.
Gravity:
      I originally thought that gravity was unchangeable and that someone way smarter than me
has worked on it and we still do not have the rewards, but I believe it is the duty of all above
average intelligent people to strive and answer the unknowns for the benefit of Mankind.
After as much research as I could find, I realized that gravity was not as complicated as
was assumed.  If we used the knowledge we have now it might just be possible.
Gravity is one that is not understood very well at all because we try and complicate it with
mathematical equations and abstract ideas instead of practical application of the Laws of physics.
     As such, I would like to inform you of some of the Laws that i believe are involved with
the creation of the force of gravity.   First off you need to know the term "MagnetoHydro-
Dynamics".  Second is to understand the concept of The Lorentz force that if you have a current flow
and a magnetic field perpendicular to  each other you create the other vector which is force.
Now imagine the earth with its large magnetic  field (B) the lines of force being parallel with
the ground, and electrostatic lines are coming in from the ionosphere to ground creating a
current flow (I) through the air and a force (F) that is gravity.
     To prove there are electrostatic lines of force just look at all plants they grow out of the ground
like a lightning path. Another way to see the motion of the ether due to these forces is to flush
the toilet.  When the molecules of water go down the drain they spin according to the Lorentz
force like an electron in a magnetic field.
    Imagine the Sun being a giant heated cathode,  The Earth being negatively grounded, a
a current flow exists between the earth and the Sun. Now we can start to imagine what happens
to the earth when this happens.  I firmly believe in Tesla's view of very highly charged particles
with a minute mass but high velocity which gives it a large amount of energy.  These particles
are what creates light, heat, and rotation of the Earth.
     Adding to this train of thought it occurred to me to that this force (F) is actually highly
charged particles flowing in from all sides sent by the many stars around the earth, remember
in a perfect vacuum a lot of the hot cathodes (stars) are creating these particles that are
accelerated downward by our Earths conditions.  As the particles enter our atmosphere
they pass through all matter based on their velocity (charge) and low mass, but these
particles create a drag on whatever they pass through.  My theory deduces that the more
dense the material the heavier it will be solely because of how much drag the particles induce in
the material forcing it toward the center of the earth and upon meeting they collide creating a heating
condition of our core.
Radiation:
     Radiation could not be any more simpler to explain based on the aforementioned theory.  If you have
these highly charged particles penetrating all matter then you can deduce that the more dense the
matter, the more drag it has till you get so dense a material that the particles start colliding with it
causing radiation.  The particles shatter the dense materials atomic structure throwing off protons,
electrons, neutrons like a bullet splashing against a metal sheet.  Eventually perforating the
material to a point when it no longer stops the particles and that in my opinion is called its half life.
Light and Heat:
     Light and heats are nothing more than a highly energized particle that is thrown through a
compressible medium such as our atmosphere creating a torroidial wave perpendicular to the direction
of the particle, like dropping a pebble in a calm lake and the ripples formed are what is considered light
and heat is from the friction of the mass bumping into all the air and water molecules of the
atmosphere and the more dense the atmosphere is, is where we get our different colors of light
because the particle has slowed down creating a slower vibration of the air molecules making the
light appear darker colors like red. Solving the mystery of "is Light a wave or a particle", its both.
     Rotation of the Earth can easily be explained by Crookes invention of the Radiometer.
Light from the Sun on one side, Dark on the other side causing us to rotate like the vanes.
Magnetism:
     This one is tricky, the idea is that a magnet does not inherently have a magnetic field but
is in fact a Channel for the ether to flow through like a water pipe.  As for what creates it that
part is well known but the force it creates is the tough one to contemplate without using the
"Ether" concept.
That is it for now.  Tell me what you think.
massive
Re: My thoughts on a unified field theory.
« Reply #1, on September 30th, 2015, 01:55 PM »
Einstein is a long time dead , < whoever or whatever came up with that formula got it right first time , we all have to face that one.
as for science , theres a minority who have foisted theories/beliefs upon the majority and made it stick. doesnt matter if its science , religion or finance
the individual has the right to think the way they want to so its interesting your going for unified field theory .
Im reading at the moment about Robert Adams and his motor .
pulsing coils and permanent magnets
he claims to tap into or allow/channel aether through using magnets . he was up against the status quo or vice versa but soldiered on for 30 years .
he certainly was not alone , so the combined theories of these individuals can only add up to something
« Reply #2, on September 30th, 2015, 03:51 PM »Last edited on September 30th, 2015, 04:38 PM
be careful you cant ignore every idea out there.
gravity and earth magnetic field.. well i looked it up.
.03 guess , or 31 micro tesla.
when taking about magnetic field remember the lack of information on the net. very simply put magnetic field are traditionally describe a cut out or cross section of a hollow coil.
so i say gravity is a joke. i think its a magnetic lock instead on all matter that has a positive or negative charge..
https://www.youtube.com/watch?v=yAfg_8OLjvs
chuff1
« Reply #3, on September 30th, 2015, 07:27 PM »
I would like to share an interesting video of what a magnetic field really looks like in a 3d medium, here
is the link.  I do not rule out any theory at the moment as I
read through so much material I tend to compare each one with another till all the pieces fit. I submit
to you another experiment to try, I used every known coil configuration below a counter balanced wood
rig.
     The specifics are a wood base with to wooden dowels that were crossed at the top to create a
cradle for another dowel each one 1/4 inch diameter then I took two wooden balls about 2" diameter
and drilled a 1/4" hole into the two in which I pressed the dowel through.  Now I counter balance the
dowel with the two balls on the ends creating a see-saw thereby giving me a gravity rig without the
magnetic field interfering with it like you would have if it were made of metal.
     After pulsing every coil with every waveform I come to the conclusion that this was not the
way to proceed.  There was only two venue left to try, one that was electrostatic and the other
was a directional force.  So I took a balloon filled with atmospheric gasses and charged it using
a piece of cloth and put the balloon above one side of the balance.  Instantaneously the balance
shifted.  Showing that electrostatics had very much promise.
     An explanation of the effect is nothing more that electrostatic attraction of the surface of the
balloon pulling on the oppositely charged surface of the wooden ball by electrostatic induction,
and there are many motors based on electrostatics.
« Reply #4, on September 30th, 2015, 09:51 PM »
so then with electrostatics what do you assume is true?
static are domains that travel in streams.
static is a interference that  can be seen on the uhf band
therefore there is a wave . and yet inertia is telling you it must be a stream of particles, or domains.
