Hello everyone I have been doing some digging and am starting to find some issues. I am new here so please bear with me if I am not posting correctly but I feel this information needs to be shared. I am finding some issues with alot of our theories here. I put this here hopefully it turns out.
" In the atomic hydrogen process, hydrogen is not really a “fuel”, but rather a “medium” used in the extraction of and conversion of energy from the ether, by transforming invisible radiation and electrical energy into infrared (heat) radiation. The energy required to pump the recombined hydrogen to a holding tank, before being recycled and shot back across the arc and into the reaction chamber once again, is not considered in this computation. This energy should be negligible, since the dissociation energy is barely more than a thousandth of the gross output, and there is probably a way to make the process work without a pump anyway."
The manipulators of information have both lied and made the direct comparison between atomic hydrogen and gasoline as difficult as possible, but I have waded through a multi-step mathematical, physical, chemical and unitary process to get to the truth.
Atomic hydrogen produces over 109 k.cal./gram molecule, which is 109,000 k.cal./kilo. Minus the 103 cal./gram mole endothermic dissociation energy, and a net of 108,897 k.cal./kilo is left. A kilo equals 2.205 lbs., so a pound equals 453.51 grams. You must divide the net cal./kilo by lb./kilo to get cal./lb., then multiply this times °F/°C (1.8) to get °F/lb. This is then divided by grams/lb. to get 196,015 BTU/lb. The gross is 196.200 btu/lb. In comparison to 19,314 BTU/lb for n-Heptane, atomic hydrogen has 10.5 times the energy per pound (of H1 per gal. of H2O).
There is an easier mathematical process, but this shows more clearly what I did. No wonder the process “went out of use”. With this process, a home consumer would pay nothing for fuel, because he could produce a small amount of hydrogen in his basement, any time he needed it, and could use it over and over, ad infinitum.
He could heat his house, drive his car, and use it for “home-industrial”, uses. In a motor cruiser on the ocean, one would never have to worry about where the “next gallon” of fuel was coming from, or what it would “cost”, because like sunshine, the heat from atomic hydrogen is “free”, except, unlike sunshine, you could produce as much as you want, any time, day or night, summer or winter, rain or shine; the farmer would no longer be dependent upon the oil cartels for his energy, and could run his machinery and heat his barns “free”. He could tell the fuel suppliers and the banks to screw themselves.
People in the far Alaskan north could heat large spaces without huge expense. “Northern industry” would thrive again. The population control Nazis will hate me.
It is obvious that the reason corporations like ARCO went so heavily into producing solar energy equipment in the early ‘70s, was so they could control and ultimately raise the cost of (free) solar energy, to make it “competitive” with gasoline and other fossil fuels. There are many ways used in contemporary texts to confuse facts, but the most effective way is by complete omission. Such facts could not have been concealed by “accident” or mere “oversight”, because they are too phenomenal. Only by plowing through a tortuous mathematical process and confusing units and other factors was the true motive for such concealment revealed for certain, but tell me why I’m not surprised?
Conservatively speaking, the atomic hydrogen process bears a 10.5-to-1 ratio to n-Heptane. Would you care for 315 miles per gallon? How about 550,000 miles? It all depends on how many times you recycle it. The figures for n-Heptane are grossly confusing, as one might expect, since it is shown only by comparison by weight that hydrogen combustion has a 2.7-to-l ratio to n-Heptane.
This deception was effected by playing around with differing heat and weight units, pressures, and volumes, and the difference between the centigrade and Fahrenheit scales. The “109,000 cal./gram molecule” figure for atomic hydrogen was omitted from the newer text, though one might have been able to extrapolate it from some complex data stated in other areas where the inquisitive person is not expected to look. There was a total absence in the new text or other “new” data available to me, of a direct comparison of energy outputs between combustion of petroleum and hydrogen, much less the atomic hydrogen process.
I have never seen a direct comparison by any of the thousands of Ph.D.s in chemistry or physics, who should have become aware of these facts during their cursory studies. To make these figures even more ludicrous, with BTU (“British Thermal Units”), one would expect the weight to be shown in kilos under the metric system, instead of the non-metric “pounds”. These machinations clearly appear to rely upon the well-founded assumption that all scientists who know, are controlled and don’t say, and those who aren’t controlled, will be considered “quacks” if they try. to say. Again, its the usual case of “Those who know, can’t say, and those who say, will be presumed not to know.”
Another stupid trick used is to compare “system weights”, under the false assumption that the user of hydrogen would have to use only the systems they present, raising the “comparable” weight of hydrogen to gasoline, using cumbersome cryogenic bottles or hydride storage tanks, etc., when the simple figures clearly show that one-third the amount by weight of hydrogen would be needed for a comparable combustion process.
Whenever hydride systems are mentioned, there is an obvious omission of the liquid hydride system developed by Dr. Gerald Schafflander of California, the promotion for which Schafflander and associates were abusively prosecuted by the SEC, as previously stated in Space Aliens. Yet, the atomic hydrogen process would be more than adequate—even fantastic—with only a pound of hydrogen, and one could carry an extra 25 lbs of Dr. Schafflander’s liquid hydride in the trunk. Below is a direct comparison between the BTU/lb for combustion of gasoline and molecular hydrogen, and the atomic hydrogen process, respectively:
Gasoline combustion (n-Heptane) 19,314 BTU/lb
Hydrogen combustion (H2 + O) 52,200 BTU/lb
Atomic hydrogen (H2<--->2H) 196,200 BTU/lb
Note that the atomic hydrogen process does not involve a “consumption” of the hydrogen, yet even if it did, the ratio between atomic hydrogen and gasoline is still 10.5-to-one. Take into consideration also that all the best methods for obtaining over a hundred miles per gallon (even hundreds of miles per gallon) of gasoline in automobile engines, utilize the vaporization of gasoline and mixture of it with air prior to combustion, something which is easier to do with hydrogen, because it is in a gaseous state at normal temperatures and pressures. Also consider that while n-Heptane is a ‘purer’ gasoline, it hasn’t been available for years, and most “gasoline” is a dilute mixture with water and various additives, with only about 50% n-Heptane, so I’m being as kind as I can be to “gasoline”.
If a pound of gasoline could propel a car 30 miles, the consumption would be 666.6 BTU/mile. On the same scale, a pound of atomic hydrogen would yield 315 miles. Then you could repeat it, over and over and over. A pound of hydrogen could conceivably supply all your energy needs for your whole life, and you could produce another 100 pounds of it electrolytically, right in your basement, from tap water! Is this free energy, or what?!
Though the facts of this “secret” hydrogen process are “hidden in plain sight”, one must beware of the disinformation, as well as the common mistakes created by “scientists” who have been duped by the RQMs. For example, in the 1976 Norton Encyclopedia, 5th Edition, page 1311, most of the pertinent facts about hydrogen are shown. The “109,000 cal./gram molecule” for recombined hydrogen, reported in an older text, was not shown directly, though the following facts which were shown, are of particular note:
Heat of vaporization at 20.4° K 107 cal/gram
Energy released upon combustion 29,000 cal/gram
Heat of combustion at 25°C 63,317.4 cal/gram mole - gross Heat of combustion at 25 °C 57,791.6 cal/gram mole - net
Since the heat energy is released on recombination, the molecules lack the potential energy already released. The potential energy of the separate atoms in their ground states, is greater than that of the molecules, because the heat energy is released from the entrained ether and converted ZPR—not from the hydrogen atoms—when they combine to form molecules.
This is hereby unmasked as Orwellian doublethink. Since when is the potential energy of the atom of an element measured from its molecular state? This is exactly like saying that a truck sitting at the bottom of a hill has more “potential energy” than one sitting at the top, because of the energy required to drive it up to the top of the hill!
What a strange way to define “potential energy”. It is like saying an empty gas can has the potential energy of the gas that it takes to fill it up! The unique thing about the hydrogen atom, is that it is “born” at the top of the hill! Its astounding properties lie in its ability to perform as a “doorway” between the ether and the world of more familiar atomic matter.
The relativist statements have been unwittingly accepted as correct, because there is no ether or Zero Point Radiation possible under their theories, and the molecules have to have more energy than the atoms separately, because “E = MC2”. The RQMs have misrepresented and concealed this process in which separate atoms—with lower MASS—possess more “atomic” energy than the molecules! Ha! These facts on hydrogen show that E equals MUCH MORE THAN MC2.
Under relativism and quantum mechanics, “solid” matter is thought erroneously to be the most “compact”, “stored” form of “atomic energy”, because the energy is supposed to be released by the “smashing” and destruction, or fusing together of atoms, which Tesla said was false. It is clearly shown by the atomic hydrogen reaction that Tesla was right and the relativists and Einstein were wrong, because the hydrogen atoms have more potential energy in a separate atomic state than they do in the diatomic molecular state!
This can only be either because when separate, the atoms “gather” energy from the ZPR, and eject it from the ether when recombined! In either case, the energy is not stored by the atoms, and no longer possessed by the molecules after release, unless there is an even greater lie hiding in the relativist bushes. This perverse potential energy fallacy is also a way to confuse the diatomic hydrogen molecules with the nascent atomic hydrogen atoms produced by the hydrolysis of water.
The energy of hydrolysis is equated with the energy of dissociation, and the energy of combustion with the energy of recombination, yet the information presented here shows that by combining the hydrolysis of water, in which atomic hydrogen is produced directly, with the atomic hydrogen recombination process, instead of the combustion process—and perhaps throwing the oxygen away—that at least 10.5 times as much energy as the hydrolytic input can be produced, in still a third astounding hydrogen free energy process.
This is true because the atomic hydrogen process without question releases at least 3.75 times the BTUs by weight, as ordinary hydrogen does in the combustion process. Even the relativists agree that the “energy of combustion” equals at least the “energy of hydrolysis” (even though it is well known that the industrial production of hydrogen by electrolysis is generally 120% efficient).
Production of atomic hydrogen directly by hydrolysis, which cuts out a separate dissociation operation, is yet another exciting possibility. It does not expend the electrical equivalent of 109,000 cal./gram molecule (to produce only 65 cubic centimeters of hydrogen gas).
As a “welding process”, this process was ‘obsolesced’ by MIG and TIG welding, neither of which can compare to its welding efficiency and uses. Since the welding process was its only “public” use in the years past, the “new” processes allowed industry to toss the “obsolete” process onto the junk heap (except for their own ‘secret’ use of it).
The “new” processes were promoted by U-Know-Who, motivating their welding suppliers and the electric power companies at their own levels. More archaic tanks, transformers, gauges, torches, electrodes, gases, fluxes, and electric power, etc., etc., to be sold at a hefty profit. If people generate their own hydrogen for welding at home, how much equipment, supplies and power will they buy?
How does the atomic hydrogen obtain its energy, if not from the “ether”? No wonder establishment science doesn’t want you to know there is an ether. If we are to believe the “law of conservation of energy”, as interpreted by establishment (relativistic, ether-excluding) ‘science’, this process is impossible, yet using data available from ‘standard’ texts, I have shown that the input energy of 103 cal./gram molecule is somehow either ‘magnified’ to 109,000 cal./gram molecule of hydrogen—a multiplication of over 1,058 times—or that, by use of hydrogen as a “medium”, that the 103 calories is ‘seed’ energy (called the “activation energy”), triggering the atomic hydrogen’s apprehension of a net 108,897 cal./gram molecule, from the “ether”.
An equally phenomenal “atomic helium” process (reported in Space Aliens) is 4.6 times this output. It can be conducted the same way, and produces the same kind of electrical energy and radiation-to-heat energy transformation, in which “mass” is only a “medium” used in the process. The same principles are shared by the Atomic Hydrogen Process, by Josef Papp’s Method and Means of Converting Atomic Energy into Utilizable Kinetic Energy (Patent No. 3,670,494, of June 20, 1972), and several other discoveries mentioned here.
If these processes used as much electrical energy as they produced, and electrical energy was the end product sought, what would be the use of the processes, right? At the comparable 30 mpg for n-Heptane, helium could produce 42.86 times as much, or about 1285.8 miles per pound.
According to Van Nostrand’s Scientific Encyclopedia, 5th ed., Van Nostrand Reinhold Co. (1976), simple electron bombardment of helium gas, in a special chamber, excites the helium atom to a temporarily radioactive isotope of extremely short half-life. In this state, the helium atom unpairs its electrons, promotes one electron to the 2s state (in which state it remains for only a very short time), and afterward releases 460,000 cal/gram-atom (per gram of helium), on collapse of the excited atom back to its ground state.
The heat is in the form of photons. This is similar to the process for atomic hydrogen, as illustrated by my drawing shown on page 102. It is my theory that while the electron clouds are in the excited (expanded) state, they gather and convert energy from the ZPR.
Apparently, as the hydrogen passes through the arc, the electric and magnetic fields, plus heat, provide the activation energy triggering the molecule’s ‘apprehension’ of an additional 108,897 cal./gram molecule of endothermic dissociation energy. Just exactly could this be possible?
Since each hydrogen atom is composed of a proton and an electron (each with a pair of purportedly equal and opposite charges) one would expect the binding force between the molecules to be very weak, but when the atoms are separated they purportedly expand greatly in size—because negative ions are larger than the non-metal atoms from which they are formed—encompassing a greater volume of Omni Matter (my term for the “ether”).
On recombination, the atoms shrink in volume, as the excess ‘gathered’ energy is squeezed out of the ether as free (heat) energy. The “endothermic” dissociation absorbs only 103 cal/gram molecule, yet on recombination, the atoms “exothermically” yield a net 108,897 cal/gram molecule. How exactly does this occur? As stated in Space Aliens, it is my theory that all space is packed solid with bumper-to-bumper “Omni Particles” (A.K.A., “the ether”).
This elusive yet dense and ultra fine, absolutely transparent matter, is meanwhile being omnidirectionally interpenetrated by something called Zero Point Radiation (“ZPR”), of such high frequency and voltage, that it is difficult to measure or comprehend.
This radiation is in (nonrelativistic) equilibrium, therefore referred to as “Zero Point” radiation. The facts proven by the atomic hydrogen process, explained by the involvement of the Omni Matter and the ZPR, are forbidden by relativity and quantum mechanics, in which a simple harmonic oscillator cannot have a stationary state of zero kinetic energy, because the ground state still has one half quantum of energy and the appropriate motion, yet by relativity’s ‘other’ rules, the principles of kinetic energy has no applicability to electromagnetic radiation (the ZPR).
Since relativity also rejects the existence of an ether, there is nothing in so-called “empty space” to contain such radiant energy, and the atomic hydrogen process would have to create its energy from “nothing”, therefore violating the law of conservation of energy, as misinterpreted by the relativists, who see all energy functions as part of the ‘winding down’ products of an “original” BIG BANG.
You can forget what the relativists said. The equilibrium of the ZPR can be upset by disturbances created in the Omni Matter—which I divide into Omnions (ultra-fine, positive “subprotonic” particles) and Omnitrons (“sub-electronic” charges carried by the Omnions—all of which the ZPR interpenetrates. Unidirectional vibrations (disturbances) in the Omni Matter cause it to accumulate transferred force from the ZPR, throwing Omni Matter out of equilibrium, and restoring equilibrium to the ZPR.
The Omni Matter’s excess force is then transferred through the atomic hydrogen atoms (or other temporarily excited, enlarged atoms encompassing it) into the atomic mass frequencies, during disturbance, thus restoring equilibrium to the Omni Matter. This transferred force is not “energy created from nothing”, but only represents a change in the “form” of some of the infinite energy (force overtime), already existing in ‘space’ in other forms (such as the ZPR, or as “sub-electronic” charges).
Whenever H2 is dissociated to 2H (H1), and the single electron clouds enlarge to encompass more Omni Matter (affected by a greater ZPR), there is a reaction with and transfer of force from exothermic atomic sources, through the molecules, into stripped Omnions which were entrapped to bind the atoms together.
This exothermic energy is sufficient to throw the Omnions within the electron clouds, and concentrated in the space between the atoms, beyond their electronic quantum boundaries, so that the additional energy needed to dissociate the atoms is regained from the surrounding Omni Matter and ZPR, restoring the equilibrium of the Omni Matter. With the recombination of the atomic hydrogen to form 2H, the converted ZPR radiant energy, and sub-electronic charges—which I call Omnitrons—is ejected (squeezed out) from the atoms, as heat or other interconverted radiant energy- of lower frequency, as the electron clouds shrink with the addition of positive charge carried by the Omnions.
The reason the electron cloud density of the hydrogen molecule is more concentrated in the area around the space between the atoms, is because of the entrained Omnions’ presence there. Otherwise, the two negative charges carried by the two atoms would cause mutual repulsion. Actually, since heat is infrared-spectrum radiation, the process can be conceived as a means of converting the ZPR from an ultra-penetrating positive (‘cold’) spectrum radiation, to a mass-reactive infrared (heat) spectrum radiation, and that is the proximate “source” of the so-called “free energy”, in the form of exothermic heat radiation. The ZPR is an analog to sunshine, except it penetrates all matter all the time and is not affected by day or night, so it can be converted to usable energy all the time with the appropriate technology, such as the atomic hydrogen process.
Incidentally, this same atomic hydrogen process, as first published here and now, is also the apparent source of the anomalous exothermic heat produced in aqueous cavitation, as well as in the so-called “cold fusion” process, which are two other free energy processes which are based on the atomic hydrogen process. In addition, it is the phenomenon which was apparently responsible for the cavitation-based, powerful fuelless pumping action produced by the “Hydro Vacuo Motor” of John Ernst Worrell Keely, in c. 1870..
The atomic hydrogen atoms have single, unpaired electrons in enlarged shells. These atoms are in Mendeleev’s Group I-a, and all the atoms in that group have unpaired outer electrons, and are photoreactive to and transmute when exposed to ultraviolet light, as do all the atoms of elements below atomic number 19.
Some of these elements transmute in visible and infrared light, and all of them can be used to transmute ZPR into usable free energy. This photo-reactivity creates temporary, artificial-radioactivity-producing isotopes of short half-life, with the emission of photon energy restoring equilibrium to the atoms as they return to their ground states. The energy for these radioactive emissions comes from the ether, not from the atoms themselves.
The atoms can be analogized by certain crystals, described by the Raman Effect, in which light passing through the crystals is “stepped down” to lower frequencies. The infrared spectrum light produced by the atomic hydrogen process is thermically reactive with normal atomic and molecular matter, because of its longer wavelengths.
The transfer of force from the ZPR, via the Omni Matter, through the dissociated H, atoms, is apparently the kind of thing somewhat cryptically spoken of by Tesla, when he stated: “There is no energy in matter other than that received from the environment.”4 In so-called “cold fusion”, the electrolytic cell produces “nascent hydrogen”, just like in the atomic hydrogen process, and the recombination of the monoatomic hydrogen to 2H releases heat, the product claimed.
This atomic hydrogen process also proves Tesla’s theory that “atomic energy” comes from the environment, not from ‘smashing’ atoms. It proves that “mass” does not even enter into the equation, and that Einstein’s “E = MC2” is wrong. Einstein’s theory says this process as I describe it could only be possible if the hydrogen were ‘annihilated’, converting its “mass” into heat, and otherwise, is impossible. But the hydrogen is still hydrogen, before, during, and after the process, and Einstein was wrong, wrong, wrong! It defies relativism, Heisenberg’s “uncertainty” principle, misinterpreted quantum mechanics, and the BIG BANG!
Perhaps this or a similar process was also what Leland Anderson referred to in his eulogy of Tesla, when he mentioned his “plucking” thermal units “...right out of the thin air”. After all, the hydrogen atoms when in the 2H molecular form are smaller, therefore “compressed”. Compression of a gas releases heat radiation, usually thought to originate with the energy endothermically absorbed during decompression, but in the case of hydrogen, the change is effected by the natural, physical process of recombination to 2H.
The molecular atoms can be ‘decompressed’ by a slight application of heat of dissociation, because the strong binding force between the atoms created by the Omnions, is more easily weakened by a small amount of exothermic energy sufficient to separate the atoms, so that the Omnions regain their Omnitronic charges from the surrounding ether and ZPR. Hydrogen atoms have the highest charge-to-mass ratio known, a ratio which almost completely neutralizes the protons.
‘Decompression’ of the electron clouds occur during dissociation, because there is less positive mass within the clouds to pull the clouds down toward the protons. As the protons dissociate with application of the 103 cal/gram molecule, this allows the greatly expanded electron clouds of the atoms to encompass a larger volume or Omnions, carrying sub-electronic Omnitronic charges equal to 108,897 cal/gram molecule, from the only source available, the ZPR and Omni Matter (A.K.A., “ether”). Since there is no great cooling activity in the proximate area of dissociation, the ‘heat’ can only come from the Omni Matter and ZPR, and is ultimately a conversion of energy in the form of random, ‘cold’ ZPR, and Omnitronic charges, into a coherent, utilizable form of heat radiation.
This process, though it can be thermally triggered, is not merely a thermal process, because the net energy released is not converted originally from thermal energy, but from ZPR and Omnitrons, into infrared (thermal) radiation. Amazingly, the raw data for this process came from ordinary science books, though the oldest text was produced in England, and would be practically unavailable to the average American experimenter. The full magnitude and output comparable to petroleum was only obviated by conversion of weights, measures, units and temperature scales, into a consistent picture, to obtain the total net outputs.
Most physicist or chemists would refuse to believe the results, even if they had calculated them themselves, and would insist that they had erred. This is indeed an inverted BIG LIE, which is told very small, and often. The BIG LIE consists of a denial that there is an ether, the distortion of quantum mechanics, and the exaggeration and minimalization of other incompatible measurements, to create a false overall picture. This is then backed up by a vacuum of information, in publicly available texts and other sources, created via the National Security Act, by the Fuel/Power Cartels.
Most physicist or chemists would refuse to believe the results, even if they had calculated them themselves, and would insist that they had erred. This is indeed an inverted BIG LIE, which is told very small, and often. The BIG LIE consists of a denial that there is an ether, the distortion of quantum mechanics, and the exaggeration and minimalization of other incompatible measurements, to create a false overall picture. This is then backed up by a vacuum of information, in publicly available texts and other sources, created via the National Security Act, by the Fuel/Power Cartels."
Ok I know this ALOT to take in but please think about this. Tesla was all over this but he was quiet because of his own reasons which if I am figuring this correctly goes way deeper then any of us could ever imagine. I apologize if I broke any protocols or rules for this forum/ site I just felt this was way to important to share with all of you. I have a few other goodies I have been working on also but will monitor this post to feel out your feelings and responses. I do believe we all have been hoodwinked worse then we realize. This is not Conspiracy this is FACT based on open sourced and privately purchased materials. I would also like to point out this is why I believe Stan was silenced as well as many others. Here is another one to ponder? If we start playing with this stuff we start entering the realm of the Atomic Commission and bigger Energy Cartels then just Electric and Oil. Here is some more food for thought. We are entering into National Defense realms also and this is the BIG ONE. I am sure I am not the only one who is putting this all together but for those of you who have not, I suggest you evaluate your place in life. I personally am pushing forward for the betterment of humanity not profits. I know it takes money but I see a better future for all of us. As being a part of this system for so many years not comprehending the real things that matter, it is much to my regret that I did not awake sooner to this. But their is a glimmer of hope I see in our future, it is You and I, by collaborating like I have seen in this and other forums we can reach the tipping point I believe.
Ok People its all in your hands now. Tell me what you think as I will be in and out of this awesome forum. Best Wishes to All.
Peace N Light to all,
Eyeindanorth
Eyeindanorth
