Nelson Rocha
Nelson Rocha
« on August 7th, 2015, 11:32 PM »
Summary (I think originally from Tom Bearden)
A method and apparatus for extracting bidirectional EM wave energy from the vacuum through the scalar potential gradient across the terminals of an electrical source, collecting the excess energy in a collector without entropy, then separately discharging the collected energy through a load to perform work, without sending the load current back through the primary source against its potential gradient; i.e., against its back emf.
Removing the load current from the source thereby substantially reduces the production of work inside the source to dissipate its bipolarity; said internal dissipative work being well-known to be the cause of exhaustion of the source's ability to continue to furnish emf to the external circuit.  By reduction of its internal dissipation, the source is enabled to furnish more energy for dissipation in the external load than is utilized to dissipate the source internally. Hence the source is enabled to operate with an overunity operational efficiency. The system permissibly operates as an "open" system, and extracts and utilizes excess EM energy from a free-flowing external source (the flux exchange between the surrounding vacuum and the bipolarity of the source), hence it can operate at an efficiency greater than unity without violation of the laws of physics, in a manner analogous to but entirely different from a heat pump.
In this invention, it is not the purpose of the primary source to furnish current and dissipative power to the external circuit. The bipolarity of the source is utilized primarily as a dipole antenna to receive the bidirectional EM wave energy flow from the vacuum, and direct it without entropy through a switching unit to the collector. Conduction electrons in the collector are temporarily restrained while being overpotentialized by the excess energy being collected upon them. The collector and its overpotentialized electrons are then switched away from the primary source, and connected across the load as a separate circuit and closed current loop. The electrons in the collector and their excess energy are then automatically released to flow as current discharge through the load, releasing their excess energy to perform useful work in the load. The collector is then switched away from the load and back across the primary source, and another collection cycle is initiated. Iteration of the collection and discharge cycles provides power to the load. Additional collection and smoothing capacitances for smoothing the iterations and furnishing steady power to the load may be added as desired. The invention violates the closed circuit practice of powering loads, but does not violate the conservation of energy law, the second law of thermodynamics, or any of the other known laws of physics.
https://www.youtube.com/watch?v=bY3Mr2pAErw
If you guys understand what this device is doing and how it might be important, please comment.
Re: Nelson Rocha
« Reply #1, on August 8th, 2015, 03:16 AM »
well its my air charge accumulator of course. and the principles are not scalar, but equal potentials. and voltages.
a open surface i have a;ready shown what that is. mit lectures.  still no one here will even assume its a false claim.
i am talking about energy measured in joules per square meter. that is important. that is useful for work. its still Tom Bardens analogy ..
i only one who claimed the experiments point to ionic breeze.
Re: Nelson Rocha
« Reply #2, on March 30th, 2016, 08:05 PM »Last edited on March 30th, 2016, 08:07 PM
This looks like a self-runner to me.  Nelson claims its fundamental principal is displacement current that allows you to charge a capacitor without depleting the source.
Re: Nelson Rocha
« Reply #3, on April 29th, 2016, 10:16 PM »Last edited on April 29th, 2016, 10:19 PM
Been working on this base platform circuit Nelson Rocha published.  He indicates this is an excellent starting point for researching radiant energy transfer.  Once better understood, it should be possible to loop this circuit with minimal modifications.
Re: Nelson Rocha
« Reply #4, on April 29th, 2016, 11:18 PM »
Ok, I'm listening.
:popcorn:
Re: Nelson Rocha
« Reply #5, on April 30th, 2016, 10:04 AM »
Having built this circuit and scoped its internals, I have and idea based on "coil short at peak".  Going to build a controller based platform to test my theory out.
Don't go too far away Lynx, this could be good.   :)
Re: Nelson Rocha
« Reply #6, on April 30th, 2016, 10:38 AM »
Oh you already have my attention Matt, this one I'd be more inclined to have a go at myself.
Re: Nelson Rocha
« Reply #7, on April 30th, 2016, 11:29 AM »
Just for some background, the reason I'm fairly hot on this topic is because Nelson demonstrated at least two loopers and a couple of years ago he was picked up by Aurthur Trankle at Steho AG.  He is now under contract (NDA) and will not release any more videos.  I have communicated with him several times and he appears to be the real deal.  He worked hard to get where he is currently at and won't do anything to jeopardize feeding his family.
He told me about this circuit and suggested that I study all of his published videos as they are a time sequence of events that lead him to developing OU devices.
Ris
Re: Nelson Rocha
« Reply #9, on November 27th, 2016, 11:54 AM »
I would say that this is true a few kilowatts without problems
Re: Nelson Rocha
« Reply #11, on November 29th, 2016, 08:21 AM »
now thats on of the best demo's I've seen in a long time.
Re: Nelson Rocha
« Reply #12, on December 2nd, 2016, 11:36 AM »Last edited on December 2nd, 2016, 11:51 AM
Nelson describes the mechanism used as such:
Quote from Nelson Rocha
No, I do not charge caps with the output, but I discharge caps to have output :) but that caps first need to be full  :)  is the reason to I say that systems have more that one stage and should not be understood like just one process, but a combination of several process.
Yes, I use nano pulses but made by own design; their action is to create a heavy unipolar pulse that make a very sharp pulse in a coil in a combination of series/parallel resonance. That effect is managed by a parametric oscilator that regulate how stronger is the pulses applyed to a coil and the frequency used.  The pulses will increase in their intensity after some seconds system start working and charges start be collected in other stage of circuit, make pulses going stronger and stronger, oscillation after oscillation.
Hope my answers could help you about your doubts
First we probably need to understand what is a parametric oscillator.
Re: Nelson Rocha
« Reply #13, on December 2nd, 2016, 11:45 AM »
oh wow nice answer.
yeah thats all sounding right on cue.
Re: Nelson Rocha
« Reply #16, on April 14th, 2017, 02:03 AM »
At the heart of this latest device are pancake coils, one of which is wound in a peculiar way:
Start with a piece of wire and find the middle.  Put a pin in the center of your winding form and loop the middle of the wire around this pin, then start winding the coil with each lead of wire ending up on the outside edge.  When complete you will have a pancake coil having almost zero inductance.
If this doesn't make any sense why you would want to do this, you need to study dielectric fields.  This is the whole key to Nelson's success.
Re: Nelson Rocha
« Reply #17, on April 14th, 2017, 05:09 AM »
So it's a self runner then?
Any chance of seeing any schematics of it?
Re: Nelson Rocha
« Reply #18, on April 14th, 2017, 12:25 PM »
Yes it is a self runner and there is zero chance of us getting the schematic or building procedures since Nelson is under contract.
I'll remind everyone, Nelson is being paid to build and improve these devices.  If they don't work, he and his family go hungry.
Re: Nelson Rocha
« Reply #20, on April 26th, 2017, 09:28 AM »
i sure would like to see this in person...
well with my O scope in hand...
i DO not trust those clamp on meters. they work good genial troubleshooting but for checking OU no go.
any how this is an interesting device for sure. and we can dig deeper in to it. as well as the Tesla hair pin, "dialetric" ect.
by the way did you grab offline backups of his entire YT?
Re: Nelson Rocha
« Reply #22, on April 28th, 2017, 05:55 PM »
Latest message from Nelson:
Everything run nice in meeting  in Hamburg and  in Cologne , that is the reason to i travel again to make a small vacations at moment  to Portugal . Like in other occasions , i find many resistance before i start presentation , but in the end run ***** stars  :-) and i could even enjoy a bit of Hamburg city .
 Now i'm make "office" work making descriptions and other boring stuff , but after i have already other system planned to be used to heat system that i will start in next weeks maybe . Not easy live until now , but hope very soon gain my "freedom" of be own to decide how will be my future , hope so .
Re: Nelson Rocha
« Reply #23, on April 28th, 2017, 06:00 PM »Last edited on April 28th, 2017, 06:08 PM
Something to notice in the attached document.  Resistance is associated with anti-resonance (or damping) when applied to specific portions of the circuit.  It also causes the resonant frequency to be altered from it's calculated value.  So help me here guys, think how we could switch in & out resistance in the proper place within a tank circuit at the proper time to create a parametric oscillation.
Re: Nelson Rocha
« Reply #24, on May 1st, 2017, 03:59 AM »
I'm also in contact with Nelson. He pointed out that his bifilar coils tranfer energy without showing a magnetic field.
https://youtu.be/XGyz31yaCdw
I wondered how this could be, because my pancake bifilar coils always showed a magnetic field (i mostly work at resonant frequency).
last week I found out how. the energy enters the coil equaly from both sides.
I did this by using a pulse transformer. basicaly a radio frequency ferrite rod, with 2 bifilar windings on them. pulsed with my IGBT.
the IGBT charges the fields of the primary, then the igbt opens, and the field collapses into the secondary, which is connected to the bifilar pancake coil.  The energy in the secondary (produced by th b emf) leaves the secondary at both ends.
This produced a resonant voltage rise (as before when pulsed without the transformer), but this time, without the magnetic field.
This, reminds me of the tesla hairpin circuit. where the energy (form the discharging caps) also enters from both sides at the same time.
So I think nelson uses the discharge of caps into the coils. but not 1 cap going from start to end, but 2 caps entering start and end at the same time. transforming the energy in the coil (by counter rotation).
So indeed, his nano pulse is a important key. it seems based on a joule thief. most inportant it creates pulses, but on 2 leads.
