I would like to propose an idea of circuit dynamics based upon
the action of a Spring and what it takes to oscillate it. In a spring
you must time your strikes in order for it to resonate, as is well
known. Using an LC circuit to oscillate at its resonate frequency
is the most efficient you can make the circuit. My thought process
is to extend past the resonate frequency by changing the capacitance
of the circuit in a linear function after each pulse to the coil. When
you pulse a transformer core you change the inductance of the circuit
but we always leave the capacitance the same, but if we changed the
capacitance to restore the same circuit to its original circuit parameters
we may have an magnifying effect.
