Musical 3D Printing. + Adding a Pause command after warm up.
« on June 5th, 2015, 06:14 AM »Last edited on June 5th, 2015, 06:15 AM
Playing Music With Your 3D Printer? + How To Add a Pause Command Before Starting Print.
so in this video i show you how to play music with your 3D printer. this all started by wanting to add a beep before a print started. after it was all warmed up. so i could make sure the filament was ready. however i ran across this site that Colin Edwards created to take old school ring tones and make them m300 commands that corresponds to the correct Gcode that the printer will read! freaking sweet! playing music before a print or after is kinda fun.
Nice work Colin!
here is the site: http://ddrboxman.github.io/RepRapRingtone/
***NOTE, you can download the page for offline use so if the site goes down you will still have the code to convert rttl to gcode.
grab trrl codes from places like this:
http://arcadetones.emuunlim.com/
Now to add a pause command will only work if your reading from an SD card, ( i think) just use the command M25  see here for more details:
http://reprap.org/wiki/G-code#M25:_Pause_SD_print
Here's my video:
https://www.youtube.com/watch?v=ITXavSIoEY8
~Russ  Gries
