its a shame u dont have anything to add here Matt. i will design a circuit that putts stand Myers to shame.. how would you like to do this?
what i outlined above are key factors for operating a working cell. screw myers.. since its all about theory i can do it without even testing it..
i make a boost cap setup at up to 36 volts of battery. i then use the caps as a source of power. from a alternator or from the battery, its even possible to use the earth as a battery..
there are so many ways to get the same results.. i take a second coil, and i submerge it in the water. i energy up to 50 kv for a time period prescribed. 5 sec on off. i run a cell as normal with my other power.
i use pulse dc and add a third common ground. i use a rodin coil for my circuit..
many ways to go, and all you go is there goes the cat?
wow.. considering people working on this over 4 years or more.
once you really try to build real setups you will easily see that you´ll run into trouble with wire insulation, vibrations and handsful of other difficulties.
talking about how something "shall work" and make it work that way is something totally different. often I can´t understand the link between your posts and the subject the thread is pointing to.
