I want to create a system that will drive a Tesla Transformer Secondary at a resonance frequency.
As Tesla Transformer secondary coil resonates the self-frequency of the Secondary floats around.
So there is no way a generator that is set up to output a specific frequency can oscillate a Tesla Transformer Secondary.
Also the Secondary of the transformer oscillates many many times faster than the primary has to be excited.
Hundred or a thousand times faster.
The primary has to be excited by a sharp Dirac Function - like impulse. Not by a harmonic oscillation.
The primary is like a clapper that rings the bell.
So the system has to know when to strike the bell with the clapper to create constructive interference of vibrations in the bell, not distructive interference.
So we need PLL or a Phase Lock Loop system. I want a digital system because analog systems are made to hit the bell with a clapper every time the bell oscillates. This is not what we want here.
Modern industry uses FPGA or Field Gate Programmable Array to solve this problem. The FPGA should work at the frequencies of several hundred megaHertz because we are trying to analize the oscillation of the Tesla Transformer Secondary to calculate the precise timing of the next pulse on the Tesla Transformer's Primary.
We need an process frequency of FPGA that is higher than that of the Tesla Transformer's resonance because we need to analize the damped harmonic oscillation of the Tesla Secondary at a higher resolution than the Tesla Coil oscillates.
I developed an algorith and an approximate architecture of this device with my partner, however we don't have skills to work with FPGA and we don't know much about digital filters that are programmed into FPGA to sift out the noise.
Should we use synchrounious or asynchronious mode of operation when it comes to analizing the damped oscillation of Tesla Secondary?
https://drive.google.com/file/d/0B2TsMZPT3tGAN0tBOU5ZRFdIX2c/view?usp=sharing
The most up to date flowchart. (I am working on it.)
This device may have a number of commercial applications and we are looking for people that may work with us on this project.
