Could somone please explain the working of the pickup coil used in the VIC.
The things i want to undertand are
1. why is the pickup coil center taped and a constant 5V is applied to the center.
2. is it reasonable to assume the pick up coil being acting as a constant electromagnet?
3. what could be the polarity of the pickup coil electromagnet as the voltage is fed in the middle?
4. what could happen when the primary coil is pulsed, i.e what will be the strength of the electromagnet before and after pulsing
