My new free energy board schematic CZF1
nav
« on January 2nd, 2015, 12:48 PM »Last edited on January 3rd, 2015, 10:59 AM
This is my new board the CZF1, it reaches parts that no other board reached.
There are 2 variants, 'resonant cell variant' and 'I don't pay for electricity anymore varient'.
The board is complex but those of you who know schematics will see the logic. Please feel free to ask any questions. I need to rest now because it took me two days to get this schematic on paper.
Thanks.
IDEA IS SCRAPPED, MOVE ON.
Re: My new free energy board schematic CZF1
« Reply #5, on January 2nd, 2015, 06:53 PM »Last edited on January 2nd, 2015, 06:56 PM
@nav
those yellow marked parts of the diagram according to ground connection don´t make sense to me.
nav
« Reply #6, on January 3rd, 2015, 02:39 AM »
Quote from Gunther Rattay on January 2nd, 2015, 06:43 PM
@nav
can you please add the pin numbers for the NE555s?
thx
These are standard pulse width modulator boards, you can purchase them anywhere. They have 2 pots for pulse width V+ and V- and a 1K variable resistor. I decided to not build my own 555 board. The 2 SCR's are purposely gate activated only, the breakdown current on the anode/cathode is higher than the board will allow. The Jfets only conduct when there is no current or voltage at the gate. The others are standard transistors.
nav
« Reply #7, on January 3rd, 2015, 02:44 AM »
Quote from Gunther Rattay on January 2nd, 2015, 06:53 PM
@nav
There are two power supplies, the smaller 1 amp supply is the ground for the board components. The larger supply is for transformer operation only. What do you not understand about the grounds?
andy
« Reply #8, on January 3rd, 2015, 03:15 AM »Last edited on January 3rd, 2015, 03:17 AM
NAV
Can you describe how the circuit operates , please?
This help me understand how your design works.
Many thanks for you.
andy
nav
« Reply #9, on January 3rd, 2015, 05:00 AM »
NAV
andy
1. PWM2 sends a pulsed voltage through Q3 into Q2 base, Q3 is already conducting because it conducts only with zero voltage at the gate.
2. The pulse train triggers the base of Q2 which allows permanent voltage into the base of Q1 and Q1 sends the pulse train into the small transformer which is a 1:10 transformer.
I will discuss that zone a little later.
3. After a set numbers of pulses which is determined by the inductance on the secondary of the transformer, the gate will deploy from PWM1.
The gate pulse must only enter the network when PWM2 is at V-. To ensure this, Q4 will only conduct when its gate voltage is zero, since its gate is driven by PWM2, it is impossible for it to conduct while PWM2 is at V+. Q4 is now in a conductive state.
4. Q4 sends forward voltage into the gate of SCR1, SCR1 is gate triggered only but can only be
turned off when PWM1 voltage is zero, so we started SCR1 with gate voltage but it only turns off when the gating period is at V-.
5. SCR1 now sends forward voltage into the gate of Q3 and this stops PWM2 voltage from driving the transformer for the duration of the gate, since Q3 can only conduct when the gate voltage is zero.
6. During the gating period, SCR1 sends forward voltage into Q6. Q6 can only be conductive when its gate voltage is zero, because Q2 has no output voltage at this time it conducts forward voltage into the Optocoupler  CNY17.
7.CNY17 is being driven by a 5Khz pulse from PWM3. The transistor inside CNY17 drives the gate of Q5 at 5Khz, the emitter and collector of Q5 pick up the voltage from the secondary of the transformer and send it into the VIC at 5Khz.
The VIC we know about.
8. Q7 is not conductive during the gate period because its gate only conducts at zero voltage. When the gate period stops it conducts and sends a forward voltage from a permanent live V+ into the gate of SCR2. SCR2 Can only operate with a gate trigger and now completes the circuit back to the pick up coil on the transformer and the spark gap.
What the system does:
It allows a pulse train to charge the small transformer for a time and then deploys a gating period. During the gate when PWM2 is switched off from the primary, it charges the VIC. The load impedance of the secondary on the small transformer is then intercepted before the primary can see it by the pick up coil which uses a spark gap and a ground to neutralize it. When the primary is opened again on the next forward pulse from PWM2, the load impedance of the small transformer has already been spent by the pick up coil.
You see, transformers that are driven by pulses of DC are very different from AC. On the AC transformers, the load impedance is transferred back to the primary at the cross over nodes of the AC current. On DC there are no nodes to do this just off and on. When a DC pulse ends on a transformer, the transformer becomes isolated from the power source completely because the switch is off. The coils collapse into voltage because of the change in current and the secondary begins to spend energy while the source is switched off from the transformer. The load impedance hits the source of power on the next leading edge of the next pulse. That's how they work. What I've done is to take the load impedance on the small transformer and intercepted it so that the transformer core thinks the pick up coil is the primary. The spark gap neutralizes the load impedance.
Some people might remember me saying that the energy companies rip us off by grounding their impedance to zero before it gets to our houses, well I just did the same thing in return, I grounded my load impedance to match there's. Wahahahahahahahahahahaha.
nav
« Reply #10, on January 3rd, 2015, 05:14 AM »
Just to add, the VIC might not necessarily be resonant at 5khz. You set that frequency depending on what frequency your VIC runs at. This system can run anything besides a VIC, you can run what ever you like from it really. Its design is to hide load impedance from the power source and dispose of it.
« Reply #11, on January 3rd, 2015, 05:34 AM »
Haha :-D
Keep it coming Nav.
Scare the sh*t out of the a$$holes who dreads seeing something like this in an open forum :thumbsup2:
nav
« Reply #15, on January 3rd, 2015, 10:08 AM »
The board can be used to charge a VIC and deploy a gate if you want, I wouldn't use it for anything else because it could be none functional. There are some inverse properties about this board I don't like.
Don't build it, its crap.
« Reply #16, on January 3rd, 2015, 10:36 AM »
If I were to take this on I would actually revise your schematics some and use function generators (to start with) to switch (only) N-type Mosfets and NPN BJT's, as the main thing is to both switch the primary transformer together with it's spark gap the way you describe it, and also dump the secondary to the VIC with the cell as per your schematics.
It's a start anyway :thumbsup:
nav
« Reply #17, on January 3rd, 2015, 10:53 AM »
Quote from Lynx on January 3rd, 2015, 10:36 AM
The point is Lynx, The primary has already spent too much energy loading the transformer at zero impedance, it needs to load the transformer at the impedance of the secondary not to spend energy. For it to work the secondary would need to spend more energy than the primary put it at zero impedance. We would then be talking in terms of inverse proportions in the core. Its a bad idea, scrap it and move on.
« Reply #18, on January 3rd, 2015, 01:11 PM »
Ok, thanks.
Regardless, you've inspired me with (quite) a few new ideas with regards to both physical properties in semi conductors and electric circuits, which is enough for me to revise my own theories regarding, amongst others, Meyer's WFC tech.
I hope you'll keep up your good work though, it's muchly needed ;-)
