I am trying to make a heater which will work exactly as described in online instructions, and one part
calls for a fan speed control circuit added to the heater as described here:Quote would I have to make the above described circuit board myself, exactly as specified above, for it to work, or could I use a ready made board like this one?
this one has a fan speed knob built into it, so presumably it might work?
http://www.ebay.com/itm/LM317-Linear-Full-stage-Voltage-Regulator-Board-Fan-Speed-control-w-Switch-/271607513142
I am new to this , so I find it hard to understand what he means and its not clearly written either.
does the plan call for the fan to be regulated to use between 3 and 10 volts ?
He has the fan connected to a 5 volt plug of a computer power supply and his
ESL writing is hard to understand. Can it use over five volts at all if connected to that
5 volt plug?
I am a complete, complete newbie to this, and I don't have
meters and things to work with, so I am trying to find a way to make this by ordering pre-made
parts like the fan speed control for it:
the plan also calls for a temperature control circuit, and again its something I hope to find ready made which I can buy. if you are interested have a look
needed For fan speed controller:
LM317
resistance - 100ohms, 1kohm pot
capacitors- 0.1uf, 10v 100uf
Air flow control is done by regulating the speed of dc motor -> which is done by regulating dc voltage. to regulate dc voltage i used LM317 ic which easily regulate the voltage over 3-10volts as mentioned above circuit. there input can be12v output from computer supply.
5 volt plug?
