I've just been doing some work with a bifilar coil and they do indeed shut down the core EXACTLY the same as opposite bucking coils. We are now so close to getting there I can literally taste it.
Please read the schematic and my explanation in steps. I'll show you how to cut the amps off and charge the cell.
There are six stages and I will describe each stage.
1. The primary is pulsed with voltage (and you can see where we are with the voltage pulse stage indicator in the bottom left corner). At this stage there is no voltage on the cell. The secondary and bifilar choke are pulse charging and the core see's the bifilar choke as one wire going in the same direction.
2. There is a current change at the primary and we know that both the secondary and the bifilar will collapse into voltage but with a superb twist. The diode in between the the secondary and the bifilar cause the voltage collapse to be directional so that a Q+ charge hits one of the cell plates.
This directional path causes voltage to move in opposite directions on the wires of the bifilar coil right at the beginning of the voltage discharge at resonance. The result is that the combined voltage of the secondary and the bifilar coil are high enough to cause the network core to have a magnetic lock and the core is effectively shut down at this stage. We now know that if the voltage is high enough on a bifilar and you combine it with a series diode and a load, magnetic flux opposes itself inside the coil north to north and south to south. Because there is no magnetic flux path back to the primary, the primary cannot see the load impedance. The lock will be long enough to charge the cell voltage to a certain factor at resonance before it shuts down. Gas production has begun at this stage. Note: Not all of the voltage goes into the cell, some of it is wasted with the magnetic flux lock but the primary can't see this.
3. The voltage in the cell is not high enough to lock the flux in the core and the core is open again and the same sequence is repeated but this time we already have voltage on the cell.
The primary pulses the core for the second time.
4. Again the combined voltage of the secondary and the bifilar lock the core so that the input cannot see the load impedance. This time the cell charges even more at resonance but still there isn't enough voltage on the cell to lock the core at the next stage.
5. The voltage on the cell is getting higher and again the primary pulses the core, same sequence again.
6. Finally we charge the cell so that the voltage is high enough to temporarily shut the core off for a period of time. At this point there has been much confusion as to what happens next. I've suggested that the cell and the bifilar continue at resonance sending the voltage exponentially higher but there are problems. Firstly the whole thing would run out of control because there would be no way to control the voltage from this point unless you put a spark gap in parallel with it to ground which in fact may be it but I strongly doubt. We have already step charged the cell so that it shuts off the core flux and the primary has no idea what the hell's going on. If it had extended resonance after the step charge shuts down the core temporarily, there would be no further need for any primary charging at all.
In all honesty I think the exponential value comes from the below stages because the bigger you build your coils and core the bigger the exponential voltage you can play with and we've seen from schematics that the gate is followed by more primary pulses.
So we must assume that the gas production in the cell below uses all the energy out of the cell until it allows the core to open again at the networks base voltage, then you pulse the primary again.
So once again I will remind people:
1. Build your bifilar coil first and find its true impedance and where it is self resonant.
2. Match the cell impedance to the coil impedance while at resonance.
3. The secondary is a dead short during resonance so not impedance matched.
4. The width of your V- on your primary is the width of the resonance period, so make it an adjustable pulse width.
Things we have found out this week:-
1. The combined voltage of the secondary and the bifilar will shut your core down with enough voltage left over to step charge the cell to a percentage but not enough to shut the core down for any length of time initially.
2. The very last pulse from the primary before the gate will be the one that puts enough juice into the network to cause the cell to finally shut the core down for a length of time (the gate)
3. During the gate, the cell will do work until the voltage drops low enough to allow the core to open again and we start all over again.
All I can say now is, Now we have a build off on our hands.
