This is the Falstad Java Sim that I have used for making a Simulation of the VIC.
It's not perfect but at least it works.
You can download the Sim here...
(http://www.falstad.com/circuit/) go to download Zip.
Extract than run........ circuit.jar
I used the older V1.5n but the new one will also work.
To run the Sim on V1.5n
Copy the HHO-Dans-VIC-Sim.txt,
Open the Sim... click on inport and then paste
If you use the new version of the Falstad Sim you must make a file.txt and then open the file.
